I recently used Gamma AI for creating presentations and content, and I wrote up a detailed user review based on my experience. I’m not sure if my impressions are accurate or if I’m missing key features or better workflows. Can anyone familiar with Gamma AI review my experience, share pros and cons I might have overlooked, and suggest how to get more value out of the tool for business and productivity use cases?
Your impressions are probably fine. Gamma has a weird mix of smart features and missing basics, so a lot depends on what you tried.
A few things to sanity check against your review:
Content quality
• If you saw generic slides, try giving Gamma 2 to 3 clear bullets per slide in the prompt, not a big paragraph.
• For example:- Audience: SaaS founders
- Goal: pre-seed pitch
- Slides: problem, solution, traction, business model, roadmap, team
• If your review says “it repeats itself” or “feels fluffy”, that lines up with what many users see if they feed it vague text.
Structure and layout
• Gamma is strong at quick structure, weak at precise layout control.
• If you expected PowerPoint level positioning, your criticisim is fair.
• You get more value if you treat it as a “first draft generator”, then export and polish in PPT or Google Slides. -
Images and visuals
• The AI images look decent at a glance, but often do not match brand or tone.
• For a fair review, mention that custom branding works better if you upload brand colors and logos first.
• If you did not try that, you might be under-rating the visual side a bit. -
Collaboration and sharing
• Gamma links are good for async review, less good if your team lives inside Google Workspace or Office.
• If your review hits friction on export format or sharing in corporate environments, that is accurate. -
Workflow tips you might have missed
• Start from “docs” then convert to “presentation” for longer content. The outline is usually cleaner.
• Use shorter prompts, then refine slide by slide with the built-in AI rewrite instead of one huge prompt.
• Lock in structure first, design last. Gamma struggles if you keep redesigning while editing content. -
Pricing and value
• Honest point for a review is:- Great for fast internal decks, rough client drafts, one-off content.
- Less strong for final investor decks, tight brand decks, heavy data decks.
If you share your main pros and cons from the review, people can tell you where they agree or where workflow tweaks would change the experience. Right now, most “power users” treat Gamma as a fast outline and first-pass generator, not as a complete end-to-end slide tool.
If your review basically says “cool idea, kinda mid in practice unless you babysit it,” you’re probably more right than wrong.
Since @stellacadente already hit the workflow tips, I’ll poke at a few meta points you might want to sanity‑check in your writeup:
Were you judging it as:
- a PowerPoint replacement or
- a content generator that happens to output slides?
Your tone should match that expectation. If you expected full design control, harsh criticism is fair. If you framed it as “AI draft tool,” you should probably separate “content quality” from “design control” in your conclusions.
Did you test it on different types of decks?
For example:- Strategy / product vision
- Sales / pitch
- Training / explainer
Gamma tends to look better on high‑level conceptual decks, worse on detailed / data heavy / process‑dense stuff. If you only used one scenario, mention that limitation so readers know how generalizable your review is.
Brand & consistency
If your review says something like “visuals feel generic and samey,” that’s valid. But I’d make it explicit whether you:- uploaded brand kit (logo, colors, fonts)
- or just used defaults
Because those are two pretty different experiences. I actually think it’s still weaker than it should be on strict brand consistency even with a brand kit, so if that was your gripe, you’re not crazy.
AI behavior & control
A lot of reviews just say “the AI felt off” without being concrete. You’ll make your review way more useful if you call out specifics like:- Does it ignore constraints you give it?
- Does it hallucinate details you never asked for?
- Does it keep reintroducing stuff you deleted?
These are common annoyances and totally fair criticism. Here I slightly disagree with the “just use shorter prompts” advice as a cure‑all. Shorter prompts help, but Gamma should handle a well written long brief. If your review calls that out as a weakness, I’d keep it in.
Editing pain points
One thing a lot of users under‑criticize: how annoying is it to fix things after the AI generates them?- Is editing text & layout fast or fiddly?
- Do small changes break the layout?
- Does collaboration feel smooth or do you end up exporting to real slide tools anyway?
If your honest experience was “I kept fighting it and then gave up and exported,” write that verbatim. That’s super valuable context.
Outcome vs effort
Try to summarize your experience like this in your review:- “Time saved on first draft: X”
- “Time lost cleaning / fixing: Y”
- “Net: worth it / not worth it for [type of deck]”
Even if you estimate, that makes your review way more actionable than “felt slow” or “felt helpful.”
Missing features vs personal workflow gaps
Before you publish, scan your own cons list and tag them mentally:- “This is a real missing feature”
- “This is probably my workflow / expectations”
For example, not having fine‑grained layout control is a real limitation. Not discovering doc‑to‑deck conversion might be more of a “I didn’t dig deep” thing. You don’t have to hide that in the review; just be transparent: “I only used X and Y features, didn’t go deep on Z.”
If you post your pros/cons list, people can nitpick the edges, but your core impressions are almost certainly valid. Gamma is in that awkward middle zone right now: too smart to be a toy, not polished enough to be a full replacement. Your review should reflect that nuance rather than assuming you “missed something huge.”
