Need suggestions for the best universal TV remote?
I’m tired of juggling multiple remotes for my TV, soundbar, and streaming box. I’ve tried a couple of cheap universal remotes and they either don’t program correctly or lose settings. I’m looking for reliable recommendations for the best universal TV remote that’s easy to set up and works with most brands, ideally with good build quality and backlit buttons.
Hi everyone.
I hit the point where I was done hunting for TV remotes in couch cushions.
We have two TVs at home, Samsung in the living room and LG in the bedroom. Two different remotes, both always missing when I need them. My phone, on the other hand, is glued to me. So I went down the rabbit hole of universal TV remote apps for iPhone, Android, and even Mac.
Below is what I tried, how it behaved in real use, what broke, what worked, and what I’d install again.
I’ll drop all the links I used, so you can check them yourself.
Part 1: TV remote apps I tried on iPhone
I went through four iOS apps:
TVRem Universal TV Remote
TV Remote – Universal Control
Universal Remote TV Smart
I used them mostly with Samsung and LG, but I also checked the menus for Sony, Android TV, Roku, etc.
TVRem Universal TV Remote – my iPhone keeper
I started with this one and, spoiler, I ended with it too.
It worked with Samsung and LG right away and listed support for Sony, Android TV, Roku, and a bunch of other brands. Setup was simple: same Wi‑Fi, auto-detect, tap, done. No accounts, no “start 3‑day trial” popups.
What surprised me: it is straight-up free. No “premium” section, no “unlock full remote” screen after 5 clicks.
Stuff I used a lot:
• Touchpad for moving around apps
• Voice input support (through Google Assistant or Alexa on TVs that support it)
• On-screen keyboard
• Volume and channel switching
Pros I noticed
• Interface is clean and obvious, I did not have to think where things are
• TV connection is quick and repeatable
• No paid tiers or locked buttons
• Supports a bunch of TV platforms
• Does everything my physical remotes did
• I did not see Vizio support, so if you have Vizio, this will not help you
Price
Free
Link
There is also this Reddit thread where people argue about universal remotes vs physical ones and list a bunch of apps:
https://www.reddit.com/r/DataRecoveryHelp/comments/1qqa2bh/best_universal_tv_remote/
Product page:
My verdict
If your TV brand is supported, this is a solid daily remote. No weird monetization tricks, all the basics included, and no learning curve.
This one feels like someone started from the same idea and then added a paywall on top of every second tap.
It connects over Wi‑Fi, works with multiple brands, and feature-wise it looked fine on paper: touchpad, voice, channel launcher, keyboard, media controls, and casting.
To actually try all of it, I had to start a free trial. Without it, most of the interesting stuff was locked.
Things that were useful once unlocked
• Touchpad worked fine
• Voice control responded quickly
• Channel launcher was convenient for jumping into apps
• Keyboard was decent
Annoyances
• Ads inside the app
• Many of the things you expect as default remote features are stuck behind “try premium”
• I hit a few random crashes, mostly when opening the side menu
Price
From 4.99 and up
Link
My verdict
Functionally OK, but it turned into a paywall maze. If you are fine paying and hate ads less than I do, it might work. I skipped the full purchase and went back to looking for cheaper or free options.
This one felt off as soon as I saw the layout.
It supports many brands, so compatibility is not the issue. The problem is the interface. The buttons feel jammed and oddly placed, and it does not feel like a remote at all. I spent more time looking for controls than using them.
What it offers
• Keyboard
• Navigation through TV apps
• Volume and channel controls
• Big brand list
Cons I hit fast
• Clumsy interface that slowed me down
• No voice control at all
• Aggressive ads, including forced video ads
• Every time I tried to do something slightly extra, like launching YouTube, I ended up on a pay screen
Price
From 7.99 and up
Link
My verdict
This was the weakest of the iPhone apps. Bad layout, heavy monetization, and the general feel of “pay first, get features later.” I removed it quickly.
This one sits in the middle.
It turns iPhone or iPad into a remote and lists LG, Samsung, Sony, Vizio, Android TV, and others. It relies on Wi‑Fi, so both devices need to be on the same network.
It sticks to basics:
• Switch channels and apps
• Playback buttons like pause, rewind, etc.
• Detects and connects to TVs without drama
• Interface is clean and readable
• Core remote features are there
• Free trial included
• Ads appear inside the app, removable if you pay
• Almost anything advanced sends you straight to a paywall
Price
From 4.99 and up
Link
My verdict
I used the trial to see everything. Once loaded, it worked fine, although the main screen lagged a bit. The constant pressure to upgrade and the ad noise pushed me away. If you do not mind paying right away, it is not bad, but it is not cheap either.
