I recently started using Plaud Ai for my workflow, but I’m struggling to figure out the best way to set it up and integrate it with my existing tools. Some features are confusing, and I’m not sure if I’m missing important settings or using it wrong. Can someone explain how to get Plaud Ai working smoothly and share any tips or best practices to avoid common issues?
I had a similar “ok what now” phase with Plaud Ai, so here is what worked for me, step by step.
Start with one clear use case
Pick one thing you want from it. For example:
• Auto transcribe and summarize meetings
• Turn voice notes into tasks
Ignore the rest until that flow feels smooth. -
Set up inputs first
You want data going in before tweaking features.
Common setups:
• Connect calendar so it auto records specific meetings
– Only enable for meetings where you need notes
• Use the mobile app or hardware recorder for quick voice notes
• If you use Zoom, Meet, or Teams, turn on the integration so it joins calls or attaches to recordings -
Define output formats
Tell it what your “default” output should look like.
For example, for meetings:
• Bullet summary
• Decisions
• Action items with owners and due dates
For voice notes:
• Short summary
• Todo list
Save these as templates or presets if Plaud supports it in your version. It saves time and keeps things consistent. -
Integrate with your task and notes tools
Typical combos:
• Notion: send summaries into a specific database or page
• Todoist or ClickUp: send action items as tasks
• Slack: send recaps to a channel like #meeting-notes
Keep it simple at first. One notes destination and one task tool.
Test a full flow: record meeting, get notes, see tasks appear in your task app. -
Clean up the automations
Turn off anything noisy or confusing.
• Disable random auto syncs you do not need
• Limit what gets posted to Slack
• Make sure it does not record all calls by default if that feels chaotic
Your goal is “I know where everything goes” every time. -
Use prompts for clarity
In your recordings, say what you want at the start or end. Examples:
• “Plaud, summarize this as: key points, risks, and next steps.”
• “Turn this into tasks for Notion with deadlines and tags.”
This makes the output much closer to what you want. -
Weekly review
Once a week, check:
• Are meeting notes where you expect them
• Are action items landing in the right tool
• Are you reading the summaries or ignoring them
If you ignore them, shorten the summaries or change the structure. -
A few feature tips I wish I knew earlier
• Create different presets for “1:1”, “standup”, “brainstorm”, “client call”. Use them instead of one generic template.
• For long meetings, ask for a short executive summary plus a full transcript. Helps reduce noise.
• If the AI gets names or terms wrong, correct them a few times and add them to a glossary if there is one. Accuracy improves.
If you share your stack, like “I use X for tasks, Y for docs, Z for meetings”, people here can suggest a concrete wiring setup. Right now, a simple path like: Plaud → Notion for notes, Plaud → your task app for action items, works pretty reliably without much fuss.
You’re not missing anything “secret,” Plaud is just kinda messy until you tame it.
I mostly agree with @shizuka’s flow, but I’d actually start from the opposite direction: instead of “what can Plaud do,” ask “what do I want to stop doing manually this week?”
Examples:
- I don’t want to write meeting recap emails.
- I don’t want to dig through transcripts to find action items.
- I don’t want scattered voice notes in 5 different apps.
Then wire Plaud around those annoyances only. Ignore every feature that doesn’t reduce a specific pain.
A few practical things that helped me:
Turn off “magic” stuff first
Instead of enabling all integrations, I disabled almost everything and turned things on one by one.
If Plaud is randomly joining meetings, creating docs everywhere, or blasting Slack, your brain just stops trusting it. Start from zero, then add. -
Create a “trash zone” destination
Instead of sending outputs straight into Notion / task manager from day one, I route them into a single “Staging” place:
- One folder (e.g. “Plaud Inbox”)
- Or one Notion page / DB
Then I manually promote what’s useful and delete the rest. Once patterns stabilize, then I automate to the “real” places.
- Decide what you’ll never use it for
This sounds weird, but it clarifies things. For example:
- “No, I won’t use Plaud as my main note app.”
- “No, I won’t let it auto-create tasks without review.”
That stops you from chasing every shiny feature and makes the UI less overwhelming mentally.
- Be brutally specific with instructions
The default “summarize this meeting” is usually mid. I literally paste / reuse the same instruction a lot:
“Give me:
- 5–10 bullet summary
- Decisions with owners
- Only action items that start with a verb and have an owner + due date.”
This kind of narrow prompt fixes 80% of “confusing output” issues.
- Treat it like a junior assistant, not an oracle
I always assume:
- It will mis-label something.
- It will miss 1–2 tasks.
So I quickly scan and correct. Over time I use those corrections to refine templates and prompts. If you expect perfection, it’ll feel broken. If you expect “draft I can clean up in 2 minutes,” it feels like a win.
- Timebox your setup
Don’t fall into the “tweak settings for 3 hours” hole. Do this:
- 15 mins: connect only calendar + 1 notes app
- 1 real meeting: see what happens
- 10 mins: tweak template & what gets exported
Repeat that loop for a few days. The app makes way more sense when you’re looking at real mess from your meetings, not test stuff.
- Decide where “truth” lives
Big source of confusion: people let Plaud become a second brain accidentally. Pick:
- Tasks live in: X app
- Docs / knowledge live in: Y app
- Plaud is just: recording + transcription + initial structure
If you feel like “are my notes in Plaud or Notion or email,” that’s a config smell.
- When to not integrate
Hot take: you might not want deep integration at all at the start. For a week I literally:
- Let Plaud generate summaries
- Copied the useful parts into my real systems manually
Once I saw a repeatable pattern, then I wired in automations.
Manual first, automation second. Not the other way.
If you share:
- what you use for tasks,
- where you store notes,
- what meeting tools you’re on,
folks here can suggest a very specific wiring like “Plaud → X only for client calls, everything else ignored.”
Right now, if it feels confusing, that usually means it’s doing too much, in too many places, with outputs that are too generic. Trim scope, sharpen prompts, and only then flip on the “cool” features.
