Simplest Way To Clean Up Files On IPhone For Someone Not Techy?
My iPhone storage is almost full, and I’m not very tech-savvy. I need a simple, safe way to delete unnecessary files, photos, downloads, and app data without accidentally losing anything important.
The first thing I’d check is Settings > General > iPhone Storage. Give it a moment to calculate everything. That breakdown is much more useful than assuming iOS suddenly filled the phone with system junk.
I had this happen after updating an older 64 GB iPhone. Storage warnings started appearing, and apps kept reloading whenever I switched between them. The update did need some temporary space, but most of the storage was actually being used by years of photos, videos, screenshots, downloads, and accumulated app data.
Photos were taking up the most space in my case, so I dealt with those first. Manually sorting several thousand pictures wasn’t practical, so I used Clever Cleaner. It groups duplicate and similar photos, flags large videos, finds old screenshots, and separates Live Photos for review. Everything is analyzed locally on the phone, there are no ads, and the free version covers regular cleanups pretty well.
Smart Cleanup is useful for clearing the obvious clutter. After that, I usually spend a few minutes in Swipe mode going through older pictures individually. For groups of similar shots, the app suggests which one to keep. That saved a lot of time with batches of vacation and family photos.
Once the photo library is under control, these are the other places worth checking:
  • Remove apps you haven’t used in months. If you may want one again, choose Offload App so its data stays on the phone.
  • Open the Files app and look through Downloads. Old PDFs, ZIP files, and random documents can add up.
  • Delete offline content from Netflix, Spotify, YouTube, Apple Music, and similar apps.
  • If Messages is using a lot of space, remove large video attachments from old conversations instead of deleting the conversations themselves.
Also check the Recently Deleted album after removing photos. iOS keeps deleted items there for 30 days, so you may not see much extra space until you empty it. When I did that, the available storage updated almost immediately.
I wouldn’t spend too much time worrying about System Data. It can grow after an update and then shrink as iOS clears temporary files over the next day or two. App Store cleanup apps can’t directly remove system files because Apple doesn’t give them that level of access.
On a 64 GB iPhone, keeping around 5–10 GB available makes a noticeable difference. Since I started leaving that buffer, updates install with fewer problems, the phone stays more responsive, and storage warnings show up much less often.
Do not empty “Recently Deleted” right away. That folder is your safety net, and if iCloud Photos is turned on, deleting a picture from the iPhone deletes it from other synced Apple devices too. Make a backup first, then leave deleted photos there for a few days so you can confirm nothing important disappeared.
For someone who isn’t techy, I’d keep the first pass boring: remove downloaded movies, music, and podcasts inside their own apps, then use “Offload App” for apps you rarely open. Offloading is much safer than deleting because it keeps the app’s documents and settings. Avoid clearing message threads or app data unless you understand what will be removed.
Clever Cleaner can make a large photo library less tedious by grouping duplicates and similar shots, but treat its suggestions as suggestions. Review small batches rather than approving a huge cleanup at once. I agree with @cyberhive2855lab about checking iPhone Storage first, but I’d wait before permanently clearing anything until you’ve checked your photos, contacts, and important files.
Clever Cleaner won’t clean general app data across your iPhone. It’s mainly for sorting photo clutter. For the simplest cleanup, open Settings > General > iPhone Storage and work from the largest item downward. Delete offline videos or downloads first, then offload unused apps. Ignore tiny files and “cache cleaner” claims since iOS doesn’t allow apps to wipe another app’s cache.
Skip anything that markets itself as a one tap cleaner or promises to free up gigs of hidden junk. Those either do nothing useful on iOS or just clear caches that iOS was going to rebuild anyway, so you gain space for a day and it comes right back. @0xserver6 is right that Apple blocks apps from wiping other apps’ caches, so treat any big ‘cache cleaner’ number with suspicion.
The thing nobody’s flagged yet is video, specifically the videos you didn’t mean to keep. Long screen recordings, accidental 4K clips, that 90 second thing you filmed by mistake. In iPhone Storage, tap Photos and it’ll often show videos eating more than your entire photo library. For most non techy people that’s the fastest single win, faster than sorting thousands of stills. Clever Cleaner does flag the large videos, which is genuinely handy for spotting them, but you don’t even need an app to catch the worst offenders. Photos has a Media Types section that lets you sort by Videos directly.
One correction to the offload advice: offloading an app does free the app itself, but it leaves the documents and data behind, so if the space hog is actually the app’s downloaded content (podcasts, a mapping app with offline regions, a game with gigs of assets), offloading barely helps. Delete and reinstall those instead once you’ve confirmed nothing important lives only inside them. And yeah, back up before you touch Recently Deleted. That part isn’t optional if iCloud Photos is on.
