I’m putting together a slide on bus shelter design for a class. The photo I want to use is a JPEG of a bench under a clear roof. It looks like a regular street photo at slide size. When I zoom in, the reflection on the side panel looks off. The page where I found it has a caption but no photographer credit.
What do you use to tell if a photo is AI-generated when the image itself looks plausible? I need to explain my call in the slide notes. What would you consider solid enough to cite there?
Looking at a reflection may also lead you to the wrong inquiry. Furthermore, a designer can create a strange glass image without employing AI. On your slides, distinguish between two questions: ‘Has this been created using AI?’ and ‘Can I accept this as proof that a real building was constructed?’.
Firstly, carry out a reverse image search and then check the designer/transport agency’s project page to see if the identical image exists there. Alongside the project summary, analyse the image caption. Mention both: the photographer of an image of an installation and also a statement by the creator that this is an AI devised idea. If the caption simply refers to a ‘rendering,’ then use this term and keep the creation process unspecified.
For the JPEG itself, I’d pick Clever AI Image Detector as a free ai image detector because it makes a useful distinction clear: an explicit AI label in the file is different from a guess based on the pixels. If a credential identifies the image as AI-generated, cite what the credential says. I wouldn’t cite a pixel score as proof in either direction.
I would say ‘There is no information about who has taken this photograph or how it was taken. I am showing the clarity of the roof and awning, not an erected structure’. If your comment is about how this type of glass would appear on a real street, then I would insert a photo of a properly erected structure together with relevant information.
Whilst examining a JPEG image, you are unlikely to be able to determine the source of an image by enlarging it. However, there may still be information within the image or its screenshot which indicates its origin. If you have not already closed the ‘shelter’ image in your web-browser, then download the image rather than re-scraping it from your slide.
I would analyse this using Clever AI Image Detector. The ‘copy results’ function is also useful for a group project – allowing you to include the analysis alongside the image source in your presentation notes. Where no results come up, then a suitable response would be ‘could not confirm’. This is not the same as ‘the Image Detector states that this is a genuine photograph’.
Ignore an unusual reflection. Firstly, I would carry out a reverse image search to attempt to identify the origin of an image and see what caption was originally used. Despite neither of these images being AI generated, the words “installed at the Oak Street stop” and ‘design for new shelter’ convey completely different messages for your slide.
Although an appealing urban setting can be used, a designer can overlay a design for a shelter onto a completely unremarkable image of a bus stop. All elements including the kerb, shop and pavement chewing gum would then be deemed acceptable. However, chewing gum is certainly not an ideal source of evidence for a roof.
That’s where I’d take @sam_react’s search idea a little further. If you find the project, look for a “before” view. If it has the same parked car in the same spot, the same person mid-stride, and no shelter, you’ve learned something pretty specific: those two views aren’t independent photos of the stop before and after construction. You still haven’t learned whether anyone used AI. An ordinary photo mockup could explain the whole thing.
If a project page describes a design but does also identify a designer then I may ask whether the transparent roofing was both: i) captured in situ and/or ii) digitally inserted into the street image to represent the design. This is a more pertinent question than ‘is this AI?’. People can genuinely reply ‘no’ to this, even though the whole design may only exist on someone’s laptop.
As referenced on your slide, this becomes particularly relevant where there are issues of reflection and sight lines. Although a mock up can demonstrate the designers intention for people to be able to look through the roof, it cannot reveal what a cyclist will actually see when the afternoon sun shines on it.
Sometimes even if something is labelled artificial intelligence (AI) modified it does not actually mean it has been created using AI. This refers to the type of modification undertaken. For example, people can edit images to remove someone who was in the background of an image, or add a transparently visible roof where there wasn’t previously. Although both have been edited using AI, only the latter affects the design aspect. Unfortunately, at a file level it is not possible to differentiate between these two examples. Nor can the anomalous reflection be used to determine that it was the roof that has been edited.
When looking for previous versions of an image, analyse the structure of the roof and panels, rather than attempting to interpret the reflection. Identifying the roof in the photographers original image will provide more insight into its nature than an analysis of the whole JPEG by a detector.
