Should I recover data before formatting a RAW partition?
My drive suddenly changed to a RAW partition after a restart, and now Windows says I need to format it before I can use it. It has important files on it, so I’m worried formatting first could make data recovery harder. What should I do first to recover data from a RAW drive safely without making things worse?
I’ve dealt with RAW partitions a couple times, and I didn’t format first either time. I’d hold off on formatting until the end. Once you do it, you make the next steps harder for no good reason.
What usually happened for me was simple. Windows stopped understanding the file system, labeled the partition RAW, then pushed the format prompt like the drive was empty junk. It wasn’t. The files were still there, but the file system info was damaged badly enough File Explorer gave up.
If your issue came from file system corruption, I’d keep the order tight:
  1. Do nothing to the RAW partition.
  2. Pull off the important data first.
  3. See if repairing the partition is worth the time.
  4. Format only after your files are safe somewhere else.
For recovery, I’d start with Disk Drill. I used it because it doesn’t rely on one method. When enough file system records are still readable, it brings files back with names and folder paths intact. When the structure is too far gone, it switches to file signature scanning and looks for known file types directly on the disk. That matters, because a RAW partition in Windows doesn’t always mean the data is gone. Sometimes it means Windows lost the index and nothing more.
The steps are straightforward:
  1. Install Disk Drill on a different drive, not the damaged one.
  2. Pick the RAW disk or the RAW partition.
  3. Click Search for Lost Data. On an external drive, if it asks for scan mode, use Universal Scan. I’d save Advanced Camera Recovery for SD cards or storage from cameras and drones.
  4. Wait for the scan to finish. Don’t cut it short.
  5. Preview files before recovering them, so you know they open.
  6. Save recovered data to another disk.
If you want a free route, I’ve used TestDisk and PhotoRec too. TestDisk is worth trying when the goal is to repair partition or file system info. PhotoRec ignores the broken file system and carves files out by type. It works, but it’s rougher. You lose original names, folder layout, and sometimes your patience. Sorting a big recovery from PhotoRec is a mess, espeically if you had years of mixed files.
After the recovery is done and checked, then I’d look at repair. If TestDisk rebuilds the partition cleanly, nice, no format needed. If it doesn’t, I’d open Disk Management, make a fresh partition, run a quick format, then copy the recovered files back over.
One thing I learned the hard way, stop if the drive starts clicking, dropping offline, or vanishing during scans. At that point it felt less like file system damage and more like failing hardware. Re-running random repair tools on a dying drive is how you turn a bad situation into a worse one. If the files matter, I’d quit there and hand it to a recovery shop.
Do recovery first. Do not format the RAW partition yet.
Formatting writes new file system data to the drive. A quick format does less damage than a full one, but it still overwrites key metadata. If your files matter, your first goal is preserving what is still there. On a healthy-but-corrupted volume, recovery success often drops after extra writes. So keep writes at zero if you can.
I agree with @mikeappsreviewer on the main point, wait on formatting. Where I differ a bit is repair timing. I would not try CHKDSK on a RAW drive before recovery. CHKDSK often refuses RAW volumes anyway, and when it does run on damaged structures it sometimes makes a messy situtation worse.
My order would be:
  1. Check SMART health with CrystalDiskInfo or smartctl.
  2. If health looks bad, clone the drive first with something like ddrescue.
  3. Recover files from the clone or from the original if the disk is stable.
  4. Verify the recovered files open.
  5. Only then repartition and format.
If you want an easier GUI option, Disk Drill is a solid pick for RAW partition recovery software. It tends to do well when Windows loses the file system but the file data is still present. If the drive is removable, test it on another PC and with another USB cable first. I’ve seen bad enclosures fake a RAW problem.
Also, if this is an SSD, stop using it now. TRIM plus extra writes is bad news for deleted or orphaned data.
For anyone comparing tools, this page on top RAW partition and SD card recovery software for getting files back fast is relevant too.
Short version, recover first, format last. Not the other way arond.
No, don’t format it first. That popup is Windows basically saying “I can’t read this,” not “your files are gone.” Big difference.
I mostly agree with @mikeappsreviewer and @sternenwanderer, but I’d add one thing people skip too often: check whether the partition problem is fake before you jump into recovery mode. If this is an external drive, try a different USB port, cable, enclosure, and another PC. I’ve seen drives show up as RAW just because the adapter was being dumb. Sounds silly, but it saves time.
Also, if the drive is making weird noises, freezing Explorer, or disconnecting, stop poking it. At that point recovery software is not the first move, preserving the drive is.
If it stays stable, recovering data before formatting is the safer play. Formatting can replace file system metadata you might still need. Even quick format is not “harmless.” So yeah, recover first, repair later, format last.
One thing I slightly disagree on with the usual advice: I would not spend too long trying to “fix” the RAW partition before copying data out. People get tempted by repair tools and end up making the mess worse. If the files matter, priority #1 is extraction, not heroics.
Disk Drill is a reasonable choice here because it handles RAW partitions pretty well and gives you a preview, which is super useful for checking whether the recovered stuff is actually usable and not just filenames with false hope attached. Save anything recovered to a different drive, obviously. Writing back to the same disk is how people turn “recoverable” into “oops.”
If you want extra reading, this thread on how to get data from a RAW drive without making things worse has some decent community input too.
Short version: recover first, format after, and don’t let Windows bully you into clicking “Format disk” just because it got confused.
Recover first. Format last.
I’m with @sternenwanderer, @byteguru, and @mikeappsreviewer on the core point, but I’d push one nuance harder: if the drive is internal and suddenly went RAW right after a restart, I’d also check system logs and BIOS/UEFI detection before doing anything heavy. Sometimes the partition is fine and the controller, cabling, or USB bridge is the liar.
What I would not do is click the Windows format prompt just to “see if it helps.” It won’t help recovery.
A small disagreement with the usual advice: I would not rush into any repair attempt, even “safe sounding” ones, unless the data is already copied elsewhere. A lot of repair tools are great right up until they are not.
About Disk Drill since it came up:
  • Good at finding files on RAW volumes
  • Preview feature is genuinely useful
  • Easier to use than TestDisk/PhotoRec
  • Can recover with folder structure when metadata is still readable
  • Not the cheapest route
  • Deep scans can take a long time
  • Signature-based recovery can still lose original names
  • Best results still depend on drive health
So yes, Disk Drill is a sensible option if you want the least painful GUI path, especially for a non-technical user. Just install it somewhere else and recover to a different drive.
One more practical thing people skip: if the recovered files are irreplaceable, sample-check a bunch of them, not just one photo and one PDF. Open larger videos, archives, project files, spreadsheets. RAW recoveries can look successful until you hit file corruption halfway through.
If the drive starts disappearing, slowing to a crawl, or throwing read errors, stop and clone first. That changes the game from “file system problem” to “failing hardware problem.”
