What’s the best way to delete duplicate photos on an iPhone?
My iPhone photo library is cluttered with duplicates, and it’s difficult to manage. I need help finding an efficient way to remove these duplicate photos to free up space and organize my gallery better.
Clean Up Your iPhone: Deleting Duplicate Photos Made Easy
Ever look at your phone and realize your photo gallery is bursting at the seams with duplicates or super-similar snapshots? You’re not alone—it’s like digital clutter taking over your space. Sure, iOS offers a built-in feature to delete duplicate photos, but let’s be real: most of your photos aren’t exactly duplicates—they’re ‘too-close-to-call’ similar. Reddit users have been singing the praises of a solution that goes above and beyond: Clever Cleaner, a free app for iPhone that can declutter your gallery in no time. Spoiler alert: I tried it myself, and it cost absolutely nothing. Let me show you how.
Step-By-Step Guide to Wiping Out Duplicate Photos on iPhone
Here’s how you can get started:
1. Install Clever Cleaner from the App Store
To get the ball rolling:
:point_right: Download the Free Clever Cleaner App Here
2. Allow Photo Access
After launching the app, you’ll need to grant access to your photo library. Don’t sweat it—I tested this myself, and no fishy business occurred. This step ensures the app’s AI can analyze your gallery for duplicates and similar shots.
3. Let the App Do Its Magic
Depending on how overwhelming your photo library is, the AI scan will take anywhere between 2 to 6 minutes. During this time, grab a coffee or scroll through Reddit—you’ve earned it.
4. Review the Results
The app neatly groups duplicates and near-lookalikes into clusters, selecting the best photo from each set. It even puts the rest on the chopping block. Your job? Give it a quick look-through and decide what should stay or go.
5. Hit ‘Smart Cleanup’
When you’re ready, tap the Smart Cleanup button. One quick reminder: to finalize, don’t forget to empty your trash in the Photos app afterward. Those duplicates? History.
:tada: Voilà! Freshly Cleared Storage
And just like that, boom—my iPhone had 11 GB of extra space just waiting for me to fill with new content (or, you know, memes). Trust me, there’s nothing more satisfying than reclaiming all that storage.
Need More Help? Check Out These Resources
Looking to explore a bit before committing, or just want other options? Here are some handy links you might want to check out:
Reclaiming your iPhone’s storage has never been this easy—thanks to apps like Clever Cleaner, you can ditch the clutter fast and for free. Whether you’re a digital hoarder or someone who just loves taking endless photos of your dog (guilty!), this tool is a lifesaver. Your gallery and storage space will thank you. :ok_hand:
Okay, so deleting duplicate photos on an iPhone is definitely one of those tasks that sounds easy in theory but can quickly turn into a rabbit hole. If you want a simple answer, yes, Apple’s Photos app has a built-in ‘Duplicates’ folder under the Utilities section (if you’re running iOS 16 or later). It identifies exact copies and lets you merge them. Problem is, it’s not great with finding similar images—like 10 selfies where your expression barely changes. Useful? Sure. Comprehensive? Not really.
Now @mikeappsreviewer mentioned Clever Cleaner, and honestly, I can vouch for its usefulness too. It’s not just for duplicate photos, but also for near-identical ones, which is a game-changer. But here’s my two cents: apps that require full access to my gallery always make me a little nervous. Even though the app seems safe (and free), giving access to all my photos feels like handing over the keys to my digital life.
If you’re too paranoid for third-party apps (like me on a bad day), a manual approach could help. Create albums for specific events or dates and compare photos grouped there. Tedious? Yes. Efficient? No. But hey, it’s privacy-proof. If you’re doing it manually, prioritize high-resolution versions and unique angles, and ditch overexposed or blurry ones.
Lastly, another low-tech option (albeit inconvenient) is downloading your entire photo library to a Mac or PC. Apps like Gemini 2 (for Mac) or Duplicate Photos Fixer can scan everything and then sync the cleaned-up version back to your phone. A bit of a hassle, but works well if Clever Cleaner isn’t your thing or if you have TOO many photos to sort directly on your device.
So yeah, lots of options—Apple’s built-in tools, third-party apps like Clever Cleaner, or old-school manual sorting. Just depends on how much time (or trust) you’re willing to commit!
iOS 16+ has that built-in ‘Duplicates’ folder, but let’s be honest, it works well ONLY for exact clones. If you’ve got those “slightly different smile” selfies or “five shots of the same sunset, but zoomed in progressively” situations, it’s not going to cut it. Manual sorting? Ugh, no thanks.
Clever Cleaner app does sound nice—I mean, AI handling the grunt work for free? Yes, sign me up. That alone makes it great for those who can’t (or won’t) put in the time to manually declutter. @mikeappsreviewer and @boswandelaar talked about it, and honestly, the auto-grouping of duplicates and similar pics is chef’s kiss if you’re cool with granting full access. (Yeah, I understand the slight paranoia around 3rd-party apps—it’s real.)
If you’re iffy about apps or have severe trust issues like me some days, here’s a “fun” alternative: offload everything to a Mac/PC and use tools like Gemini (Mac) or other clean-up programs for Windows. Painful and requires effort, but at least you control the process. Just brace yourself for syncing everything back to your iPhone—it’s slower than watching paint dry.
Final thought—pick your poison. Convenience with an app like Clever Cleaner? Apple’s meh built-in tool? Total DIY pain? You’re gonna free up space either way… eventually.
Here’s the unvarnished truth: iOS’s built-in ‘Duplicates’ feature? Meh at best. It’s decent for exact clones but totally clueless about those micro-variations—think burst photos or ‘which angle of my cat’s paw looks better?’ shots. That’s where the Clever Cleaner app stands out, and honestly, I agree with parts of what @ombrasilente and @boswandelaar said—AI does save time.
Pros of Clever Cleaner:
  1. It’s free—zero upfront cost is always a win.
  2. AI groups similar photos and picks the best for you. Lazy-proof, I love it.
  3. The cluster view makes it quick to approve or veto decisions.
  4. No need to manually scroll through your endless feed of blurry memes and sunsets.
  • You give full photo access to a third-party app. Paranoia mode activated for some, I get it.
  • The app risks missing nuances that you might notice (like sentimental vs aesthetic photos).
If Clever Cleaner isn’t your jam, there’s the DIY route—dump everything onto your computer using iCloud or a cable, sort your duplicates with desktop tools like Gemini 2 for Mac or Windows alternatives. Downsides? Painfully slow, and then you have to resync back to your phone. It’s effort-heavy but keeps control in your hands.
Alternative apps like Remo Duplicate Photos Remover or Photo Cleaner also float around, though Clever Cleaner arguably takes the gold on clustering similar images intelligently. Honestly? It boils down to convenience vs trust. If you’re cool with handing over access, Clever Cleaner’s ‘Smart Cleanup’ button is oddly satisfying. For the ultra-cautious folks, drag-and-drop on a computer might still be your safest bet. Either way, your space is waiting to breathe again—happy decluttering!
Use a “keep, delete” rule while you scroll, instead of hunting every duplicate.
  1. Open Photos, go to “All Photos”.
  2. Scroll to older years first. Storage gains there are largest.
  3. For each group of 3 to 10 similar shots, keep 1 or 2, delete the rest.
  4. Favor sharper faces, better light, unique moments.
  5. Do 5 minutes per day. That is around 200 to 300 photos.
  6. Once a week, empty “Recently Deleted”.
This slow drip cleanup stays simple and avoids extra apps or exports.