Part 2: Android TV remote apps I tested
My wife is on Android, so we tested a few apps there too. Short version: Android remote apps love ads way more than I do.
Universal TV Remote Control
This one is all over Play Store charts.
It supports a long list of brands: Sony, Samsung, LG, Philips, TCL, Hisense, Panasonic, and several others. It also works over Wi‑Fi and as an IR remote if your phone still has an IR blaster.
Features that looked good on paper
• Trackpad-style navigation
• Voice search
• App control
• Keyboard
• Standard remote controls
The catch is the ad situation.
• Wide TV support
• Works via Wi‑Fi and IR, which is rare now
• All essential controls seem to be available in the free tier
Cons that killed it for me
• Ads everywhere, including ones that are weirdly hard to close
• Frequent crashes that forced me to reconnect to the TV
Price
Free
Link
My verdict
At first I thought “ok, free and feature packed, this is good.” After a few minutes, I was stuck in an ad loop. Functionality is not bad, but the user experience took a hit from the ad overload.
Remote Control For All TV | AI
This one tries to brand itself as AI-powered. In daily use, it felt like a normal remote app that hides half the things behind a paywall.
It supports many brands and connects via Wi‑Fi. It found our TV, but it took longer than the others.
Free version
• Basic directional pad
• Enough for simple tasks
• Filled with ads
Paid features
• Ad removal
• AI assistant
• Keyboard with voice input
• Screen mirroring
• Works with many common TV brands
• Free tier has basic controls if that is all you need
• Heavy ad load in the free tier
• Slow TV detection each time
• Most helpful features are locked behind a subscription
Price
From 4.99 and up
Link
My verdict
If you only want a simple directional pad and you tolerate ads, this is okay. For anything more than that, you hit paywalls and delays. I uninstalled it and moved on.
Universal TV Remote Control (Unimote)
This one tries to be the “all in one” Android remote.
It supports Wi‑Fi Smart TVs and IR setups, so if your phone has an IR blaster you get more coverage. It found our TV fast, but it did not always connect on the first try.
Pattern I saw
• Open app
• TV detected fast
• Click to connect
• Ad appears
• Connection sometimes fails, repeat
• Simple layout with clear controls
• Works with both IR phones and Wi‑Fi TVs
• Full-screen video ads appear often and break the flow
• Many features require in-app purchase, so the free tier feels crippled
• Connection dropped from time to time
Price
From 5.99 and up
Link
My verdict
Ok as a backup if you keep it installed and use it occasionally. For daily control it is too unstable and ad-heavy compared to what you get.
Universal TV Remote Control (another one)
Yes, same name, different dev.
This one supports LG, Samsung, Sony, TCL, and others. It works over Wi‑Fi and IR and tries to look like a generic remote.
What it offers
• Power on/off
• Home/Menu button
• Basic playback (Play, Stop, Back, Forward)
• General control screen
• All basic remote functions seem present
• Ad quantity is high
• Most features turn out to be paid once you start tapping around
Price
From 3.99 and up
Link
My verdict
Function set is fine, but you are paying for almost everything and watching a lot of ads in the meantime. If ads annoy you, this gets old fast.
Part 3: Controlling the TV from a Mac
I use a Mac a lot while working, so I was curious if I could keep a remote on my laptop too. Turns out, yes.
TVRem Universal TV Remote (Mac)
Same name as the iPhone app, and it behaves similarly.
I installed it from the Mac App Store, launched it, and paired it with a Samsung TV in a few seconds. No registration, no “copy code to email” nonsense.
What I used
• Touchpad for navigation
• Keyboard for logins and searches
• App launcher for jumping into streaming apps
• Interface is clean and simple
• No ads, no surprise subscriptions
• Works with a range of popular TV brands
• Covers all the stuff I use daily
• No Vizio support here either
Price
Free
Link
My verdict
If you watch a lot of content while sitting at your Mac, this is a nice way to keep control nearby. No extra cost, and it just acts like a normal remote.
TV Remote, Universal Remote (Mac)
This is another Mac App Store remote app.
It connected to my TV without a fight and the interface looked decent. The problem is the same as with many of the mobile apps: most of the useful features sit behind a paywall.
I also had a couple of random crashes where the app closed mid-use. Not constant, but enough to notice.
• Interface is alright
• Supports multiple TV brands
• Has the basic controls you would expect
• Many features require payment
• Occasional crashes interrupt usage
Price
From 4.99 and up
Link
My verdict
If you pay, you get something usable. I did not like the instability and did not feel like contacting support for a remote app, so I stuck with the free alternative.
