I’m planning to buy an iPad primarily for note-taking during lectures and meetings. With so many models available, I’m unsure which one offers the best features (like Apple Pencil support) and performance for this purpose. Any recommendations from personal experiences?
For taking notes, I’d recommend the Apple iPad Air (4th Gen). It’s a solid mix of performance and affordability. This model supports the 2nd-generation Apple Pencil, which is a game-changer for note-taking, as it attaches magnetically and charges wirelessly. The screen is large and crisp, making it great for handwriting and sketching.
Another strong contender is the iPad Pro. While more expensive, the Pro offers more screen real estate, better display quality (ProMotion technology with 120Hz refresh rate), and the higher processing power of the M1 chip. This might be overkill if you’re just using it for notes, though.
Both the iPad Air and the iPad Pro support split view, which is handy for multitasking during lectures or meetings. There’s also palm rejection when using the Apple Pencil, so you can write naturally without worrying about your hand touching the screen.
If you’re looking for a budget-friendly option, the 8th-gen iPad is also worth considering. It’s not as powerful and doesn’t support the 2nd-gen Apple Pencil, but it’s still a solid device for note-taking.
In summary:
- iPad Air (4th Gen): Great balance of features and price.
- iPad Pro: Best tech and features, premium feel, but more expensive.
- 8th-gen iPad: More budget-friendly, still supports note-taking but with fewer bells and whistles.
Choose based on your budget and whether you need the extra features the Pro line offers.
I disagree a bit with going for the iPad Pro unless you really need the additional power and screen size. If your primary focus is note-taking during lectures and meetings, the iPad Mini (6th Gen) might actually be the sleeper hit here. It’s compact, highly portable, and still supports the 2nd-gen Apple Pencil. The smaller screen is easier to manage in cramped lecture halls or crowded meeting rooms. Plus, it’s easier to carry around, especially if you’ll be commuting.
However, the iPad Air (4th Gen) suggestion is spot on for a balanced option. If you go for it, you’re getting a larger screen than the Mini but at a lower price point than the Pro. The 2nd-gen Apple Pencil support with magnetic attachment and wireless charging is fantastic; it’s so convenient when you’re switching between typing and handwriting. The new A14 chip should be more than enough for your needs, especially when paired with the optimized iPadOS.
Now, for those considering the more budget-friendly route, the 9th-gen iPad (better than the 8th-gen slightly) also deserves a glance. Sure, it supports the older, 1st-gen Apple Pencil, but with its A13 Bionic chip, it still offers reliable performance. While you won’t get the ProMotion or the sleek design of the Air, it’s still more than capable for notes, sketches, and basic multitasking. Plus, at its price point, it’s a steal for students on a budget.
To wrap it up:
- iPad Air (4th Gen) is the sweet spot for most users in terms of features and price.
- iPad Pro packs a punch with its M1 chip and 120Hz display but might be overkill.
- iPad Mini (6th Gen)—ideal for those prioritizing portability without compromising on the newer Pencil.
- 9th-gen iPad—best for those on a budget who still need a reliable note-taking device.
Consider how you’ll be using the iPad outside note-taking, and don’t forget to invest in a good stylus-friendly case and perhaps a keyboard. Happy note-taking!
Use a hands-on test instead of comparing specs. Visit a store with one lecture slide or meeting agenda. Write for 10 minutes on each size. Check wrist comfort, text readability, split-screen space, and Pencil storage.
Choose the cheapest model that feels comfortable. For most users, the standard iPad with a compatble Apple Pencil handles notes well. Buy Apple refurbished if price matters. This simple test prevents paying for speed or features you wont use, and it gives you a clearer answer than online comparisons.
The iPad model matters less than the app and the writing surface. People obsess over chips and screen sizes, then handwrite on slippery glass and wonder why it feels off.
@vim_dave89 has the right instinct with the in-store test, but the store won’t tell you the thing that actually annoys you later: writing on bare glass feels like skating. A matte screen protector fixes that for cheap and it’s the single upgrade that changed note-taking for most people I’ve seen mention it. So if you do the store test, remember the real device will feel different once you cover it.
Two things nobody flagged. Storage first. The base 64GB models fill up faster than you’d think once you load handwriting apps, PDFs, and scanned readings, so if notes are your main use I’d jump to the next tier and skip the regret. Second, the app choice decides more than the hardware. Something like Notability or GoodNotes runs fine on the cheaper models, so you don’t need the M-chip horsepower for ink to keep up with your hand.
On the Mini that @boswandelaar pushed, it’s genuinely nice for portability, but the narrow screen gets cramped if you write full sentences or want a PDF open beside your notes. Great for quick jotting, less great as your only note surface. Honestly the 9th or 10th gen standard iPad plus a matte protector covers most students without touching the Air or Pro budget.
