Need help downloading the YouTube app on my device
I’m having trouble downloading the YouTube app on my phone, and I’m not sure if it’s a problem with my device, my account, or the app store itself. I’ve tried restarting, checking storage, and updating the OS, but the download still fails or gets stuck. Can someone explain possible reasons and step-by-step fixes so I can successfully install the YouTube app and get it working again?
First thing, figure out if this is Android or iPhone, because the fixes are a bit different. I will split them.
For both, since you already restarted and checked storage and OS, go through these:
  1. Check time and date
    Wrong time can break app store downloads.
    Set it to automatic time and automatic time zone.
  2. Check internet
    Try both Wi‑Fi and mobile data.
    Run a speed test in your browser. If pages load slow, app store will fail too.
  3. Check parental / content restrictions
    If your account or phone has age limits, YouTube might be blocked.
Now details.
ANDROID
  1. Check device and OS support
    Settings > About phone.
    Android needs to be 8.0 or higher for current YouTube versions.
    If it is older, Play Store might block it.
  2. Clear Play Store data
    Settings > Apps > Google Play Store
    Force stop
    Storage > Clear cache
    Then Clear data
    Do the same for Google Play Services.
    Reopen Play Store and try again.
  3. Remove and re add Google account
    Settings > Accounts > Google
    Remove your Google account
    Restart phone
    Add account again
    Open Play Store, accept terms, try YouTube.
  4. Check for disabled / old YouTube
    Settings > Apps
    Look for YouTube.
    If it is disabled, tap Enable.
    If it is a system app, there will be only an Update button in Play Store.
  5. Check Play Store country and restrictions
    Open Play Store
    Tap your profile picture > Settings > General > Account and device preferences
    See if there is a country mismatch or a warning.
    If you use VPN, turn it off.
IPHONE
  1. Check region and age
    Settings > Your name > Media & Purchases > View Account
    Make sure your country supports YouTube.
    Settings > Screen Time > Content & Privacy Restrictions
    Check App Store and App limits.
    Set Allowed Apps and age rating to allow 17+.
  2. Sign out and back into App Store
    Settings > Your name > Media & Purchases > Sign Out
    Restart iPhone
    Sign back in
    Open App Store and search for “YouTube” again.
  3. Check payment info
    Sometimes App Store blocks installs if billing has an issue, even on free apps.
    Settings > Your name > Payment & Shipping
    Fix expired cards or address issues.
  4. Check iOS version support
    YouTube supports only newer iOS versions.
    Settings > General > About
    If your iOS is too old for the current app, App Store might say “not compatible” or fail.
    In that case, you need an older IPA only if you had YouTube installed before on the same Apple ID.
IF NONE OF THIS WORKS
Try this quick test list and note what happens:
  1. Can you download any other large app, like Instagram or TikTok
    If no, it is a store or network issue.
    If yes, issue is specific to YouTube.
  2. Exact error message or behavior
    Example
    • “Download pending” forever
    • “Error code xxx”
    • “Not enough space” even when you freed space
    • Install button does nothing
Post your phone model, OS version, app store (Play Store, Galaxy Store, App Store, Huawei AppGallery), and the exact error text. With that, people here can pinpoint the issue instead of guessing.
Couple of extra angles you can try that weren’t really covered by @yozora:
1. Check if it’s actually an install problem or a visibility problem
Sometimes YouTube is already on the phone but hidden or tied to a different profile.
On Android:
  • Go to Settings → Apps → See all apps
  • Tap the 3 dots → Show system apps
  • Look for YouTube or com.google.android.youtube
    • If you see it:
      • Tap it → if there’s an Enable button, hit that
      • If it says Uninstall updates, that means YouTube is a system app and you’re basically just updating it via Play Store, not installing it fresh
  • Also check Settings → Users & accounts / Multiple users / Work profile. If you have a work profile, YouTube can be blocked there while still available on your personal profile.
On iPhone:
  • Swipe down and use Search for “YouTube”
  • If it shows in search but not on the home screen, it might be:
    • In the App Library only
    • Hidden in a folder
  • Go to Settings → Screen Time → Content & Privacy Restrictions → Allowed Apps and see if YouTube is toggled off there.
2. Check for device / vendor store conflicts
Especially if this is a Samsung, Huawei, Xiaomi, etc.
  • If you first tried to grab YouTube from a non Google store (Galaxy Store, AppGallery, some vendor store), it can leave behind half installed junk.
  • Try:
    • Go into that vendor store
    • Search YouTube
    • If it shows as Installed or Update but doesn’t actually open, tap Uninstall from there
    • Then switch to Google Play Store / App Store and try again
On Huawei without Google services: official YouTube from Play Store will not work at all. You’d have to use YouTube in browser or YouTube Vanced / ReVanced style clients, but those are unofficial and come with their own risks.
