I’m trying to figure out how to enable Apple Intelligence on my iPhone but I can’t find the option in Settings or Siri. I’m not sure if my device is compatible, if I’m missing a software update, or if it’s only available in certain regions. Can someone explain the exact steps to turn it on, any requirements, and how to confirm it’s actually working
Short version. Most people do not see an “Apple Intelligence” switch yet because it only shows up if all of this is true:
Check if your iPhone supports it
• iPhone 15 Pro or iPhone 15 Pro Max
• Older models do not support Apple Intelligence at all
• On iPhone go to Settings > General > About and check Model Name -
Check your region and language
• Only on iOS 18
• Only in US English at first
• Your Apple ID region needs to be United States
• Your device language needs to be English (US)
Settings > General > Language & Region -
Update to the right software
Right now it is tied to iOS 18 betas
• Go to Settings > General > Software Update
• If you are on iOS 17, you will not see any Apple Intelligence options
• If you do beta, you need the iOS 18 developer or public beta when it is available in your region -
Where the toggle shows up
Once you have
• iPhone 15 Pro or 15 Pro Max
• iOS 18 beta installed
• US English set
You should see Apple Intelligence prompts during setup after the update
Also check
• Settings > Siri & Search
• Settings > Privacy & Security > Apple Intelligence or similar wording, since Apple keeps tweaking menus in betas -
Things that block it
• Older iPhone like 14 Pro, 13, SE, etc, will never get Apple Intelligence
• Wrong region on Apple ID
• Wrong system language
• Not on iOS 18 or not on the right beta build
So if you do not see the option
• First, confirm your phone model
• Second, check the iOS version
• Third, check language and region
If your phone is not 15 Pro or 15 Pro Max, there is nothing to turn on, even with updates.
You’re not crazy, Apple just made this way more confusing than it needs to be.
@cazadordeestrellas already hit the main checklist (device, region, language, iOS 18 beta). I’ll add what usually trips people up in practice and a couple spots where I slightly disagree with how strict it all sounds.
Don’t hunt for an “Apple Intelligence” big ON/OFF switch
This is the first gotcha. Right now Apple Intelligence is more like a collection of features baked into apps, not a single master toggle. So if you’re scrolling through Settings expecting a giant “Apple Intelligence” button like “Screen Time,” you’ll prob never see it.Instead, look for:
- New Siri UI and prompts (press and hold side button or “Hey Siri”)
- Writing tools in text fields (rewrite, summarize, etc.)
- Image tools in Photos / Messages, depending on the beta build
Setup prompts can be one-time and easy to skip
After updating to an eligible iOS 18 beta on a 15 Pro / 15 Pro Max with US English, you should see setup cards like:- “Try the new Siri”
- “Use Apple Intelligence”
If you raced through those or hit “Not now,” Apple doesn’t always make it obvious how to get them back. Try: - Settings > Siri & Search > look for new options labeled something like “Siri with Apple Intelligence” or “Advanced Siri features.”
- Settings > General > Software Update > tap “iOS 18” and check for “Beta updates” to make sure you’re on a recent build. Old betas sometimes hide stuff or have it half-broken.
Region and language are messier than they look
I mostly agree with @cazadordeestrellas on US-only + US English, but:- Some folks report that having device language as English (US) is key, but the region in “Language & Region” can sometimes be non-US as long as the Apple ID country is US. Not guaranteed, just what’s been seen in the wild.
- If nothing shows up, try setting:
- Settings > General > Language & Region: iPhone Language = English (US)
- Region = United States
- Apple ID country = United States (this part is more painful to change and might not be worth it if you’re just curious)
Double check you didn’t hit a hardware wall
This is the part people hate:- iPhone 15 Pro / 15 Pro Max only right now
- iPhone 15 non Pro, 14 Pro, etc, are left out at the moment
You can confirm in Settings > General > About > Model Name. If it is not 15 Pro or 15 Pro Max, you will not get Apple Intelligence features, even with iOS 18 installed. No hidden toggle, no secret plist hack, no “wait for it to roll out.”
If you do have a 15 Pro / 15 Pro Max and still see nothing
Try this quick checklist:- On iOS 18 developer or public beta?
- If you’re on iOS 17.x, nothing AI-related will appear.
- Once updated, restart the phone. Sounds dumb, but some users only saw prompts after a full restart.
