I accidentally deleted the wrong folder from my USB drive and lost important files I still need for work and personal documents. I’m looking for the best way to recover deleted files from a USB flash drive before anything gets overwritten.
If I were dealing with your USB stick, I’d start with recovery software, as long as the drive still behaves like a normal drive. I mean it shows up, reports a normal size, stays connected, and doesn’t feel hot or flaky. If it keeps dropping out, says 0 bytes, or looks physically damaged, I’d stop there and treat it like a hardware case instead.
For the usual, “I deleted stuff and now I need it back” problem, software is the first move. Not perfect, no. Still the cheapest and cleanest shot before you end up staring at a lab quote you do not want to pay.
The first thing I’d do is simple. Stop writing anything to the USB right now. No new files. No format. No cleanup. No “let me test something.” On USB drives, deleted files usually are not sitting in the normal Recycle Bin waiting for you. The system marks the space as available, and your old data stays there only until something else lands on top of it. I learned this the bad way years ago with a folder of camera raws. One copy job later, gone for good. So yeah, hands off the drive.
Before running scans, I’d check the boring stuff first, because sometimes the files were not deleted at all. They were hidden, moved, or copied somewhere else earlier and forgotten.
Show hidden files on the USB and look through it manually.
Check for folders like $RECYCLE.BIN, RECYCLER, RECYCLED, or .Trashes if the stick was plugged into a Mac at some point.
Look through your PC folders, mainly Downloads, Desktop, Documents, and any folder where you tend to dump files fast and sort them later. I do this all the time and regret it later.
Check backup and sync sources. File History, OneDrive, Google Drive, Dropbox, old backups, whatever you use.
If all of that turns up nothing, I’d move to recovery software.
Most of these tools work in roughly the same way, even if the menus and wording are all over the place:
Install the software on your computer, not on the USB drive.
Plug in the USB and pick it inside the recovery app.
Run the deleted file or lost file scan.
Let the scan finish. Don’t stop early if the files matter.
Use filters if the tool supports them, file type, date, size, filename.
Preview files where possible.
Select what you want back.
Save recovered files to your computer or another drive, never to the same USB stick.
I’m repeating that last part because people mess it up a lot. If you restore files back onto the same USB, you risk overwriting other deleted data you have not recovered yet. Then you get half your stuff back and spend the next hour wondering why the rest is corrupt. Seen it, done it, dumb mistake.
These are the tools I’d look at first.
Disk Drill
This is where I’d start. It’s easy to get through without fighting the interface, and it handles the file systems you usually see on USB drives, FAT32, exFAT, NTFS. The preview feature matters more than people think. If a photo opens in preview, or a document renders properly, your odds are usually better. I’ve also had it pull files from drives with mild file system mess, not only clean delete cases.PhotoRec
Ugly, blunt, effective. It’s free, and when a file system is damaged, this thing still digs stuff out. The catch is organization. You often lose original names and folder paths, so what you get back might be a mountain of files named like random scraps. If you need a free rescue option and do not mind sorting through a pile later, it earns its spot.Data Rescue
I’ve had decent results with it, though I never liked the flow of the interface much. It works, though. If your first scan misses something, using a second tool sometimes helps because the scan methods are not identical. I would treat this as a backup plan or a second opinion.Recuva
Old one, Windows only, still useful in plain delete cases. If you lost common files like JPGs, PDFs, Office docs, it’s worth a try. I would not expect miracles from it on newer or messier cases, but for a basic undelete job it still has a pulse.
One thing I would hold off on is CHKDSK or any repair command. Those tools are aimed at fixing the file system, not getting deleted files back. Sometimes they help with access issues. Other times they rearrange things enough to make recovery worse. My rule stayed the same after a few messy recoveries, get the files first, repair later.
So if your USB still mounts normally, I’d scan it with Disk Drill first, recover the important files to another drive, and only after that think about reformatting or reusing the stick. If the data matters a lot and the drive shows hardware trouble, I would skip the home fixes and go straight to a recovery lab.
