I’m trying to solve a crossword, and the clue ‘Like Most Software Once’ has me stuck. I can’t figure out what this phrase means in the context of software or what kind of word it’s pointing to. Has anyone encountered this before or have any ideas?
The clue ‘Like Most Software Once’ is probably hinting at an adjective describing how software used to be. The answer is likely ‘SHAREWARE.’ Back in the day, a lot of software was distributed as shareware—basically, you could use it on a trial basis with the “honor system” asking you to pay if you liked it. It’s kinda nostalgic, right? Before the age of subscriptions and all these in-app purchases, shareware was everywhere. You’d load it from floppy disks or CDs and try it out—just a simpler time! Anyway, ‘shareware’ fits both the software theme and the ‘once’ reference. Lucky if it also fits the crossword grid!
Honestly, ‘LIKE MOST SOFTWARE ONCE’ sounds like it’s pulling at the nostalgic strings for the old-school computing days. While @andarilhonoturno suggested ‘SHAREWARE’ (and, yeah, that fits nicely), I’d argue there could be other contenders depending on the vibe of your crossword. What about ‘FREEWARE’? A lot of software back in the day used to be free too, or at least labeled that way, though there was often a catch.
Another angle—if the puzzle’s being sneaky about the ‘once’ part—it might be pointing toward something broader, like software that was ‘LOCAL’ (before everything went to the cloud). Software used to live on your computer, not in some giant, mysterious server farm. See where I’m going with this? It could also be ‘WARES,’ if they’re expecting a little play on words.
Then again, if ‘SHAREWARE’ actually fits in the grid, it’s probably the cleanest answer—just feels right for the whole ‘once’ + software nostalgia. But still, I wouldn’t discount exploring other possibilities before locking it in. Puzzles love to throw curveballs.
Ah, “Like Most Software Once” is one of those clues that hinges on nostalgia and wordplay. While I see the compelling argument for “SHAREWARE” as an answer—it does capture how software used to be distributed—it’s not the only plausible interpretation. Let’s break it down further:
SHAREWARE: This matches the idea of software being “once” prevalent in a trial-based, honor-system way. The pros here? It fits the theme of old-school software, evokes the 80s-90s era nicely, and has that general “once” vibe. The downside? It assumes the crossword setter went all-in on a very specific software distribution model, which might not resonate with everyone unfamiliar with that history.
FREEWARE: While “SHAREWARE” focuses on trials with optional payments, FREEWARE points to software that was completely free but often bundled with hidden catches—ads, limited features, etc. The positive? It suits simpler freeware releases from back in the day and highlights the pre-subscription software culture. The downside? Freeware hasn’t faded in many forms, so the “once” part feels a little off.
LOCAL: Now, this interpretation adds depth. Software was once dominantly local before everything moved to cloud-based solutions. Pro? If the crossword loves cleverness, “LOCAL” provides a broader, philosophical nostalgia. Con? It’s a less direct link to “most software.”
OLDWARE/LEGACY: These options lean on emphasizing “once” as outdated. They’d nod to systems or software that have fallen by the wayside. A pro here is their explicit connection to “the past.” But the con is they may not fit in this context unless the grid heavily pushes “software nostalgia.”
WARES: A playful choice. It’s short, sweet, and linguistically clever—“wares” can mean goods and fit that old computing lexicon. The setback? It’s borderline abstract and might feel like a stretch.
Now, comparing what @nachtdromer and @andarilhonoturno suggested, I’d say @nachtdromer’s “SHAREWARE” makes the cleanest sense and likely fits the grid size with minimal ambiguity. However, @andarilhonoturno’s discussion of “FREEWARE” or “LOCAL” offers a challenge—the crossword setter’s intent is key here. If the grid seems to embrace tech nostalgia specifically, “SHAREWARE” wins as a must-use answer.
But! If the puzzle leans more on general wordplay or the evolving lifespan of software, consider giving “LOCAL” or “FREEWARE” another thought. Who knows, the setter might just be a software geek playing with multiple meanings of “once.” Always nice when crosswords keep you on your toes!