- Open: Settings > Siri & Search and scroll really slowly. Apple has been renaming and moving things between early betas. Look for any new sections that mention “Siri capabilities,” “Advanced features,” or “Apple Intelligence” wording.
- Check Settings > Privacy & Security too. Some builds put AI-related toggles or info panels there.
Reality check: it might just not be “on” for you yet
Even if you tick every box, Apple sometimes staggers server-side activation. That means:- Correct device
- Correct region & language
- Correct beta
…and still nothing, just because your account hasn’t been flagged yet. Super annoying, but normal for early betas. In that case, honestly the only move is: wait for the next beta or two and keep an eye on the release notes.
So, tl;dr for your case:
- First, confirm model: if it’s not 15 Pro / 15 Pro Max, stop digging, it will not appear.
- If it is 15 Pro / 15 Pro Max, get onto iOS 18 beta, switch everything to US / English (US), restart, then look for new Siri / writing tools rather than a giant “Apple Intelligence” switch.
- If still nothing, it’s probably not fully rolled out to your combo of device + account + beta yet, not something you’re “missing” in Settings.
Little add‑on from a more “why isn’t this showing up?” angle rather than more toggles to chase.
@cazadordeestrellas covered the mechanical checklist. Where I slightly disagree is on the idea that if you meet the criteria it’s just “wait and it’ll appear.” In practice, with Apple Intelligence right now, there are three less obvious bottlenecks people hit:
Account flags & age settings
- If your Apple ID is part of Family Sharing and marked as under 18, some Apple Intelligence features may be limited or silently withheld.
- Check in Settings > [your name] > Family to see if there are Screen Time restrictions that disable Siri & Dictation enhancements. Those can indirectly kill the Apple Intelligence surface without saying so.
- A few testers have reported that logging out of iCloud, rebooting, then logging back in forced a fresh “capabilities” pull from Apple’s servers. It is annoying, but for some it was the first time Siri started responding with the new behaviors.
On‑device processing constraints
- Apple Intelligence leans heavily on on‑device models. If your device is low on storage or heavily thermally throttled (very hot, constant background sync, etc.), features can appear sluggish, incomplete, or just “not there yet.”
- Try freeing at least 15–20 GB of space, then leave the device plugged in and on Wi‑Fi for a while. Some of the model downloads and indexing happen quietly and can delay activation.
In‑app behavior is sometimes a better test than Settings
Instead of living in Settings, try:- Long pressing in a block of text in Mail or Notes and see if you get options like “Rewrite” or “Summarize” in the pop‑up menu.
- In Messages, type something longer and look for a small “sparkle” icon near the text field. That often appears before any obvious Apple Intelligence branding in Settings.
If those tools are present, you effectively have Apple Intelligence, even if the branding is confusing or missing.
On the “there is no big Apple Intelligence switch” point: I mostly agree, but Apple has a habit of quietly introducing umbrella panels in later betas or .1 updates. So I would still periodically recheck Settings > Siri & Search and Settings > Privacy & Security after each new iOS 18 build, since Apple sometimes centralizes controls later in the cycle.
Since you mentioned not being sure if your device is compatible, one harsh reality check that often gets missed: even if a future iOS 18 stable release mentions “some Apple Intelligence features available on more devices,” do not assume your non 15 Pro iPhone will suddenly get the full set. Historically, Apple keeps some ML‑heavy stuff locked to newer chips permanently.
Pros & cons wise for “How To Turn On Apple Intelligence” as a topic:
- Forces you to verify all the moving parts at once: hardware, region, language, software build.
- Gives you a sanity checklist so you know when to stop hunting for a non‑existent toggle.
- Helps you distinguish between “AI is off” and “AI is actually on but hidden in features like writing tools.”
- The phrase itself is misleading because there is no simple on/off like Dark Mode, which makes expectations worse.
- Focus on “turning on” Apple Intelligence can distract from testing in‑app behavior, which is more reliable than Settings labels.
- It can make people burn hours tweaking language/region when the real problem is hardware or Apple’s server‑side rollout.
Compared with what @cazadordeestrellas laid out, I’d lean less on endlessly flipping regions and more on: confirm hardware, confirm you are on a recent iOS 18 beta, give the phone time on Wi‑Fi and power to pull models, and then test inside apps rather than obsess over a single master toggle in Settings. If all of that fails on an iPhone 15 Pro or 15 Pro Max, you are almost certainly waiting on Apple’s backend, not missing a magic switch.
