How To Print Screen On Mac
I just switched from Windows to a Mac and I can’t figure out how to print screen the whole display or just a specific window. I keep missing dialogs and dropdowns when I try shortcuts I found online. Could someone explain the reliable screenshot methods on macOS and how to save or copy them quickly for work documentation
Here are the main Mac screenshot tricks you want. I’ll keep it to the ones that actually work for dialogs, dropdowns, etc.
  1. Whole screen
    Press: Shift + Command + 3
    Result: Screenshot of every display.
    File goes to Desktop by default.
  2. Selected area
    Press: Shift + Command + 4
    Your cursor turns into a crosshair.
    Click and drag around the area.
    Release mouse to take the shot.
    Good for parts of a window or a menu.
  3. Single window (great for dialogs)
    Then press Spacebar.
    Cursor turns into a little camera icon.
    Move over the window or dialog you want.
    It highlights in blue.
    Click once.
    You get a clean shot of that window, with a shadow.
  4. Screenshot to clipboard instead of file
    Add Control to any of the above.
    Examples:
    Control + Shift + Command + 3 for whole screen to clipboard.
    Control + Shift + Command + 4 for selection to clipboard.
    Then paste in Mail, Slack, Word, etc with Command + V.
  5. Time-sensitive stuff like dropdowns and menus
    This is where people miss stuff.
    Trick: Open the menu or dropdown first.
    Keep it open with the mouse.
    Then press the shortcut with your other hand.
    macOS does not close the menu when you press the keys, so you get the full shot.
    For a specific menu:
    Shift + Command + 4, then Space, then hover the menu and click.
  6. Screenshot options panel
    Press: Shift + Command + 5
    You get a little toolbar at the bottom.
    From there you can:
  • Capture entire screen
  • Capture selected window
  • Capture selected portion
  • Record screen
    Click “Options” in that bar to:
  • Change save location
  • Add a timer (5 or 10 seconds, helpful for tricky menus)
  • Show or hide mouse pointer
  1. Change the default save location (once, so life gets easier)
    Open the Screenshot toolbar with Shift + Command + 5.
    Click Options.
    Pick Desktop, Documents, Clipboard, Mail, Messages, or “Other Location”.
    That sticks for next time.
  2. If nothing works
    Check System Settings > Keyboard > Keyboard Shortcuts > Screenshots.
    Make sure those shortcuts are enabled and not reassigned.
Quick cheat sheet:
  • Whole screen: Shift + Cmd + 3
  • Area: Shift + Cmd + 4
  • Single window: Shift + Cmd + 4, then Space, then click
  • To clipboard: add Control to any of those
  • Extra controls and timer: Shift + Cmd + 5
Once you use Shift + Command + 4 + Space a few times, dialogs and dropdowns stop being a pain.
You’re not crazy, macOS screenshots are a bit weird if you’re coming from Windows’ Print Screen.
@hoshikuzu already covered the main shortcuts, so I’ll skip re-listing those and hit the stuff that usually trips people up, especially with dialogs and menus.
1. Why you keep “missing” dialogs & dropdowns
What usually happens:
  • You click something
  • Dialog or dropdown shows up
  • You move the mouse or hit the wrong keys
  • The UI changes or closes before the shot happens
Two things to try that don’t get mentioned enough:
A) Use a timer via Shift + Cmd + 5
  1. Press Shift + Command + 5
  2. Click Options
  3. Set a 5s or 10s timer
  4. Choose “Capture Entire Screen” or “Selected Portion”
  5. Click Capture, then quickly open your dialog / dropdown
macOS waits for the timer, then captures, and it won’t close your menus just because time passed.
This is usually more reliable than trying to ninja the shortcut while stuff is opening.
B) Change the pointer behavior
In some dialogs, the pointer can block labels or buttons. In that same Shift + Command + 5 options panel, there’s a “Show Mouse Pointer” toggle. Turn it off if you want clean UI, on if you’re trying to show where you clicked.
2. If your shortcuts seem “dead”
Sometimes after switching from Windows, people install stuff like keyboard remappers or screen tools that hijack keys.
Check:
  • System Settings → Keyboard → Keyboard Shortcuts → Screenshots
  • Make sure none of the screenshot shortcuts have a weird custom key combo or are disabled
  • If you use apps like BetterTouchTool, Magnet, Karabiner, etc, check they’re not intercepting Shift + Command + 3/4/5
If stuff still doesn’t work, log out and back in, or try in a fresh user account. macOS can be annoyingly sticky with old settings.
3. For “I just want Print Screen like Windows”
A rough equivalent is:
  • Shift + Command + 3 → like Print Screen to file
  • Add Control to that → like Print Screen to clipboard
If you always want clipboard instead of files:
  2. Options → Clipboard as the default save location
Now every time you use that toolbar’s capture buttons, it behaves more like the Windows “copy to clipboard” style. Not exactly the same as the keyboard key, but close enough in daily use.