Part 4: Physical TV remote vs remote app
Here is how it played out for me after a few weeks of using apps instead of hunting for the physical remotes.
Definitions
Physical remote
The plastic remote your TV ships with or an aftermarket replacement.
Remote app
Software on your phone or tablet that controls the TV over Wi‑Fi, Bluetooth, or IR.
Why I leaned toward apps
  1. Harder to lose
    My phone is almost always next to me. Remotes wander all over the place. With apps, I stopped asking “where is the remote.”
  2. Text entry does not suck
    Typing passwords with four-way arrows is painful. Phone and Mac apps give you a normal keyboard. Typing streaming logins or search queries became a lot faster.
  3. Cost
    Replacement remotes are not cheap over time. Ballpark prices on Amazon when I checked:
    • Samsung TV remotes (2019–2025 models): roughly 15–20 dollars
    • LG TV remotes: roughly 13–35 dollars
Compare that with something like TVRem that is free, and the math is simple if all you need is standard control.
  1. Multiple devices in one place
    Remote apps let you switch between TVs inside one app. If you have a living room TV and a bedroom TV, this is much easier than carrying two remotes. Some apps also list other smart devices.
  2. Interface
    Phone and Mac screens give you cleaner layouts than a cluttered physical remote. You get touchpad areas and labels instead of rows of tiny buttons.
Limitations I ran into with apps
• You need Wi‑Fi or Bluetooth in decent shape
If your TV is asleep weirdly or Wi‑Fi is acting up, some apps stop seeing the TV. IR remotes still work in those moments.
• You depend on your phone
If your battery is low or your phone is charging in another room, your “remote” is now unavailable.
• Some TVs only expose basic controls
Older or cheaper smart TVs might let the app do only simple actions like power, volume, and channel. App features depend a lot on what the TV supports.
What I ended up using
After trying all this, I stopped bothering with physical remotes most of the time.
On iPhone, my top pick is:
• TVRem Universal TV Remote – free, no ads, all basic features. I use the touchpad and keyboard a lot. Only gap is Vizio support, so if you own Vizio this will not help with that TV.
Second place on iPhone goes to:
• TV Remote – Universal – paid, with a trial that showed it works fine. If you are willing to pay and tolerate some upsells, it is decent.
On Android, my wife ended up keeping:
• Universal TV Remote Control – the first one in the Android section. I still think the ad volume is over the top, but from a feature standpoint, it does the job for her, and she did not want to dig through more apps.
If you are tired of chasing physical remotes, start with the free ones, especially TVRem on iOS and Mac. If they support your TV brand, you get a working setup without extra cost. If not, the rest of the apps in this post give you backup options, just watch for how aggressive the ads and paywalls are before you commit.
Short answer for physical remotes: stop buying the super cheap ones. They lose codes, have weak IR, and awful firmware.
If you want one solid “real” universal remote:
  1. SofaBaton U2 (or X1 if you want hub based)
    • Handles TV, soundbar, streaming box in one shot.
    • Uses a code database plus learning mode, so if one device is weird, you teach it from the original remote.
    • Settings stay in the remote, not in volatile memory, so they do not vanish when batteries die.
    • U2 is around 40–50 bucks, X1 around 150.
    • X1 uses a hub that blasts IR to your gear, so you do not need to point the remote with sniper precision.
  2. One For All URC-7880 or URC-7965
    • Less fancy than Logitech Harmony was, but reliable.
    • Good brand coverage for TVs, AVRs, soundbars.
    • “Activity” style macros, so one button powers TV + soundbar and selects inputs.
    • Codes stay stored. I have one that survived multiple battery swaps over years.
  3. Avoid these patterns
    • No-name 10–20 dollar “universal” sticks on Amazon with a 5-page code sheet. They often forget settings after a few weeks or after one low battery event.
    • Remotes that rely only on “learning” each key, no code library. You end up spending an hour teaching every button and then lose it all if memory corrupts.
That said, I slightly disagree with @mikeappsreviewer on going app first. Phone remotes are nice as backup, but for fast volume changes, mute during calls, or family use, a physical remote is still faster and more consistent. Wi Fi hiccups, phone battery, and “where did my phone go” all get in the way.
If you are open to mixing both:
• iPhone or Mac
TVRem is a good call like they said. Use it for typing passwords, app search, and when the couch ate your remote.
• Daily driver
Get a SofaBaton U2 or One For All URC model. Program:
  1. Add TV, soundbar, streaming box via built in codes.
  2. Test each. Fix missing buttons with learning mode.
  3. Create a macro “Watch TV” that powers on all three and sets correct inputs.
  4. Tape the old remotes in a drawer for backup.
That combo removes juggling, keeps things stable, and you still have your phone as a backup remote instead of the primary one.
