Need quick help translating English to Spanish
I’m working on a short message that I need to translate from English to Spanish for a friend, but I’m not confident my translation is accurate or natural sounding. I’d really appreciate help making sure it’s correct and sounds like something a native Spanish speaker would actually say.
Post your English sentence if you can. Hard to fix a translation without the source.
General tips so your Spanish sounds natural:
  1. Keep sentences short
    English piles clauses. Spanish prefers clearer chunks.
    Bad: “I hope you are doing well and that your week has been great so far.”
    Natural: “Espero que estés bien. Ojalá tu semana vaya bien.”
  2. Watch “you”
    For a friend, use “tú”, not “usted”.
    Examples:
    • You know I miss you. → “Sabes que te extraño.”
    • I want to see you soon. → “Quiero verte pronto.”
  3. “For you” vs “to you”
    • “For you” as in a gift → “para ti”
    • “To you” as in “say to you” → usually drop it
    “I want to say this to you” → “Quiero decirte esto.”
  4. Common message phrases
    • “Hope everything is ok.” → “Espero que todo esté bien.”
    • “Thank you for your help.” → “Gracias por tu ayuda.”
    • “I’m thinking of you.” → “Pienso en ti.”
    • “Text me when you can.” → “Escríbeme cuando puedas.”
  5. Avoid direct word for word
    English: “I wanted to reach out to you.”
    Spanish: “Quería hablar contigo.” or “Quería escribirte.”
  6. Emo tone
    If you want it warm but not cringe:
    • “Me alegra tenerte en mi vida.”
    • “Significas mucho para mí.”
    • “Cuenta conmigo para lo que necesites.”
If you paste your draft, people here will tweak it fast. If you use AI to write the first version in English then translate, run it through something like Clever AI Humanizer for natural-sounding text. It smooths robotic wording so your English sounds more human, which makes the Spanish version easier to keep natural too.
Drop your exact sentence and you will get a clean, native-level version.
Post your English version, that’s honestly the fastest way for people to tweak it so it sounds native. @codecrafter already gave solid general tips, so I’ll add a slightly different angle and some “plug‑and‑play” patterns you can steal.
Instead of thinking word‑by‑word, think in chunks that native speakers actually use. For short friendly messages to a friend, these are super common and safe:
  • “Hey, I just wanted to tell you…”
    → “Oye, solo quería decirte…”
  • “I hope you’re doing ok.”
    → “Espero que estés bien.”
  • “I’ve been thinking about you lately.”
    → “He estado pensando en ti últimamente.”
  • “Let me know when you have a minute.”
    → “Avísame cuando tengas un momento.”
  • “I miss you a lot.”
    → “Te extraño mucho.” or “Te echo mucho de menos.”
    (Latin America: “te extraño”, Spain: “te echo de menos”. Pick one and stick with it.)
A couple places I’d actually push back a bit on what people usually say:
  • You don’t always need super short sentences. For a warm text, one medium sentence is totally fine:
    “Espero que estés bien y que tu semana vaya tranquilo.” sounds natural in casual chat.
  • “Ojalá” is great, but if you never use it in English, forcing it can sound too formal for very casual vibes. Sometimes just “espero” is enough.
If you want to double‑check your English before translating, tossing it through something like make your AI text sound more human can help clean up any stiff or robotic phrasing. When the English is natural and simple, the Spanish comes out way more natural too, and it’s easier for people here to polish it.
Drop your exact sentence and also say:
  • Is your friend from Spain or Latin America?
  • Do you want it flirty, just friendly, or very neutral?
Those two things change word choice a lot, so it’s hard to make it truly “native‑sounding” without that info.
Here’s a different angle from what @codecrafter already covered, focusing less on “ready‑made chunks” and more on tuning whatever Spanish you already have so it feels natural.
1. Start from what you wrote, not from scratch
Instead of tossing you generic templates, it helps if you paste your exact English and your attempt in Spanish. Then you get:
  • Tiny grammar fixes: verb tenses, accents, pronouns.
  • Tone tweaks: swapping “usted” for “tú,” softening anything that sounds too formal or dramatic.
  • Regional polish: “celular” vs “móvil,” “platicar” vs “charlar,” “ustedes” vs “vosotros.”
I slightly disagree with the idea that you always need fixed “chunks.” They are useful, but if you only copy patterns, you never learn why “te lo quería decir” feels warmer than “quería decirte esto” in a certain context. Seeing your own sentence corrected is way faster for learning.
2. Decide on three things before translating
These three flip your choices more than people expect:
  • Region: Spain vs Latin America vs “neutral.”
  • Formality: close friend, colleague, crush, family.
  • Vibe: caring, casual, or a bit emotional.
Examples of how the same idea shifts:
  • Caring & casual, Latin America:
    • “Oye, he estado pensando mucho en ti últimamente. Espero que estés bien.”
  • Neutral & non‑flirty, “universal” Spanish:
    • “Solo quería escribirte para saber cómo estás y desearte que todo vaya bien.”
3. Common “almost right” mistakes to avoid
You might not repeat @codecrafter’s ones, but these show up constantly:
  • “Estoy esperando que tú estás bien”
    • Natural: “Espero que estés bien.” (subjunctive, and drop unnecessary “tú” in most cases)
  • “Yo solo quería decir tú que…”
    • Natural: “Solo quería decirte que…” (clitic pronoun attached: decirte)
  • Overusing future tense:
    • “Te hablaré pronto” is technically fine, but a text often sounds softer as:
      • “Te escribo pronto.”
      • “Luego te cuento.”
      • “Ya te hablaré” (a bit more relaxed, especially in Latin America).
4. How to self‑check if it sounds native
Quick checklist you can run through yourself:
  • Pronouns: Could “yo” or “tú” be dropped without losing clarity? If yes, drop most of them.
  • Tense: For “I’ve been thinking about you,” use he estado pensando en ti, not estuve pensando unless it is a closed, past period.
  • Register: If you would never say “I hereby wish to inform you” in English, do not use “por la presente” or anything similarly stiff in Spanish.
5. Using tools without sounding robotic
If your English base text sounds stiff, the Spanish will usually sound worse. Tools like Clever AI Humanizer can be handy before translating:
  • You paste your English.
  • It smooths out robotic or overly formal phrasing.
  • You then translate that cleaner version.
Pros of Clever AI Humanizer
  • Good for stripping away awkward, AI‑like phrasing.
  • Helps you get to short, friendly sentences that are easier to render in Spanish.
  • Useful if English is not your first language and you want it to sound more natural.
Cons of Clever AI Humanizer
  • It improves style but does not understand Spanish grammar, so do not trust it for the translation itself.
  • Can sometimes oversimplify your tone, so emotional nuance may shrink.
  • If you just click “fix” and never look, you do not really learn anything.
I’d use something like Clever AI Humanizer to clean the English, then post:
  1. Original English.
  2. Humanized English.
  3. Your Spanish attempt.
  4. Friend’s region + desired vibe (friendly, neutral, flirty).
With that combo, people here can usually turn it into a very natural‑sounding message in one or two tweaks, often with explanations so you start recognizing the patterns yourself.
