Is there a fully cross-platform USB over network app?
Looking for a USB over network solution that works seamlessly across Windows, macOS, and Linux. I’ve tried a few tools but ran into compatibility issues or limited features on some platforms. Has anyone found a software that truly works everywhere? Need this for sharing USB devices between different systems in my home office.
I needed to rope in a scanner hooked to a Windows PC, a test phone on Android, and a MacBook running some legacy hardware that had to play nice with everything else. Local KVM switches weren’t cutting it.
Ended up using USB Network Gate. Wasn’t my first pick (I went through at least three trials before), but it’s the only thing that let me share an Android test device, work with physical dongles on a Mac, and access random Linux gadgets from my trusty Windows desktop without a dozen cables.
  • Supported OS: Windows, MacOS, Linux, Android (yes, seriously—all four)
  • Setup: Download, click, connect. No secret handshakes.
  • Primary perk: Remote access to any plugged-in USB gadget wherever you are in the office (or beyond)
  • Drawback: Not open-source, so if you like peeking under the hood, this isn’t for you.
If you’re juggling Macs, Linux boxes, Android gear, and Windows stuff and want a single way to access USB devices everywhere, USB over Network alternative is a solid option.
Feel free to ask me for screenshots or setup tips. I wish someone had posted this before I had to figure it out the hard way!
I’ll be honest, truly seamless cross-platform USB over network tools are pretty rare unicorns. @mikeappsreviewer’s experience with USB Network Gate lines up with what I’ve seen – it does deliver one of the most comprehensive multi-OS support packages (macOS, Win, Linux, plus Android), but there’s a caveat: that price tag stings and it’s definitely not open source. If you’re all about just plug-and-play and willing to shell out a little, it’s a legit solution, though I’ve had similar bumps with older Linux support and it’s not always as magical as marketed (that “didn’t see my device” issue is stupidly common).
For those who aren’t ready to commit cash and want something a bit more DIY–ish: there’s also VirtualHere. It supports Windows, Mac, and Linux, with a server you can throw on a Raspberry Pi or Linux box pretty easily. The client side is pretty pain-free too, but the free version only lets you share one device at a time and their UI looks like Windows XP nostalgia hour. Still, it’s solid for testing before coughing up for a license.
Real talk: if you want the best all-in-one USB over IP software for mixed environments, you’ll probably end up coming back to USB Network Gate, annoyance and licensing fees aside. If you’re still exploring, you can scope out alternatives and compare features at best ways to share USB devices over a network across operating systems.
Gotta be honest—‘fully cross-platform USB over network app’ is almost a mythical beast. Like, unicorns riding hoverboards rare. I’m vibing with what @mikeappsreviewer and @codecrafter said about USB Network Gate: it does tick the Windows, macOS, Linux and Android boxes, but the subscription cost is a bit of a wallet punch and open-source evangelists will have to sit this one out. I’ve also run into the “where’s my device?” gremlin more than I’d like—plus, their UI feels like something IT would install in a dentist’s office in 2012.
On the flip side, VirtualHere is a bit friendlier on cost (especially for dipping your toes in with a single device), and definitely wins nostalgia points for its GUI, but cross-compatibility isn’t as integrated and the licensing for more devices stacks up quickly. Interesting workaround if you’re fine with sharing only one device at a time.
You could, in theory, wrangle usbip, but only if you’re a Linux command line masochist and don’t mind community hacks for Windows. It’s not plug-and-play. Most “free” solutions end up with either janky drivers, dubious security, or sudden brick walls when you want to go cross-platform.
Surprised no one dropped a word about FlexiHub (which also does cross-platform and even adds cloud tunneling), but IMO, it’s even pricier than USB Network Gate and their licensing is even harder to decode than my tax return.
Bottom line: If “seamless” is what you need–and you don’t want to spend weekends on forums deciphering kernel modules—USB Network Gate is the closest thing to a one-stop shop. Until someone open-sources a polished miracle, I’m stuck grumbling about price, but at least my Mac sees the test dongle on my Linux box. Still searching for magic, but this keeps me saneish.
If you decide to try it, check out this page for easy cross-platform USB device sharing downloads—gets you directly to the stuff you’ll need for every OS combo. If anyone actually finds a totally free AND truly seamless solution, please scream it from the rooftops. We’ll name our servers after you.
A simpler option is to leave each USB device attached to one small host PC, then access the host through Remote Desktop, RustDesk, or VNC. You use the device through its native app, so Windows, macOS, and Linux compatibility matters less. For scanners, set up scan-to-folder and share the folder over SMB. This avoids USB forwarding drivers, license fees, and flaky device detection. The tradeoff is one extra host machine and a minor network dependancy.
A license dongle over the network behaves nothing like a webcam or an audio interface. The dongle-type stuff (which is what most people here are actually sharing) works fine on any of these tools, USB Network Gate included, but isochronous gear like cameras and mics tends to stutter or drop no matter which software you pick. So before you judge a tool as broken, check whether it’s the software or just the bandwidth of the device you’re forwarding.