Short version: stop buying the $15 “universal” specials and look at mid‑tier stuff that has a real code database and non‑volatile memory.
Since @mikeappsreviewer went deep on apps and @techchizkid already covered SofaBaton + One For All, here are a few different solid options that fix the “loses settings / won’t program” headache:
1. One For All URC-7880 / URC-7935 / URC-7980 family
Yeah, different model than the one mentioned already, and still very underrated.
  • Multi‑device: TV, soundbar, AVR, streaming box, etc.
  • Uses built‑in code library plus “learning” for odd buttons.
  • Settings survive battery pulls because they are stored in flash, not some flaky RAM.
  • Macro support so you can do “Watch TV” = power TV + soundbar + switch inputs.
  • The 7935 “Streamer” is great if you mostly use a box (Roku, Fire TV, Apple TV) plus TV power/volume.
If I had to pick one for someone who just wants it to work, I’d land here before SofaBaton. Less fancy, but more “set and forget.”
2. GE / Philips 8‑Device Backlit remotes (MID range, not the $9 ones)
The dirt‑cheap GE that @techchizkid warned about is trash, agreed.
The slightly nicer models (with full backlight and 4+ devices) are actually usable:
  • Actual code database that covers most TV/SB/streamers.
  • Learning mode to capture missing commands from your original remotes.
  • Store config in non‑volatile memory so they don’t wipe themselves when batteries die.
Key is: avoid the 3‑device “basic” versions and grab the bigger model. Costs a bit more but doesn’t forget everything every other month.
3. If you like the idea of a hub but don’t want SofaBaton X1
You can still find used Logitech Harmony Companion / Elite on resale sites. Logitech abandoned the line, but:
  • Database is huge and still works through their servers.
  • Rock solid with TV + soundbar + streaming box.
  • Activities are smoother than anything SofaBaton is doing right now.
It’s not future‑proof, so if “support for 10 more years” matters to you, skip this. But for someone tired of juggling remotes today, Harmony is still miles ahead of the random Amazon no‑name stuff.
4. Stuff to filter out right away
You already hit this, but just to be explicit:
  • Any remote that:
    • Only offers “learning every key” with no code library. Time sink, then memory corrupts and you’re back to zero.
    • Brags about “controls 1000+ brands” but ships with a 2‑page pamphlet of tiny numeric codes and no website support.
    • Has no mention of “settings retained during battery change” in the manual or listing.
Those are exactly the ones that lose programming or act weird once the batteries sag.
Slight disagreement with the others
I don’t fully buy the “phone remote as backup only” idea. If you’re fine using your phone, pairing TVRem (or similar) for text entry plus one solid physical universal remote for everyday channel/volume/input is actually ideal. Most people in my house still grab the physical remote first, but I use the app constantly for sign‑ins and search.
What I’d do in your case
  1. Pick one of these as your main universal:
    • One For All URC‑7880 or URC‑7935 if you want something reliable that just works.
    • GE/Philips 8‑device backlit if you want cheaper but still not garbage.
  2. Program TV + soundbar + streaming box.
  3. Add a single “Watch” macro so you literally only hit one button to get your whole setup on and on the right inputs.
  4. Keep your originals in a drawer, and maybe a phone remote app installed purely as an emergency backup.
That combo solves the juggling problem without you going through yet another pile of cheap remotes that forget who they are every time a AA goes weak.
Short version: I’d actually split your setup into two “remotes”: one solid physical universal plus a phone / desktop app as backup and for typing. The cheap all‑in‑one sticks you already tried keep burning you for a reason: weak code databases and no non‑volatile memory.
Where I agree / disagree with others:
  • @techchizkid is right to steer you to mid‑tier hardware like SofaBaton and some One For All models, but I think the fancier stuff is overkill unless you have a receiver, game consoles, and lighting scenes.
  • @yozora leans very hard into hub‑style setups; nice if you love tinkering, but you said “reliable” more than “feature‑packed.”
  • @mikeappsreviewer basically proved that apps can completely replace remotes in many cases, and I agree more than most on that point, especially for text entry.
