Still Can’t Figure Out How To Increase IPhone Storage
My iPhone storage is almost full, and I still can’t figure out how to free up space or increase available storage. I’ve deleted some apps and photos, but the storage warning keeps coming back. What are the best ways to clear iPhone storage without losing important data?
I’d be pretty careful with the idea of upgrading the internal storage on an iPhone. I looked into it a couple years back after my phone was completely full, and at first it seemed like maybe it was just another repair job, like swapping a battery or screen. There were videos showing people replacing the storage chip, so I started checking with repair shops.
The first shop I talked to was honest about it, which was lucky. They said it can be done, but they didn’t recommend it. It’s not a normal part swap. Replacing the NAND chip means micro-soldering, firmware work, and a decent chance of killing the logic board if something goes wrong. Even if the repair works, you’ve voided the warranty and made future Apple service a lot messier.
After that, I quit looking at the hardware route and started cleaning up the storage I already had. The most useful starting point was Settings > General > iPhone Storage. I thought I was out of options, but a lot of the space was just being wasted.
  1. Offloading unused apps helped right away. It removes the app but keeps the documents and saved data, so if you install it again later, your stuff is still there.
  2. Messages were taking up way more space than I expected. Old videos, photos, GIFs, and attachments had built up over years. Setting older conversations to delete automatically helped keep that from coming back.
  3. Photos were the real problem. Apple’s Duplicates album only caught a small amount because most of my clutter wasn’t exact duplicates. It was similar shots, screenshots, Live Photos, and big videos.
For the Photos mess, I ended up using Clever Cleaner. It was useful because it handled the stuff Apple’s duplicate finder didn’t really catch. It grouped similar photos, picked suggested best shots, sorted videos by size, found old screenshots, and could turn Live Photos into still images when the motion part wasn’t needed. That freed up more space than I expected.
iCloud Photos with Optimize iPhone Storage also made a big difference. The full-resolution photos stay in iCloud, while the phone keeps smaller versions until you open something. Day to day, it doesn’t feel much different, but the local photo library takes up way less space. If you don’t want to pay for iCloud, Google Drive or Dropbox can work for files and videos, but you’ll probably have to organize more of it yourself.
After cleaning things up, I only bought extra storage for stuff I didn’t need on the phone all the time. In my case, that was an external flash drive for older photos and videos. It’s easier now with newer USB-C iPhones, and some drives even let compatible apps record video straight to external storage instead of filling the phone first. Just check that the drive uses a supported format like exFAT or APFS.
I’m glad I didn’t go through with the storage chip replacement. Cleaning the phone, moving older files to cloud storage, and keeping an external drive for long-term stuff solved the problem without risking the whole device. I’d try all of that before even considering a hardware modification.
A phone that is full because of photos is a different problem than a phone that is full because “System Data” or app caches have gone wild. I agree with avoiding the storage-chip upgrade, but before deleting more random stuff, check Settings > General > iPhone Storage and see what category is actually eating space. If it’s apps like TikTok, Instagram, Spotify, Podcasts, or Maps, deleting and reinstalling the app can clear cache that offloading may leave behind. If it’s Photos, don’t forget Recently Deleted still holds deleted items until you empty it. If it’s System Data, a normal restart, updating iOS, and sometimes backing up then restoring are more useful than deleting another 20 pictures. You can’t really increase internal iPhone storage in the normal sense, so the trick is figuring out which bucket is lying to you first.
You probably won’t get a permanent fix from deleting a few random things if the phone is already down to its last couple of gigabytes. iOS needs breathing room for updates, cache, photo processing, messages, and app temp files, so if you only free 1 or 2 GB, the warning can come right back the same day.
I’d make a bigger cut once instead of nibbling at it. Go to iPhone Storage, sort of mentally ignore the tiny apps, and attack the big stuff: downloaded Netflix/YouTube/Spotify media, Podcasts downloads, Messages attachments, Files app downloads, and big videos in Photos. People forget the Files app a lot, especially if they’ve saved ZIPs, PDFs, videos, or stuff from Safari. Check On My iPhone and Downloads in Files, not just the Photos app.
Small warning on iCloud Photos: if it’s turned on, deleting photos from your phone usually deletes them from iCloud too. It is sync, not a separate backup. If you want to remove photos from the phone but keep them forever somewhere else, copy them to a computer, external drive, Google Photos, Dropbox, etc. first, then confirm they’re really there before deleting. After that, empty Recently Deleted, restart the phone, and give Storage a few minutes to recalculate. The number often looks wrong right after cleanup.
