IPhone Almost Full But I Need To Free Up Storage Without Losing Anything - Where Do I Even Start?
My iPhone storage is almost full, and I’m worried about deleting something important like photos, messages, or app data. I need help figuring out the safest way to free up space without losing anything, especially since my phone has started acting slow and I rely on it every day.
I hit the same wall a while back. iPhone said storage was full, I had already deleted the obvious stuff, and the free space number barely twitched. The part people miss is simple. You need to see what category is eating the space before you start removing random things.
Check the storage graph first
Open Settings > General > iPhone Storage, then wait a bit. The colored bar needs time to finish loading. I wouldn’t trust the number before it settles. That screen shows where the problem sits, photos, apps, system data, messages, or something else. If you skip this step, you end up deleting three apps and 200 screenshots, then finding out videos were the real issue.
If you do not use iCloud
The first change I made was camera format. Go to Settings > Camera > Formats and switch to High Efficiency. New shots save as HEIC instead of JPEG. Same photo for most people, smaller file. It does nothing for old photos, but it slows the damage.
Also, Live Photos add up fast. People forget each one stores extra motion and audio. It looks like one picture, but it behaves more like a photo with a tiny video stapled to it. I turned a bunch of mine into still images and got space back without losing the shot itself.
Offload apps before deleting them
This one gets ignored way too often. In Settings > General > iPhone Storage, tap an app you rarely open and choose Offload App. The app itself gets removed, but your documents, saved files, and sign-in info stay put. The icon stays on the Home Screen. Tap it later, it downloads again.
Stuff like games, airline apps, hotel apps, and old editing apps are good targets. I found one travel app sitting there with gigabytes attached to a trip I took months ago. Didn’t need it daily. Offloading fixed it.
If deleting photos did nothing
This catches a lot of people. Photos you delete do not leave right away. iOS moves them into Recently Deleted for 30 days, and they still take up storage the whole time. So if you cleaned out your library and the phone still acts stuffed, go to Photos > Albums > Recently Deleted, then remove them for good.
That was the part where my storage number finally moved. Before that, it felt broken tbh.
When the phone is so full it starts acting dumb
Restart it. No magic here. A reboot clears temporary cache files and other junk iOS hangs onto. You will not get back huge chunks, but I’ve seen it free enough space to make the phone usable again. If your screen is lagging, apps refuse to open, or the camera won’t save photos, do this early.
Manual cleanup gets ugly once the library is huge
Here’s where it gets annoying. The built-in tools don’t do a great job surfacing the worst offenders. Near-duplicate burst shots, old 4K videos, giant screen recordings, and Live Photos spread across years of albums are hard to hunt down one by one. I tried doing it manually once. Waste of time.
I used Clever Cleaner for this part. What helped me most was the view sorting the biggest files first. You see the monsters right away, giant videos, long screen recordings, forgotten clips. There’s also a section grouping similar photos together, which made burst cleanup much faster. It picked a best shot in a lot of my duplicate sets, and most of the picks were fine. Not perfect, but close enough. The Live Photo tool was the one I kept using. It removed the motion part and kept the still image, and I got back a few GB from that alone. From what I saw, processing stayed on the phone.
Last thing to inspect
If System Data still looks bloated after all this, check your social apps. Go to Settings > Apps and look at what Instagram, TikTok, and similar apps are storing. Those apps hoard cache like crazy. In a lot of cases, the only clean fix is deleting the app and installing it again. Your account stays there. Your local cache gets wiped.
If your phone says full and nothing you delete seems to matter, I’d do it in this order. Check the storage graph. Empty Recently Deleted. Offload large apps. Restart. Then deal with duplicate photos, big videos, and Live Photos. That order saved me a lot of pointless cleanup.
Start with backup. Not cleanup.
If you want zero-risk space savings, do this first.
  1. Plug your iPhone into a Mac or PC and make a full local backup.
  2. If you have enough iCloud space, run an iCloud backup too.
  3. Open Photos and confirm syncing status before touching anything.
I partly disagree with @mikeappsreviewer on one thing. Restarting helps a little, but if you need meaningful space, backups and export matter more first.
Best safe wins:
  1. Turn on Messages in iCloud, if you use it. Old attachments move off the device over time.
  2. Review Downloads in Files app. PDF files, ZIPs, video files, and random docs sit there forever.
  3. In Podcasts, Music, Netflix, YouTube, Spotify, remove offline downloads. This frees space fast and you lose nothing permanent.
