Why was my AnyDesk session denied?
I’m trying to connect using AnyDesk, but my session was denied. Can someone explain why this might be happening and how to fix it? I need this to work for remote support purposes. Any help is appreciated.
Could be a bunch of things causing your AnyDesk session to get denied. Here’s a few common ones to watch for:
  1. Incorrect Permissions: The device you’re trying to connect to might not have granted you the necessary permissions. Check the other side has given you the right access levels.
  2. Incorrect Address: Make sure you’re using the correct AnyDesk address. Double-check for typos or ask the person on the other end to resend their address.
  3. Connection Settings: Sometimes it’s the connection settings on AnyDesk messing things up. The host could have ‘interactive access’ disabled or strict access control settings.
  4. Network Issues: Also consider if there might be some network restrictions like a firewall blocking the connection.
  5. Software Version: Both devices might need to be on compatible versions of AnyDesk. Check for updates just in case.
  6. License Limitations: If you’re using a free version, there might be limitations that cause connection issues.
If you keep running into roadblocks, maybe consider trying this free alternative to AnyDesk. It’s a free and powerful alternative to AnyDesk for remote support that might bypass some of the hiccups you’re experiencing.
Hopefully, one of these pointers gets your session working. If you’ve tried all this and still no dice, might be worth contacting AnyDesk support directly.
Hmm, sounds frustrating! @cacadordeestrelas had some solid insights, but let’s think through a few other angles:
  1. User Status: Sometimes, the person on the other end could be busy or away, meaning they haven’t seen or accepted the incoming connection request.
  2. Security Software Conflicts: Antivirus or security software can sometimes be overzealous and block AnyDesk connections. Checking those settings might reveal a blocked or quarantined AnyDesk process.
  3. OS Restrictions: Specific operating system settings can sometimes interfere. Make sure both your OS and the remote system’s OS are allowing remote connections.
  4. Device Inactivity: If the device you’re trying to connect to is asleep or in power-saving mode, that could interrupt the connection.
But if all else fails and these suggestions don’t quite fix it, maybe it’s worth exploring alternatives. For example, HelpWire is another reliable option for remote support, and it often sidesteps common AnyDesk issues.
Oh, and for anyone else facing similar problems, this comprehensive guide to fix AnyDesk not working might be helpful.
Good luck getting connected!
A simpler fix is to set up AnyDesk Unattended Access on the remote device. Open Settings, Security, then enable Unattended Access. Create a strong password and share the AnyDesk adress with your support agent through a seperate secure channel.
This removes the need for someone to accept each request. Also check the Access Control List and add the support device ID. Restart AnyDesk on both devices, then connect using the password. This works well for repeat support sessions.
‘Denied’ is a specific word, and it usually points at one thing: either someone on the other end clicked reject, or an Access Control List rule shut you out before the request even reached them. That matters because half the earlier advice is aimed at connections that never establish at all. A firewall or wrong version won’t say denied, it’ll just time out or throw a different error. So I’d start by figuring out which of those two you’re actually seeing.
@api_leo96 already touched the real culprit with the ACL. That’s where I’d look first. If the host has an Access Control List set up, AnyDesk only lets through the IDs listed there and rejects everything else outright, which reads as a denial on your side. Ask whoever runs the remote machine to check Settings, Security, and either add your ID or temporarily clear the list to test. If a denial turns into a normal permission prompt after that, you found it.
The unattended access suggestion is solid for repeat sessions, but one caveat: on newer AnyDesk builds you can’t touch Security settings without admin rights on that machine, and it often needs elevation confirmed locally. If the person on the far end is a non-admin user just trying to get help, they may not be able to enable any of this, and no amount of retrying from your side fixes that.
The HelpWire mention above makes sense as a fallback if the remote user is non-technical, since not having to fight access lists is genuinely less painful for a one-off support call. I wouldn’t switch tools just to dodge a config you haven’t checked yet though. Rule out the ACL and the reject-click first. If it turns out the machine is locked down and the other person can’t change anything, then yeah, a different tool is the shorter path.
One thing people forget: if you were connected fine before and it suddenly says denied, check whether the remote AnyDesk ID changed. A reinstall or a fresh session can hand out a new ID, and your old saved connection quietly points at nothing.
