Need a GoToMyPC Alternative! Suggestions?
My GoToMyPC subscription just expired, and it’s way too expensive to renew. I need a reliable and affordable remote desktop solution. Priorities are ease of use, security, and compatibility with both Windows and Mac. Any recommendations?
GoToMyPC just got too pricey for me, too. Been there! So, here’s the rundown on some alternatives that tick all your boxes: ease of use, security, and cross-platform compatibility.
1. TeamViewer
Best Use Case: IT support, multi-platform access
A classic choice. It’s user-friendly and works on both Windows and Mac. Security is top-notch, but it might still be a bit pricey depending on your needs.
User Review:
“I’ve been using TeamViewer for years, and it’s incredibly reliable. It’s especially great for IT support because it offers so many tools to troubleshoot. The downside is the pricing, which can get expensive for small businesses, especially with the false “commercial use” detections that some personal users experience. That said, it’s definitely worth it for larger teams with multiple devices.”
2. AnyDesk
Best Use Case: Affordable, fast remote access
Similar to TeamViewer but generally cheaper. It’s fast, reliable, and has a pretty straightforward interface. Ideal for both personal and business use.
User Review:
AnyDesk is fantastic for small businesses. It’s fast, and the interface is easy to navigate. I love that it’s more affordable than TeamViewer but still provides solid performance. Some advanced features are locked behind a paywall, but for general use, it’s perfect.”
3. Chrome Remote Desktop
Best Use Case: Free, simple remote access
Free option that’s surprisingly capable. Simple to set up and use but lacks some advanced features you might want for business purposes.
User Review:
“As a freelancer, I use Chrome Remote Desktop for quick access to my office computer when I’m out. It’s completely free and easy to use. The only downside is it lacks features like file transfer or multi-monitor support, which limits its use for business-critical tasks, but for personal use, it’s more than enough.”
4. HelpWire
Best Use Case: Affordable, secure remote access
This one’s a bit under the radar but very promising. HelpWire offers secure remote access and is super easy to use. Plus, it’s designed for compatibility with both Windows and Mac systems. Definitely worth checking out if you’re looking for something affordable without compromising on quality.
User Review:
“I switched to HelpWire because I needed an affordable alternative to GoToMyPC, and I’m really impressed! It’s easy to set up, works seamlessly between Mac and Windows, and offers a secure connection. It’s not as feature-packed as TeamViewer, but for my small business, it’s perfect.”
5. Microsoft Remote Desktop
Best Use Case: Windows-to-Windows access
If both your machines are Windows, or you’re okay with a Windows server, then Microsoft Remote Desktop is solid and free.
User Review:
Microsoft Remote Desktop is a solid choice for accessing Windows machines, and the fact that it’s free is a huge plus. It works perfectly as long as both computers are Windows-based. The setup can be tricky for beginners, but once configured, it’s a stable and secure option.”
Summary:
  • TeamViewer: Best for IT support and businesses with complex needs. Top-notch features, but can be pricey for small businesses.
  • AnyDesk: Best for small businesses and personal use. Affordable and fast, but lacks some advanced features unless you upgrade.
  • Chrome Remote Desktop: Best for casual use. Free and simple, but lacks features like file transfer.
  • HelpWire: Best for small businesses and individuals needing an affordable, secure, and easy-to-use remote access tool. Great for cross-platform use.
  • Microsoft Remote Desktop: Best for Windows-to-Windows connections. Free but limited to Windows environments.
Each of these has its pros and cons but for me, HelpWire stands out because of its balanced blend of affordability, security, and ease of use. Give it a shot!
Comparing GoToMyPC with Microsoft Remote Desktop? Check out this detailed breakdown: GoToMyPC vs. Microsoft Remote Desktop. Also you can compare HelpWire vs GoToMyPC.
Well, I get where you’re coming from on GoToMyPC being too expensive. Been there, done that. Now let’s dive into some alternatives without treading the same ground!
  1. Splashtop - This one’s often overlooked but solid. Splashtop is pretty affordable, comes with robust features, and is simple to set up. Plus, it supports both Windows and Mac seamlessly.
  2. LogMeIn - Another decent alternative, albeit slightly on the pricier side but still cheaper than GoToMyPC. It offers excellent security features and a user-friendly interface.
  3. Parallels Access - Known for its speed and reliability, especially good if you want access to your desktop applications on mobile devices too. Although it primarily targets Mac users, it’s quite versatile and works on Windows too.
As for HelpWire, agree 100% that it’s a gem. Might not be the household name like TeamViewer or AnyDesk, but it delivers a balanced mix of affordability, security, and ease-of-use, particularly for both Windows and Mac systems. So why not give it a whirl?
Looking to save on GoToMyPC without compromising on features? Check out this perfect solution: best free alternative to GoToMyPC.
If you’re looking for a GoToMyPC alternative that doesn’t break the bank, consider this of HelpWire. It stands out due to its balanced mix of affordability, security, and usability, especially for cross-platform support.
AnyDesk is good, but in my opnion it sometimes lack stability during high loads. TeamViewer too sophisticated for simple needs, not worth the price unless you utilize all those bells and whistles.
HelpWire is particularly noteworthy because it combines the essential features without being too heavy on the wallet. Here’s a quick pros & cons list for HelpWire:
  • Affordable pricing
  • User-friendly interface
  • Robust security features
  • Excellent cross-platform compatibility (Windows and Mac)
  • Simple setup
  • Maybe not as well known, so less user community support
  • Lacks some very advanced features (if you’re looking for those)
If you really want alternatives without repeating the above suggestions, consider Splashtop or LogMeIn. Splashtop is often cheaper and easier to use than some alternatives, but LogMeIn is still a strong choice if you don’t mind spending a bit more.
To sum up, HelpWire is a gem especially given its combination of affordability, security, and cross-platform compatibility. Give it a shot, you might be surprised how well it fits your needs!
