How To Turn Off Meta Ai On Facebook
Meta AI started showing up in my Facebook search and chat, and I can’t figure out how to disable or remove it. I’ve checked my settings but I’m not seeing a clear option, and I need help finding the right steps to turn off Meta AI on Facebook.
You usually do not get a full off switch for Meta AI on Facebook right now. Meta added it into search, Messenger, and parts of the app. For most users, removal is not offered.
What you can do:
  1. Mute it in Messenger.
    Open Messenger.
    Find the Meta AI chat.
    Open the chat, tap the name, then tap Mute or Archive.
  2. Clear it from search.
    Tap the search bar.
    Long press recent Meta AI prompts or results if shown.
    Delete search history.
  3. Limit AI features.
    Check Facebook app settings, then look under Privacy, Search, or AI features.
    Some accounts show toggles, many do not.
  4. Use Facebook in a browser.
    The web version sometimes shows fewer AI prompts than the app.
  5. Update or reinstall.
    Some people report the AI bar changes after an app update. It does not fix evrything, but it helps for some users.
If you want it gone completly, there is no universal setting at the moment. Meta is rolling this out unevenly, so your account might not have the same options other people post about.
You’re probably not missing anything. Meta mostly doesn’t give a real disable button for Meta AI on Facebook right now.
One thing I’d add beyond what @jeff said: check whether you can turn off AI-based message summaries/replies if those are showing up. Sometimes that setting is buried under Messenger preferences or chat features, not under the main Facebook settings where you’d expect it. Meta loves hiding stuff in weird places, aparently.
Also, if the issue is the blue circle/search assistant specifically, try this:
  • switch to an older app version if your phone allows it
  • leave the Facebook beta program if you’re in it
  • force stop the app and log out of all sessions
I kinda disagree with the “update/reinstall” advice as a main fix, because for a lot of people that just brings the AI stuff back even harder. It can help, but it’s not some magic switch.
If you want the practical answer: you can usually only hide, mute, reduce, or avoid Meta AI, not fully remove it. Browser version + Messenger notification controls tends to be the least annoying workaround rn.
