If I Delete Attachments Will It Remove Them From My Other Apple Devices?
I deleted some message attachments on one Apple device to free up storage, and now I’m worried they might disappear from my iPhone, iPad, and Mac too. I use iCloud and I’m not sure how attachment syncing works across Apple devices. Can someone explain whether deleting attachments on one device removes them everywhere?
Big message attachments on iPhone are still a pain. I kept expecting one clean bulk-delete screen, but Apple still makes you poke through menus and pick stuff by hand. Here’s the version that worked for me, plus the stuff that tripped me up.
Is there any faster option than tapping files one by one?
A little. Not much.
The quickest place I found is Settings > General > iPhone Storage > Review Large Attachments. That screen pulls the biggest message files from all chats into one list, which saves time if your storage is getting chewed up by random old videos and PDFs.
If you already know which conversation is the problem, open it, tap the person or group name at the top, then look in Photos or Documents. Hit See All and you can mark multiple items from that thread in one pass.
Still no Select All button. Weird omission, still there in 2026.
Does this work the same on iPad?
Yep. I did the same steps on an iPad and got the same menus. iPadOS handles message attachments the same way iOS does.
If you use iCloud Messages, deleting something on your iPhone should sync over to the iPad too. Mine didn’t update instantly every time. A few minutes later it usually caught up. Once or twice it felt broken, then it sorted itself out.
Does deleting attachments remove both photos and videos?
Yes. Both go away from Messages.
The part people miss is this. If you saved a photo or video to the Photos app earlier, you made a separate copy. So when you delete the attachment from Messages, you only remove the version stored inside the chat history. The saved copy in Photos stays there.
If you never saved it, deleting it from Messages means it’s gone.
Why do deleted attachments show up again?
I ran into this, and there were two reasons.
First, Messages has its own Recently Deleted area. Stuff sits there for 30 days unless you clear it yourself. On the main Messages screen, tap Edit in the top-left corner, then Show Recently Deleted. If you skip this part, your storage often won’t come back yet because the files are still sitting on the phone.
Second, iCloud syncing and storage optimization seem to muddy things. I saw files act like they were back even after I removed them. After I emptied Recently Deleted and restarted the phone, storage numbers finally corrected themselves and the repeat appearances stopped.
Why doesn’t storage drop right after deleting things?
Most of the time, it’s the Recently Deleted folder. Those files still count for the full size until you empty it.
Also, the storage readout lags. I’ve seen it sit there with the old number for a while. Restarting the phone pushed it to update faster for me.
When cleaning message attachments isn’t enough
This was the part I ignored at first. Message junk was only one slice of the problem. My phone had duplicate-looking pics, old 4K clips, and a stupid number of screenshots. I cleared message attachments and still felt short on space again not long after.
For wider cleanup, I used Clever Cleaner. What I liked was the layout. The Heavies tab puts the biggest files at the top with exact sizes, so you see fast what is eating storage. The Similars tab groups near-matching photos and picks a best shot, which helped with burst-photo mess. Screenshot sizes are shown before deletion too.
It processes on the device, so nothing gets sent out somewhere else.
After I cleared about 15GB there, then emptied Messages Recently Deleted, my free space came back and the phone stopped feeling bogged down. Not magic. It was more like finally removing all the junk from the places iOS hides it, lol.
If Messages in iCloud is turned on, yes. Delete an attachment on one Apple device, and it gets removed from the same conversation on your iPhone, iPad, and Mac after sync finishes. It is one shared message database, not separate copies on each device.
A few exceptions matter.
If one device does not use Messages in iCloud, it might keep its own local copy. Same if a Mac is signed into a different Apple Account. Also, if you saved the file to Photos or Files before deleting it from Messages, the saved copy stays put. Only the copy inside Messages gets removed.
I differ a bit from @mikeappsreviewer on one point. Sync issues are often less about attachments “coming back” and more about one device not finishing iCloud sync yet. Check Settings, tap your Apple ID, then iCloud, then see if Messages is enabled on all devices. On Mac, open Messages, Settings, iMessage, and confirm “Enable Messages in iCloud” is on.
If your goal is storage cleanup with less risk, save important attachments first, then delete. I do this for tax PDFs and family videos so I dont nuke somthing I need later.
For broader storage cleanup, Clever Cleaner helps more with photos, screenshots, and large files than with Message syncing itself. Also worth a read: Reddit users on the best truly free iPhone cleaner app.
Yep, usually yes.
If Messages in iCloud is on for your iPhone, iPad, and Mac, deleting an attachment from a conversation on one device removes that attachment from the same thread on the others too. It may not vanish instantly, but after sync catches up, it’s generally gone everywhere. That part @kakeru got right.
Where I slightly disagree with @mikeappsreviewer is the idea that stuff “comes back” in a meaningful way. In my expereince, it’s more often one of these:
  • one device has not synced yet
  • the message is still sitting in Recently Deleted
  • the file was saved separately to Photos or Files first
That last one matters a lot. If you saved the pic/video/PDF outside Messages, deleting the message attachment does not delete the saved copy. So your Photos library or Files app copy should still be there.
Also, if one device has Messages in iCloud turned off, it can behave a little weird and keep older local data longer than you’d expect. Apple’s syncing is nice when it works, kinda annoying when it doesnt.
If you’re trying to free space without risking anything important, save the attachments you care about first, then delete from Messages. For general storage cleanup beyond Messages, Clever Cleaner is actually useful for finding big videos, duplicate-ish photos, and screenshots that are silently eating space.
Also worth a quick look if you want a visual walkthrough of iPhone cleanup: watch this iPhone storage cleanup demo.
A simpler option is to leave Messages alone and free storage elsewhere. Open Settings > General > iPhone Storage. Tap Offload Unused Apps. This removes the app but keeps its documents and login data.
Also delete downloaded Netflix shows, Spotify playlists, podcasts, or offline maps. One downloaded movie often uses 2 to 6 GB. This gives you space without risking synced attachments on your iPhone, iPad, or Mac. I’d start there if you dont want anything disappearing.
Before you touch anything, check that every device actually has Messages in iCloud switched on, not just iCloud in general. People mix those two up constantly. Being signed into the same Apple ID does nothing for message syncing on its own. The toggle you want is the specific one inside iCloud settings for Messages, and on the Mac it lives in the Messages app under settings, not in System Settings. If that box is off on even one device, that device is running its own private copy and none of this ‘delete once, gone everywhere’ logic applies to it.
@kakeru and @vrijheidsvogel both nailed the main answer, so I won’t rehash it. The bit I’d push back on slightly is the calm ‘it’ll catch up after sync’ framing. That’s true most of the time, but the annoying edge case is the odd device out. Say your Mac had Messages in iCloud off for months while your iPhone had it on. Flip it on later and the Mac can shove its old local history back up into the shared database, and suddenly attachments you deleted look like they’ve returned. It isn’t a bug, it’s two databases merging. So if you’ve got a device that’s been out of sync for a while, sort that one out before you start deleting, not after.
For plain storage relief, @goldenwolf7686 has the least risky idea in the thread. Offloading apps and dumping downloaded Netflix or Spotify files gets you gigabytes back without going anywhere near your messages. Do that first and you might not need to delete a single attachment.
Clever Cleaner is fine for the photo and video side of things, the big duplicate clips and screenshot piles, but it doesn’t touch the Messages sync question at all, so don’t expect it to solve the thing you actually asked about. Use it for the photo library, handle Messages separately.