3. Look for security or “device health” apps blocking it
Antivirus / security / “phone optimizer” apps love to overstep.
Check if you have:
  • Norton, McAfee, Avast, Kaspersky, etc
  • Or built-in apps like “Security,” “Device Care,” “Phone Manager”
Open those and look for:
  • App lock, App blocking, Network firewall, or Child protection / Kids mode
    YouTube is a common target for these restrictions. Temporarily turn them off and retry the install.
4. Check if your account itself is the bottleneck
Not the app store account, but:
Under 13 or under family group rules:
  • If your Google / Apple account is part of a Family with parental control, YouTube may be blocked specifically.
  • Ask the family organizer to:
    • On Google: review Family Link settings and see if YouTube is allowed
    • On Apple: Settings → Family → [your account] → Ask to Buy / App limits
Sometimes YouTube is blocked while other social apps are allowed, which makes it weird because everything else downloads fine.
5. Network-level blocking that only hits YouTube
YouTube is often blocked at the router or DNS level.
Try these tests:
  1. Turn Wi Fi off, use mobile data only, then try to install.
  2. If that works, your Wi Fi router or DNS is probably blocking YouTube or Google video domains.
  3. On Wi Fi, change DNS:
    • Android: Wi Fi → your network → Advanced → IP settings → Static / Private DNS and use something like 1.1.1.1 or 8.8.8.8
    • iPhone: Wi Fi → (i) on your network → Configure DNS → Manual → add 8.8.8.8 / 1.1.1.1
If your ISP or school network blocks it, there is nothing “wrong” with your phone.
6. When the store button does literally nothing
This is a weird one but happens a lot:
Android:
  • Long press Play Store → tap App info
  • Make sure Install unknown apps is OFF for Play Store, but Special app access → Install unknown apps is not blocking other system pieces
  • Also check Settings → Developer options (if enabled)
    • Disable Don’t keep activities
    • Make sure Background process limit is set to standard
iPhone:
  • If tapping “Get” or the cloud icon does nothing and there’s no error:
    • Toggle Settings → Screen Time → Content & Privacy Restrictions OFF completely
    • Force close App Store, reopen, retry
@yozora suggested Screen Time checks already, but I’ve seen installs silently do nothing until Screen Time is fully turned off, not just “adjusted,” so I’d actually go a bit harder here and just disable it temporarily to test.
7. If you want targeted help, post these details
If you can, reply back with:
  • Phone model (ex: Galaxy A52, iPhone 8, etc)
  • Exact OS version
  • Which store you’re using
  • What exactly happens:
    • Progress bar then error?
    • “Pending” forever?
    • Tap button and literally nothing?
    • Or it looks like it installs but no icon appears?
Right now you’ve already done the obvious stuff (restart, storage, OS update) and @yozora hit most of the general fixes, so the next step is usually finding out if it’s:
  • A restriction (account / Screen Time / Family / work profile)
  • A vendor store conflict
  • A network / DNS / router filter
  • Or just too old hardware / OS pretending it’s fine when it is not.
Skip the repeats from @viajeroceleste and @yozora for a sec and treat this like a deeper diagnostics pass.
1. Figure out when the download fails
Different stage = different cause:
  • You never see a progress circle at all
  • It starts, shows a tiny bit of progress, then stops
  • It finishes, but YouTube never appears on the home screen / app drawer
  • YouTube appears, but tapping it instantly crashes
Each points somewhere else:
  • No progress: account, payment, or restriction issue
  • Partial progress: network throttling, storage corruption, or cache issue
  • Installs but no icon: launcher / profile / restriction glitch
  • Crashes: app binary or OS compatibility
Try again and note exactly which of those happens. That detail matters more than most people think.
2. Check your account trust level, not just age / region
Both replies covered parental controls, but there is another annoying angle:
Google / Apple sometimes quietly “degrade” an account when:
  • You changed country several times in a short period
  • You had multiple failed payment attempts
  • You used VPNs heavily with your store account
On Android:
  1. Open Play Store
  2. Profile icon → Payments & subscriptions → Payment methods
  3. Remove old cards, add one valid method (even if YouTube is free)
  4. Try installing any random free app from Google LLC first (like Google Photos)
  5. Once that works, try YouTube
On iOS:
  1. Settings → Your name → Media & Purchases → View Account
  2. Fix any payment warning or billing address error
  3. Install a free Apple app first (like Pages or iMovie)
  4. Then search for YouTube again
If your store silently “does nothing” when you tap Install / Get, this is weirdly common.
I slightly disagree with the idea that payment issues “sometimes” affect free apps: in practice, I see it happen a lot, especially on iOS.