  4. In Safari, clear website data. Small gain, but safe.
  5. Check Voice Memos. One hour of audio is often 30 MB to 500 MB, depending on format.
  6. In Books, delete downloaded audiobooks and PDFs you already finished.
For photos, I would not mass-delete first if you are nervous. Export first. Use Image Capture on Mac, Photos app on Windows, or cloud storage.
If your photo library is messy, Clever Cleaner helps sort large videos and similar shots faster. The App Store page is here, clean up iPhone storage with Clever Cleaner.
Your safest order is backup, export, remove downloads, offload apps, then photo cleanup. Slow is better here. One bad tap sucks.
I’d split this into stuff you can remove safely vs stuff that only looks removable.
@viajeroceleste is right about backing up first, but I actually think people over-focus on backups and under-focus on what is re-downloadable. If it can be streamed or downloaded again, it’s the lowest-risk target. That means:
  • downloaded Netflix/Spotify/YouTube content
  • old iOS update files if they’re sitting there
  • Mail attachments cached on-device
  • browser download folders inside Chrome/Firefox, not just Safari
  • WhatsApp/Telegram media that already exists in the chat/cloud
One thing I’d check that @mikeappsreviewer didn’t really get into is Mail. If the Mail app is huge, it’s often just synced messages and attachments. Removing and re-adding the mail account can shrink local storage without deleting the actual email from the server. Same idea for some cloud apps.
Also, look at apps with giant “Documents & Data” totals. Offloading is fine, but for bloated apps I usually go straight to delete and reinstall if the data lives in your account anyway. Reddit, Instagram, TikTok, Discord, even shopping apps cache a stupid amount of junk tbh.
For photos, if you’re scared of deleting, use a sorting tool before you touch anything. Clever Cleaner is decent for finding large videos, duplicates, and similar pics without making the process a total mess. If you want a better breakdown first, this Clever Cleaner for iPhone review and cleanup guide gives a solid overview.
My safest order would be:
  1. Backup
  2. Remove downloads and caches
  3. Reinstall bloated social/media apps
  4. Review mail/storage-heavy chat apps
  5. Then clean photos
Don’t start by nuking memories when cached garbage is probly the real problem.
I’d add one thing none of @viajeroceleste, @codecrafter, or @mikeappsreviewer really stressed enough: check Messages storage by conversation, not just Messages as a whole.
Go to Settings > General > iPhone Storage > Messages. If one group chat has years of videos, GIFs, voice notes, and memes, that single thread can be multiple GB. You can delete only the big attachments inside that chat instead of wiping messages you care about.
Same with third-party chat apps. In-app storage managers are often safer than deleting the whole app because you can target videos and forwarded junk only.
I also wouldn’t rely too much on “System Data” fixes. Sometimes people obsess over that number when the real problem is hidden attachments and downloads.
If photo cleanup gets messy, Clever Cleaner is useful for spotting large videos and similar shots.
Pros: fast scan, easy size-based cleanup, helps avoid random deleting.
Cons: similarity detection is not always perfect, and I still wouldn’t auto-delete anything sentimental without reviewing it.
So my order would be:
  1. Back up
  2. Check iPhone Storage
  3. Clean big message attachments
  4. Clean chat app media from inside the apps
  5. Remove offline downloads
  6. Only then touch photos/apps
Try one simpler option: use iCloud Photos with Optimize iPhone Storage.
Open Settings, tap your name, iCloud, Photos. Turn on Sync this iPhone, then select Optimize iPhone Storage. Your full-resolution photos stay in iCloud, while your phone keeps smaller copies. This often frees several GB without deleting memories.
You’ll need enough iCloud storage and Wi-Fi. Leave the phone charging overnight. Dont clean photos until syncing finishes. Open a few older photos afterward to confirm they download correctly. This takes less effort than sorting thousands of files by hand.
Careful with the delete-and-reinstall trick @codecrafter mentioned. It’s fine for Instagram or TikTok where everything lives on the server, but WhatsApp is the classic trap. If your chats aren’t backed up to iCloud or Google Drive first, reinstalling can wipe media and messages that only existed on the phone. Same goes for any app holding downloads or drafts locally. Check where the data actually lives before you nuke the app.
The Optimize iPhone Storage route @silverthinker7366stu pointed at is genuinely the least effort, but it stalls the second your iCloud is full, and the free tier fills instantly. So either you’re paying monthly or you’re back to manual cleanup anyway.
For me the real hogs are almost always videos, not photos, and that’s where running something like Clever Cleaner to sort by size saves you scrolling for an hour. Just don’t expect any tool to fix a full iCloud for you. That part’s on your wallet.
