Need help comparing paired app reviews
I’m trying to analyze paired app reviews across iOS and Android to see how user feedback differs between the two platforms. I’m not sure what tools, methods, or metrics I should use to compare ratings, keywords, and sentiment in a meaningful way. Can anyone suggest a practical approach, or share how you’ve done cross-platform app review analysis for better ASO and product decisions?
Short version. Treat this like a small data project with 3 tracks: ratings, text, and themes over time.
Here is a concrete way to do it.
  1. Get and align the data
    • Export reviews for both stores
  • iOS: App Store Connect or AppFigures / AppFollow / AppTweak
  • Android: Google Play Console or same third party tools
    • For “paired” reviews, define a key
  • By app version
  • By country
  • By date bucket (day or week)
    You compare iOS vs Android per bucket, not per single user, since the user IDs do not match.
  1. Ratings comparison
    • Metrics to track by platform and by version or week
  • Mean rating
  • Median rating
  • Rating distribution (percent 1–5 stars)
  • Review volume per day
    • Simple stats
  • Difference in mean rating (iOS minus Android) per version
  • t test or Mann Whitney test for significance if you have enough reviews
    • Practical view
  • Plot 2 lines: avg rating per week for iOS and Android
  • Add app version markers, see where they diverge
  1. Text preprocessing
    Use Python if you are comfortable. Rough workflow:
• Clean text
  • Lowercase
  • Remove URLs, emojis if you want, punctuation
  • Remove stopwords (the, and, etc)
    • Tokenize
  • spaCy or NLTK
    • Language detection if you have multi language reviews and filter to one language first.
  1. Keyword and topic comparison
    Approaches:
A) Simple frequency and TF-IDF
• Build two corpora
  • All iOS reviews
  • All Android reviews
    • For each corpus
  • Top unigrams and bigrams
    • Then compare
  • Words overrepresented on iOS vs Android
  • Use log-odds ratio or chi square to see which terms differ by platform
    Example result:
  • Android overindexes on “crash”, “won’t open”, “battery”
  • iOS overindexes on “subscription”, “price”, “widget”
B) Topic modeling
• Use LDA or better, BERTopic (Python) separately on iOS and Android
• Label topics manually, like
  • “Login issues”
  • “Performance”
  • “Feature requests”
    • Compare topic share
  • Percent of reviews per topic per platform
    Example:
  • Android: 30% “crash / performance” vs iOS: 10%
  • iOS: 25% “UI / navigation” vs Android: 12%
  1. Sentiment analysis
    • Tools
  • VADER, TextBlob, or transformer models (e.g. “nlptown/bert-base-multilingual-uncased-sentiment”)
    • For each review
  • Get sentiment score or sentiment class (negative, neutral, positive)
    • Metrics per platform
  • Average sentiment per period
  • Sentiment distribution
  • Sentiment by topic
    Useful combo: 1–5 rating vs sentiment.
  • 4–5 stars with negative sentiment text often means “good app but one huge pain”. Compare where this happens more, iOS or Android.
  1. Paired by version and feature
    To see differences around specific changes:
• Tag each review with app version and release date
• For each release
  • Before vs after rating shift per platform
  • Before vs after sentiment shift
  • Top new keywords after release
    Example:
  • New feature hits first on Android. Look for “new update”, “latest update”, “after update” in Android reviews and see keywords.
  1. Visualization ideas
    • Line charts
  • Average rating over time, one line per platform
  • Sentiment score over time
    • Stacked bars
  • Rating distribution by platform
  • Topic distribution by platform
    • Word clouds or bar charts
  • Separate for iOS and Android top complaint keywords
  1. Tools that help without too much coding
    • AppFollow, AppFigures, AppRadar, AppTweak
  • They do sentiment, topics, filters by store and version
    • Low code stack
  • Export CSV
  • Clean with Python or R
  • Visualize in Looker Studio, Power BI, Tableau
  1. Practical steps to start this week
    Day 1
  • Export 6–12 months of reviews from both stores to CSV
  • Normalize fields: date, rating, text, country, version
Day 2
  • Compute basic rating metrics and plots by platform and version
  • Simple keyword counts (top 50 terms each)
Day 3
  • Run sentiment model and plot sentiment vs rating, per platform
  • Start topic model or manual tag a sample of reviews
Day 4
  • Compare platforms by: rating, sentiment, top topics, top overindexed words
  • Write 3–5 key differences like
    “Android users complain more about crashes”
    “iOS users mention price more”
If you share a small anonymized sample later, like 100 reviews per platform as CSV, people on the forum can help you tweak metrics or code.