Since those three already covered SofaBaton / Harmony / generic cheap universals and a big list of apps, I’d look at this combo instead:
1. Use a sturdy, boring universal as your main remote
You want three things your cheap ones did not have:
  1. Real built‑in code library for TV + soundbar + streaming box
  2. Learning capability to fix missing buttons
  3. Non‑volatile memory so it does not lose programming when batteries die
Models from One For All and the better GE / Philips 6–8 device remotes hit that sweet spot. No fancy color screens, but they:
  • Store macros like “Watch TV” that power everything and pick the right inputs
  • Survive battery changes without wiping your setup
  • Usually give you punch‑through for volume so your soundbar volume works on all activities
I slightly disagree with the idea that you must jump to a hub like SofaBaton X1 unless you really want app‑driven automation. For most people with TV + soundbar + streaming puck, a good non‑hub remote is actually more reliable and faster to respond.
2. Pair it with a universal TV remote app
This is where what @mikeappsreviewer found becomes useful. For daily use, the physical remote wins in speed and “anyone can grab it” factor, but:
  • Apps crush it for password entry and search
  • They are free or cheap compared to another premium remote
  • They are great when someone walks off with the main remote
If you are on iPhone or Mac, the sort of app they described that auto detects TVs on Wi‑Fi and has no in‑your‑face paywalls is exactly what you want. Pros of that kind of universal TV remote app:
  • No extra hardware to buy
  • Clean layout that normal humans can figure out
  • Keyboard and sometimes voice input for logins and search
  • Multi TV support inside a single interface
  • Needs the TV to be on the same network and cooperating
  • Will not help with older non‑smart gear that only speaks IR
  • If your phone is dead or in another room, you lose your “remote”
Used alongside a physical universal, the drawbacks vanish almost entirely.
3. Avoid this trap again
Any universal that:
  • Makes you “learn” every single button with no code presets
  • Does not say anything about retaining settings if batteries are removed
  • Ships with a tiny folded sheet of codes and no online updates
is the type that will either not program correctly or will forget everything after a power blip. Those are the ones you have already been burned by.
4. Practical setup pattern
  1. Program the physical universal to control:
    • TV power / input
    • Soundbar power / volume
    • Streaming box navigation
  2. Add one macro for “Watch Streaming” that:
    • Turns on TV + soundbar
    • Switches TV to HDMI with your box
    • Selects the right soundbar input if needed
  3. Keep the app on your phone for:
    • Logging into apps
    • Searching for titles
    • Emergency use when the physical remote goes missing
That way you are not juggling three or four remotes anymore, and you are also not betting everything on another bargain‑bin “universal” that forgets its own identity whenever the batteries sag.
Try HDMI-CEC before buying anything. It lets your streaming box remote control TV power, inputs, and soundbar volume.
Connect the soundbar through HDMI ARC or eARC. Then enable CEC in each device:
Samsung: Anynet+
LG: Simplink
Sony: Bravia Sync
Roku or Fire TV: HDMI-CEC
Set the streaming remote’s volume control to CEC. One remote should then handle playback, power, and sound. Setup takes about 10 minutes and costs nothing. Keep the original remotes in a drawer for rare settings changes. CEC names are confusing, but once enabled, it’s usally stable.
CEC is the right first thing to try, but @api_leo96 makes it sound calmer than it actually is. The part that bites people is soundbar volume. Power and input switching over CEC are usually fine, but volume control depends on whether your soundbar and TV agree on the protocol, and half the time the streaming remote ends up adjusting the TV’s internal speakers instead of the bar. So you enable everything, it looks like it works, then you realize the volume buttons are talking to the wrong device.
The other CEC gotcha is phantom power. Once it’s on, your TV will randomly wake up because the streaming box twitched, or the whole chain powers on when you only wanted the soundbar. Some people love it, some people end up disabling it for that exact reason. Worth knowing before you assume it’s set and forget.
Here’s the thing everyone in this thread is skating past though. If you already own an Apple TV, Fire TV, or newer Roku box, the remote it came with can usually learn IR for TV power and soundbar volume directly. No CEC, no extra hardware, no app. You point the original soundbar remote at it once during setup and it copies the volume commands. That covers the exact three-device juggling the OP described without spending a cent or buying a SofaBaton. It won’t do fancy macros, but for TV plus soundbar plus streaming box it’s often enough.
On the app side, the write-up from @mikeappsreviewer is solid for what it is, and something like TVRem is genuinely handy for typing logins since on-screen keyboards on TVs are miserable. I just wouldn’t lean on a phone as the daily volume knob. Wi-Fi remotes have lag that you notice most when you’re trying to mute something fast, and that’s the moment nobody wants to unlock a phone.
So my order would be: try your streaming remote’s built-in IR learning first, fall back to CEC if that box doesn’t have it, and only buy a dedicated universal like the One For All models mentioned above if you’ve got older IR-only gear or a receiver in the mix. Skip the physical remote purchase entirely if the free options already handle your setup.
