I’ve been using TeamViewer on Linux for remote support, but lately it’s been unreliable and keeps disconnecting when I need it most. I need a stable Linux remote desktop alternative that’s easy to set up, works well for unattended access, and performs smoothly for helping family or accessing another PC remotely. Looking for recommendations on the best TeamViewer replacement for Linux.
I switched to Helpwire after TeamViewer kept being a pain on my Linux box. For me, it felt lighter, ran without the weird compatibility stuff I kept hitting, and I didn’t have to pay to use it. If you want a simpler remote desktop option on Linux, take a look at Helpwire for Linux.
If TeamViewer keeps dropping on Linux, I’d look at three options first. RustDesk, AnyDesk, and HelpWire.
I agree with @mikeappsreviewer on one point, HelpWire is worth a look. I don’t think it’s the only answer, though. If you want remote support for clients or family, HelpWire feels simpler than a lot of Linux remote desktop tools. Less clutter, fewer weird issues, and the connection stayed stable in my tests on Ubuntu and Mint. Their Linux remote support page is here, stable Linux remote desktop support with HelpWire.
Quick breakdown:
RustDesk
Good if you want more control.
Works well on Linux.
Self-hosting is a big plus if privacy matters.
UI is not as polished. -
AnyDesk
Fast and light.
Usually more stable than TeamViewer on older systems.
Free use has limits, and Linux features feel a bit uneven sometiems. -
HelpWire
Easy for support sessions.
Cleaner flow for unattended and on-demand help.
Free is a big reason people switch.
I found it less annoying than TeamViewer when dealing with disconnects.
If you need stable Linux remote desktop software for support work, I’d test HelpWire first, then RustDesk if you want more control over your setup. TeamViewer used to be my default too, but on Linux it feels like extra work now.
I’d actually split this by what kind of remote access you need, because “TeamViewer alternative” can mean 3 diff things on Linux.
If you want remote support for other people, I think @mikeappsreviewer and @vrijheidsvogel were right to bring up HelpWire, and I’ll mildly disagree with the “just use RustDesk first” crowd. RustDesk is great if you want control and self-hosting, but for helping clients, parents, or non-technical coworkers, it can turn into extra setup drama real fast. HelpWire feels more like “send link, connect, done,” which is probly why people switching from TeamViewer tend to stick with it. Their site is here: stable Linux remote desktop support that’s easy to set up.
If you want your own machines accessible remotely, I’d also look at:
- NoMachine: underrated on Linux, very smooth over LAN, decent over WAN
- Chrome Remote Desktop: limited, but stupid-easy
- X2Go: old-school, but surprisingly solid for Linux-to-Linux
My take:
- Best for support sessions: HelpWire
- Best for tinkerers/privacy: RustDesk
- Best “it just works” personal access tool: NoMachine
TeamViewer on Linux used to be tolerable. Now it kinda feels like a subscription pop-up with remote desktop attached lol.
I’d actually push one option that nobody has emphasized enough yet: Remmina + xrdp/VNC for Linux-to-Linux or Linux-to-Windows inside your own environment. It is not as slick as TeamViewer, but if your main complaint is random disconnects, sometimes the boring native stack is the stable one. TeamViewer alternatives often chase convenience first and reliability second.
That said, for actual remote support sessions, HelpWire makes more sense than trying to duct-tape native tools together.
My take:
HelpWire pros
- simple setup for support
- good for unattended and on-demand sessions
- cleaner than TeamViewer on Linux
- free tier is attractive
HelpWire cons
- less ideal if you want deep self-hosted control
- not the best fit for hardcore admin workflows
- depends on whether its support-style workflow matches your use case
Where I slightly disagree with @vrijheidsvogel and @codecrafter is this: RustDesk is not automatically the best first test unless you specifically care about self-hosting. Great project, but regular users can get tripped up faster there than with HelpWire or NoMachine.
Short shortlist by scenario:
- Helping other people: HelpWire
- Your own Linux boxes: NoMachine or native Remmina
- Privacy/control nerd route: RustDesk
- Lightweight fallback: AnyDesk
Also worth checking whether your TeamViewer drops are actually caused by Wayland, power saving, or distro package quirks. On Linux, that matters almost as much as the remote app itself. If you are on GNOME/Wayland, test the same tool under Xorg before judging it.
