Recommendations for Best Remote Starter With Phone App?
My car’s manual remote starter just died, and I want to replace it with a remote starter that I can control via a phone app. I’ve been looking online but there are so many options and reviews. I’m hoping to find something reliable and user-friendly. Anyone have personal recommendations or experiences to share?
If you’re looking for a solid remote starter with a phone app, I’d recommend checking out the Viper SmartStart system. I’ve had mine for about a year now, and it’s been pretty reliable. The app is very user-friendly, and you can even control multiple cars if you happen to have more than one.
Installation was fairly straightforward, though you’ll need a professional to do it if you’re not comfortable with car electronics. One downside, though, is that the SmartStart module can be a bit pricey, but for the added convenience, it’s worth it IMO. Plus, Viper offers a nice range of features like keyless entry, GPS tracking, and even Google Assistant and Amazon Alexa integration, which is pretty cool if you’re into smart home devices.
Another option might be the Compustar DroneMobile. It’s pretty similar in feature set, but some people swear by its reliability. I haven’t used it personally, but the reviews are generally positive.
Just make sure to check the compatibility with your car model before purchasing. There’s nothing more frustrating than getting everything set up only to find out it doesn’t work with your ride.
Hey, considering you’re diving into remote starters with phone apps, I def second the recommendation for Viper SmartStart. But, another cool option you might wanna check out is the Start-X Remote Start Kit w/Phone App. It’s pretty slick, combines well with most vehicle systems, and is known for stellar customer support if you hit a snag during setup.
I’ve also tried the MyCar Mobile App-based remote starter, and it’s pretty robust. What’s sweet is its compatibility with lotsa different car models. The app interface is clean, so you won’t get lost trying to start your car or use other features. But ya, like @cazadordeestrellas said, always make sure your vehicle model matches. That’s a huge deal-breaker.
If price is a concern (and let’s be honest, for some of us, it usually is), you might want to look into simpler models that still offer app control but skip some of the gadgetry. Autostart ASCL6 is more no-frills but gets the job done efficiently.
And yeah, depending on your level of tech comfort, professional installation is usually the smart move. Last thing you want is messing up your car’s electrical system over a weekend DIY project gone wrong, right? Good luck! :red_car:
Actually, I’m with you on the Viper SmartStart, @shizuka. Used that one myself, and it’s been rock solid! However, another system to consider is the Viper DS4 Remote Start System. It’s kinda like the SmartStart but with a few more bells and whistles. You get the same app control and it integrates well with existing car systems. Plus, the range is amazing – you can start your car from pretty far away.
I’ve also heard good stuff about the Compustar CM900. Again, it’s that blend of reliability and feature richness. One thing to keep in mind though is that some users report the app can be a bit glitchy, but overall I think it’s got strong performance.
Pros for Viper DS4:
  • Amazing range
  • Comprehensive app control
  • Integrates well with existing systems
  • Pricey (but worth it if you need all the features)
  • Requires a professional for install if you’re not tech-savvy
@cazadordeestrellas mentions Start-X Remote Start Kit w/Phone App. From what I gather, it’s decent but some users find the installation might need a bit more finesse.
As for a more budget-oriented option, you could look at the Crimestopper RS7-G5. It’s more of a no-nonsense remote starter but with app control. Doesn’t have all the extra features, but if you’re just looking to start your car remotely without breaking the bank, it’s a solid bet.
One thing that @shizuka and @cazadordeestrellas both highlight is the importance of compatibility. It’s def a must. There’s no bigger frustration than getting everything set up only to find out it’s not compatible with your car’s make/model.
As @cazadordeestrellas mentioned, the Autostart ASCL6 is also worth considering if simplicity is your thing. It won’t overwhelm you with features, but it gets the job done without all the frills.
Overall, it really comes down to what you prioritize – feature-rich and costlier or simpler and budget-friendly. Choose your warrior! :wrench::red_car:
Skip a full remote start swap. Add a plug in smart outlet and a small interior heater for winters or a low amp battery maintainer for storage.
You schedule the outlet with a Wi‑Fi smart plug app. Example, TP‑Link Kasa or Wyze, under 20 dollars.
You leave the heater or maintainer switch on. The plug controls power.
You pre‑warm the cabin or keep the battery strong, without touching the car’s wiring or remote start system.