Couple of extra angles you can layer on top of what @kakeru already outlined, especially if you want “paired” in a more product/UX sense rather than pure data science.
  1. Define questions before metrics
    Instead of starting from “what tools,” start from 3–5 concrete hypotheses like:
  • “Android users hit more fatal errors than iOS users.”
  • “iOS users care more about polish than stability.”
  • “Paying users are angrier on iOS.”
Then pick metrics that exist only to accept/reject those. Otherwise you’ll drown in charts.
  1. Use cohorts instead of just time buckets
    Paired by “calendar week” is ok, but often misleading if your release cadence is different. Try:
  • Install cohort: group users by install month, compare iOS vs Android within the same install month.
  • First‑review cohort: bucket by “days since install” if you can join to analytics, so you compare early‑life feedback on both platforms.
This is more actionable for onboarding / first‑run experience issues.
  1. Join with product analytics (if you can)
    Most people stop at text + star ratings. If your analytics stack lets you, create very simple joins:
  • For each review, attach: last session platform, number of sessions, subscription status, last feature used.
    Then you can ask:
  • “Among users who used Feature X last, what % of negative reviews come from Android vs iOS?”
  • “Are low ratings on Android mostly from low‑engagement users, while iOS rants come from power users?”
This matters a lot when deciding what to prioritize.
  1. Don’t fully trust sentiment classifiers
    This is where I slightly disagree with the heavy focus on sentiment tools. For app reviews specifically, a cheap model will misread stuff like:
  • “Love the app BUT since the last update it crashes every time”
    as overall positive.
What’s worked better for me:
  • Use sentiment only as a coarse filter (very negative vs everything else).
  • Then run very targeted pattern / keyword rules on that negative set: crash|freeze|won't open|stuck, price|expensive|subscription, slow|lag|performance, etc.
    You end up with “problem buckets” that are more precise than generic sentiment scores.
  1. Build a simple “pain index” per platform
    Instead of just mean stars, create a composite metric like:
Pain index = (% 1–2 star reviews) + (freq of critical error keywords) + (share of reviews mentioning ‘can’t use’, ‘unusable’, ‘won’t open’)
Compute that separately for iOS and Android by version or week.
Sometimes you’ll see both platforms have similar average rating, but Android has a much higher pain index which surfaces “hard blockers” faster.
  1. Compare mismatch between text and stars
    One surprisingly useful slice:
  • 4–5 stars with clearly negative text.
  • 1–2 stars with mostly positive text.
Do this per platform:
  • If Android has more “5 stars, angry text,” you may be seeing cultural or UX differences in how users use the star widget, which means raw ratings are less trustworthy there.
  • Also run this around big releases to see if one platform’s users are more “forgiving.”
  1. Manual coding on a small sample
    Before you go all in with LDA / BERTopic etc, grab 200 reviews per platform and just tag them by hand:
  • “crash / bug”
  • “feature request”
  • “payment / price”
  • “UX / confusion”
  • “praise / nothing actionable”
Then compare distributions. This gives you:
  • A sanity check for any model you use later.
  • A shared taxonomy you can use with PMs and engineers so your charts aren’t “Topic 1 vs Topic 2” but “Login failures vs Performance vs Billing.”
  1. Platform‑specific expectation gaps
    One subtle thing to look at: what people expect each platform to do. To see this, run a quick comparison on phrases like:
  • iOS: “widget”, “lock screen”, “sync with Mac”, “iCloud”
  • Android: “battery”, “background”, “SD card”, “default app”, “notifications”
Rather than just counting them, read 20–30 reviews per phrase per platform and answer:
  • Are iOS folks mad because something looks “un‑Apple‑like”?
  • Are Android folks mad because something doesn’t behave like a “good Android citizen” (battery, background limits, permissions)?
That often leads to platform‑specific UX work that generic topic models will blur together.
  1. Prioritization view for the team
    At the end, don’t just dump metrics. Try to summarize as:
For each platform:
  • Top 3 engineering problems (e.g., crashes on X device, login fails with SSO)
  • Top 3 UX or “expectation” problems (e.g., navigation weird on Android tablets, iOS paywall too aggressive)
  • Any “only on iOS” or “only on Android” patterns that are clearly distinct.
If you can, attach a rough magnitude like:
  • “Affects ~18% of recent Android reviews, mostly 1–2 star”
  • “Shows up mainly in iOS US store over the last 2 releases”
That translation layer is the part most tools don’t do for you.