3. Rule out profile / launcher issues
The others hinted at YouTube being hidden, but there is a subtler version:
Android:
  • If you use a custom launcher (Nova, Microsoft Launcher, etc.), switch back to the default:
    • Settings → Apps → Default apps → Home app
    • Pick the system launcher
  • Log out of any “guest” or “secondary” user:
    • Settings → System → Multiple users or Users & accounts
    • Make sure you are on the main user
Sometimes an install lands only on the owner profile, but you are on a guest profile where it is invisible and blocked.
iPhone:
  • Go to Settings → Home Screen
    • Set new app downloads to “Add to Home Screen,” not “App Library only”
  • After installing YouTube, swipe to the very last page to open App Library, search “YouTube” there. If it shows, long press → Add to Home Screen
If you see it in App Library but not on home screens, your install is fine and the “problem” is really just icon visibility.
4. Storage integrity, not just “space available”
You already checked that you have enough GB free, but sometimes the storage has corrupted blocks.
Android idea:
  1. Install any other large video app (Netflix, Prime Video, Twitch)
  2. If all of them fail partway, especially around the same size, your storage might be failing
  3. Move some photos / videos to cloud or external storage, then run:
    • Settings → Battery & device care (or similar) → Storage → Optimize / Check
  4. If possible, run the phone in Safe Mode:
    • Long press power → long press “Power off” → Safe Mode
    • Try installing YouTube from Play Store there
    • If it works only in Safe Mode, a third party app is interfering
iPhone:
If any big app install or update behaves the same way, try:
  • Settings → General → iPhone Storage
  • If “System Data” looks absurdly big, or storage bar looks wrong, you might be looking at a restore-from-backup scenario:
    • Backup to iCloud or computer
    • Settings → General → Transfer or Reset iPhone → Erase All Content and Settings
    • Restore and retest
That is extreme, but if multiple apps fail the same way, it is sometimes the only clean fix.
5. Look for very specific YouTube-related blocks
YouTube is a frequent target for focused blocking, separate from other apps.
  1. Check any “Digital wellbeing” / “Focus” / “Kids mode” feature:
    • Android: Settings → Digital Wellbeing or “Wellbeing & parental controls”
    • Turn off any app timer or bedtime mode that lists YouTube
  2. Check your router or home security system:
    • If YouTube is blocked only on your home Wi Fi but fine on mobile data, the router might be filtering video / social media.
    • In that case, installs can hang or silently fail because the device cannot reach all required YouTube services.
I lean more toward router / DNS filters than VPN issues in real-world cases, especially if other streaming apps act odd too.
6. Compatibility edge cases nobody likes to talk about
Both earlier answers touched OS version, but there are some in-between problems:
Android:
  • Devices that are technically on Android 8+ but running heavily customized or de-Googled firmware
  • Phones that used to have Play Store but were re-flashed with vendor ROMs
If you are on a Huawei without official Google services, or a very niche brand, you might see YouTube listed but the download always fails or errors out. In that case:
  • Your realistic options are:
    • Use YouTube in a browser
    • Use a competitor app like YouTube Go if still available in your region
    • Or third-party clients, which come with security and stability tradeoffs
iPhone:
  • If you are on something like iOS 12 on older hardware, YouTube might say “Requires iOS X or later” and not offer an older build unless you had it on that Apple ID in the past.
  • If you did have it years ago, try:
    • App Store → Profile icon → Purchased → search YouTube there
    • Install from Purchases, not from search
7. What to post next for more targeted help
To narrow this down without more guesswork, share:
  • Phone model and exact OS version
  • Store used (Play Store, App Store, Galaxy Store, etc.)
  • Exact behavior when you hit Install / Get (see section 1)
  • Whether other big apps install correctly
@viajeroceleste gave you a very methodical checklist, and @yozora added a bunch of edge cases like work profiles and Screen Time conflicts. Building on top of that, the next steps are really about:
  • Identifying the exact failure stage
  • Checking account trust, not just age/region
  • Verifying launcher/profile and storage integrity issues
  • Confirming whether YouTube is individually blocked at network or parental level
Once you drop those specifics, people can usually point to a very specific cause instead of another round of generic “clear cache and reboot.”
Covered so far: pinpoint failure stage. Fix account trust and billing. Check profiles and launcher. Validate storage health. Look for YouTube specific blocks. Note OS and device compatibility. Share your model, OS, store, exact behavior, other installs.
Simpler path to try now. Do a time sync reset. Wrong clock breaks store TLS, installs stall. 5 to 10 minutes off blocks installs.
Steps. Settings, Date and time, use network time. Toggle off then on. Set correct time zone. Reboot. Try mobile data once. Open store, search YouTube, tap Install. Report back if teh time skew was the culprit.