4. Tidying up the Desktop clutter
macOS loves dumping screenshots all over your Desktop like a raccoon. To keep it sane:
  • Shift + Command + 5 → Options → choose Documents or a custom folder like ~/Pictures/Screenshots
  • That setting sticks, so you don’t have to fix it every time
5. When you need pixel-perfect stuff
If you’re trying to capture UI with exact sizes (for design, docs, etc):
  • Use Shift + Command + 4
  • While dragging, hold Space to move the selection
  • Hold Option to resize from the center
  • Hold Shift to lock one axis while resizing
Not strictly necessary for basic screenshots, but once you know it, it’s hard to go back.
So: use Shift + Command + 4 tricks for quick stuff like @hoshikuzu described, but honestly, for menus and dialogs that keep “escaping,” the Shift + Command + 5 toolbar with a timer is way more forgiving.
If you’re coming from Windows “hit Print Screen and forget it”, macOS feels inside‑out. @hoshikuzu covered the core shortcuts and the Shift + Cmd + 5 timer trick really well, so I’ll try to fill the gaps and slightly disagree in a couple of spots.
1. Use the floating thumbnail instead of racing menus
After you take a screenshot, macOS shows a little thumbnail in the bottom right. This thing is secretly powerful and helps with dialogs you “almost” caught:
  1. Trigger your screenshot however you like.
  2. Let the dialog/menu appear, grab the shot.
  3. Click the floating thumbnail before it disappears.
  4. In that quick editor you can:
    • Crop tighter around the dialog you care about.
    • Add arrows / boxes to point at menus you missed slightly.
    • Hit “Done” and pick where to save.
It is not as clean as getting the perfect one-shot capture, but it saves a lot of retries.
2. Why I sometimes avoid the Shift + Cmd + 5 toolbar
Small disagreement with the heavy reliance on Shift + Cmd + 5:
If you switch contexts a lot or you are on a smaller screen, that toolbar can actually get in your way.
When you only need:
  • Entire screen: Shift + Cmd + 3
  • A specific window: Shift + Cmd + 4, then tap Space, then click the window
you skip the whole UI layer and it is faster, especially when documenting a lot of steps.
For dropdowns that close when you click elsewhere, I usually:
  1. Open the menu and keep holding the mouse button down.
  2. While still holding, press Shift + Cmd + 4.
  3. Drag the region over the open menu.
Since the click is never released, the menu stays open. Clunky, but it works without timers.
3. Fix weird color or transparency issues
If your captured dialogs look slightly off compared to what you see:
  • Go to Screenshot app settings (via Shift + Cmd + 5 → Options → “Show in Finder” then right click the app → Options).
  • Make sure you are not using any third‑party color filters or “Night Shift” style tools that auto‑tint the screen.
  • Also check if “Reduce transparency” is enabled in System Settings → Accessibility → Display, which can change how menus look in shots.
This affects people migrating from Windows who are used to exact UI captures for design or bug reports.
4. Clipboard‑only workflow without living in Shift + Cmd + 5
@hoshikuzu mentioned using the toolbar to default to clipboard, which is fine, but if you prefer pure keyboard:
  • Ctrl + Shift + Cmd + 3 → whole screen to clipboard
  • Ctrl + Shift + Cmd + 4 → selection to clipboard
  • Ctrl + Shift + Cmd + 4, then Space → window to clipboard
That lets you paste straight into Slack, email, or a doc without ever touching files or the screenshot toolbar. For someone used to Windows’ Print Screen + Paste, this is typically the most natural.
5. Check for conflicts in “mission critical” apps
If shortcuts seem flaky only in certain apps (remote desktop, games, or some Electron apps):
  • Verify if that app is capturing shortcuts itself. Some remote desktop tools or virtualization software grab Command combinations.
  • Try the same shortcut in a simple app like TextEdit to rule out a global issue.
  • If it only fails in one app, look for that app’s own screenshot or shortcut settings.
This is where people think macOS screenshots are “broken” when it is actually the foreground app intercepting keys.
Quick pros & cons summary for the “how to print screen on Mac” workflow you’ll probably settle on:
  • Very flexible: whole screen, window, region, or timer from the built‑in tools.
  • Clipboard shortcuts give a pretty close “Print Screen” feel.
  • Floating thumbnail makes quick edits and crops easy without extra apps.
  • Several shortcuts to remember instead of one key like on Windows.
  • Shift + Cmd + 5 toolbar can feel heavy or intrusive for small, frequent captures.
  • Menus that close on click still need workarounds like timers or click‑and‑hold tricks.
Between @hoshikuzu’s timer advice and a clipboard‑first shortcut setup, you get something that behaves close to Windows while still using the native macOS tools efficiently.
