A self check is not an accusation.
You are explaining the process of running the essay through GPTZero as something the instructor might do, but it is something you are doing. You are deciding to revise an essay based on a check you are performing. Unless the assignment instructions stated that passing a detector is a condition of submission, I would not add that as a requirement.
I disagree with the advice of the second detector. Before uploading a second time, consider what result would satisfy you. If a passing result would only distress you about the first flag, then scanning again achieves nothing. If a second flag would prompt you to rewrite the exact sentences that concern you, then you abdicate responsibility to the websites by turning in an essay that includes issues you recognize.
My response to your thesis is a negative one: I would not trust GPTZero to flag material for revision.
That is not to say that I believe your draft requires no revisions. It is to say that a sentence needing to be rewritten is not the same as a sentence that was not written by you. The former can be a matter of style or clarity, while the latter is an allegation. Either could appear in an essay you wrote, but addressing one is not a revision to the other.
In the case of the passages that concern you, I would advise ignoring the results of the detectors and following the normal editing process you would apply to any draft. Does the sentence assert what you intend it to assert? Does it provide the evidence you want it to provide? If so, it is doing its job, regardless of how it scored on a plagiarism detector. If not, you should revise it, not because the website says so, but because you know what you intend for your essay.
The one consideration I feel you are not addressing is the possibility that your instructor might not require any students to submit their work to a plagiarism detector.
If the instructions are unclear, ask for clarification before making any decisions. Do not turn in an essay with the expectation that it will be accepted, only to argue that it does not deserve a punishment you believe you do not deserve. If the instructions are clear, follow them. You should decide what assistance your instructor has permitted you to use on your essay, not the reverse.
I cannot endorse continuing to turn in this essay while insisting that it does not deserve a penalty, but I would advise saving the records of your process and preparing a defense if you feel that this is a fair appeal. I would not include an unprompted explanation of the detectors’ results with the essay, but I would submit the paper according to the guidelines provided, without further self-editing beyond the revisions you decide the essay needs.