If you want a super barebones stack to get started without repeating what @kakeru already detailed:
  • Pull CSVs, dump into a notebook.
  • Manually tag 200 + build that taxonomy.
  • Build the pain index and mismatch metrics.
  • Do one pass of reading for “platform‑expectation” issues.
You’ll get a surprisingly clear iOS vs Android story even before you touch fancy topic models.
Treat this as an alignment problem more than an NLP problem: your goal is to make iOS and Android as comparable as possible before you even touch models.
1. Tighten what “paired” means
Instead of only pairing by time/version like @kakeru suggested, try a 2D pairing:
  • Axis 1: release context
    • Version groupings like “post major UI change,” “pre‑subscription rollout,” etc.
  • Axis 2: market slice
    • Country or region
    • Possibly language
You then compare “US, English, post‑paywall” iOS vs Android as a pair, “Germany, English, pre‑redesign” as another, and so on. This avoids the trap where Android has a very different country mix that distorts everything.
I slightly disagree with leaning too hard on calendar buckets alone; markets and release themes often explain more variance than weeks.
2. Normalize rating behavior across platforms
Star ratings are not directly comparable between stores. To make them closer:
  • Convert raw stars to z‑scores or percentiles per platform and region.
    Example: 3 stars on Android Brazil might be “average,” while 3 stars on iOS US might be “below average.”
  • Create relative metrics, like “distance from store‑wide average”:
    • delta_rating = review_star - mean_star(platform, country, month)
Then compare distributions of delta_rating between iOS and Android. This reduces cultural and platform bias a bit.
3. Replace generic sentiment with impact-weighted signals
I agree with @sternenwanderer that vanilla sentiment often misfires on app reviews, but instead of mostly ignoring it, you can repurpose it:
  • Use sentiment as a weight, not a label.
    • Strongly negative text gets higher weight when counting complaint keywords.
  • Build impact scores per review:
    • impact = neg_sentiment_score * (5 - star_rating)
      Now keywords and topics are ranked by impact difference between iOS and Android, not just frequency.
This is useful when you want to focus on pain that both hurts emotionally and drags ratings.
4. Platform-specific “acceptable pain” threshold
Compare:
  • Fraction of users that report a bug but still give 4–5 stars.
  • Fraction that report minor annoyances and give 1–2 stars.
Do this per platform and region. That gives you a sense of:
  • Where users are more tolerant (“I love the app, crashes sometimes, still 5 stars”).
  • Where they are more punitive.
This matters because identical crash rates can yield very different public ratings. It also helps you calibrate internal KPIs: maybe Android requires a lower bug rate to avoid visible damage.
5. Use “paired reading” instead of only paired metrics
After your quant pass, pick 2 or 3 matched slices like:
  • “After last major release, US, English, 1–2 star reviews, last 30 days.”
    • One set from iOS
    • One from Android
Then literally read 50–100 from each side in alternating order, writing down:
  • Unique Android complaints (permissions, background behavior, OEM quirks)
  • Unique iOS complaints (ecosystem integration, gestures, platform conventions)
  • Shared complaints where severity language differs
This crossreading shows expectation gaps that topic models blur together. It also produces concrete quotes that product teams absorb better than charts.
6. Translate all of this into a simple internal framework
To avoid drowning your team, collapse everything into a 2×3 grid:
Engineering issues UX / expectation issues Business / monetization
iOS
Android
Under each cell, list 2–3 items like:
  • “Crashes on specific OEM devices, high Android impact score, 16% of recent negative reviews.”
  • “On iOS, navigation feels ‘un‑Apple‑like’, moderate impact, clustered in last redesign.”
This is where your comparison actually becomes decision-ready.
7. On tools & “”
If you are looking for something like ‘’, treat it as a layer on top of your exports, not as a magic solution:
  • Centralizes reviews from both platforms in one interface
  • Often provides built‑in filters by country, version, and date
  • Can give quick charts for rating trends and keyword frequencies
  • Out‑of‑the‑box sentiment and topics are generic and not tuned to your app
  • “Paired” analysis across iOS and Android usually needs your own logic in a notebook
  • Can encourage dashboard‑gazing instead of the kind of structured, hypothesis‑driven work that @sternenwanderer and @kakeru outlined
Compared to what @kakeru described, ‘’ is more UI centric than analysis centric. Compared to @sternenwanderer’s more product‑driven framing, it is better at getting you raw visibility than at answering nuanced “why” questions.
Use ‘’ for quick exploration and filtering. Use your own code and the frameworks above when you want trustworthy, platform‑vs‑platform insights.
