Is Blender available for iPad?
I recently got an iPad and was hoping to use Blender for some 3D modeling projects. After searching the App Store, I couldn’t find it. Is there a way to run Blender on an iPad, or are there any alternatives that offer similar functionality? Any help would be much appreciated!
Blender isn’t available for iPad, unfortunately. The app store doesn’t have it, and if you were hoping to tap into Blender’s power on iOS, it’s a no-go. Apple’s hardware, while impressive, doesn’t support Blender natively. Even trying to run Blender via remote desktop apps can be clunky and less than ideal because of performance issues.
That said, there are alternatives. Shapr3D is a pretty solid choice if you’re looking to do some 3D modeling on your iPad. It’s more streamlined for touch interfaces and has a range of features that should cover most needs. If you’re into more sculpting than strict modeling, check out Forger. It’s like having a mini ZBrush on the go.
But if you’re dead set on the power of Blender, consider getting a robust laptop or desktop. There’s not much that can replace Blender’s breadth and depth in iPadOS land. If you must stick to iPad, then pairing it with a desktop might be a way to bridge the gap—use the iPad as an input device while doing the heavy lifting on a connected PC.
So yeah, not the answer one hopes for, but those alternatives like Shapr3D can still provide quite a punch in your 3D modeling adventures. Shapr3D, in particular, is fine-tuned for the iPad experience and packs a decent suite of tools for professional work. Hope this helps!
I know, it’s kinda a bummer that Blender isn’t available for iPad. But adding to what @nachtschatten said, you might also find Procreate useful, especially if you’re into creating textures or doing some concept art alongside your 3D modeling. Procreate’s not a full 3D modeling suite, but its powerful drawing tools could complement your 3D projects nicely.
If you’re set on Blender and need more flexibility on the go, another alternative is using a remote desktop app like TeamViewer or Splashtop. Sure, performance can be wonky, but for quick tweaks or rendering supervision, it might save you in a pinch. Plus, if you pair that with a Bluetooth keyboard and mouse, you might get a more bearable experience out of it.
Also, check out Nomad Sculpt. For pure sculpting work, it’s pretty robust and might fill that gap for those ZBrush-like needs when you’re on the move. Sometimes it’s about combining several tools to achieve what you’d normally do on Blender.
One more thing: consider getting an iPad with the M1 chip if you don’t already have one. The hardware can handle quite a lot, and new apps optimized for it might offer more powerful 3D modeling features in the future. In the meantime, Shapr3D and Forger can be good workarounds, but don’t completely rule out cross-platform workflows. The tech between desktops and mobile devices is closing the gap, even if it’s not there yet.
The seemingly low availability of robust 3D modeling tools on iPadOS (like Blender) highlights a gap in the market; developers might surprise us soon with more versatile solutions. So keep an eye out!
Try Tinkercad in Safari. It runs in your browser, with no App Store install or remote desktop setup. Use it for basic models, prototypes, and simple parts. Export your work as STL or OBJ, then finish it in Blender on a computer later. It’s easy to learn, touch-friendly, and saves alot of setup time.
The hardware isn’t the reason, and I’d correct that before anyone runs out to buy an M1 iPad hoping it changes things. Modern iPads have plenty of horsepower for Blender-level work. The blocker is that Apple locks down iPadOS enough that a full desktop app like Blender can’t just be ported over, and the Blender team hasn’t built for it. So @suenodelbosque’s ‘wait for M1-optimized apps’ is a nice thought, but the wall is Apple’s rules, not chip speed. Waiting won’t fix a policy problem.
On the remote desktop idea, it works better than people expect for viewing a render or babysitting a bake. Where it falls apart is actual modeling. Blender leans hard on the middle mouse button, numpad, and a wall of keyboard shortcuts. Streaming that to a touchscreen means you’re fighting the interface the whole time. A Bluetooth mouse and keyboard help, but at that point you’re basically using your iPad as a small monitor for your PC, which is fine, just be honest with yourself about what you’re actually doing.
Tinkercad in the browser, like @greengurux8695lab said, is genuinely the least painful path if your models are simple. No install drama, exports clean, done. It just caps out fast once you want anything organic or detailed.
If you want real modeling that feels native to the iPad, I’d skip the Blender workarounds entirely and pick a tool built for touch. Nomad Sculpt for sculpting is the standout, cheap and surprisingly capable. Shapr3D is the pick if you’re doing hard-surface or CAD-style parts. Treat those as their own thing rather than a Blender stand-in, then move files to Blender on a computer when you need the finishing work. Trying to force one app to do everything is where most people end up frustrated.
