Meta AI started showing up in my Facebook and Instagram experience, and I can’t figure out how to turn it off or opt out. I’ve checked settings and help pages but the steps are unclear or seem outdated. I need help finding the current way to disable Meta AI features or limit how my data is used.
You don’t get a full off switch for Meta AI on Facebook or Instagram right now. Meta rolled it into search, chat, and some creation tools. So the answer is annoyng, but simple.
What you can do:
Mute it in Messenger or Instagram DMs.
Open the Meta AI chat.
Tap the name at the top.
Use Mute, Archive, or Delete chat. -
Stop using it in search.
Don’t tap the blue circle or AI prompt.
Use the normal search results when they appear. -
Limit AI features in apps.
Check Settings, then search for things like AI, Imagine, or message suggestions.
These menus move around a lot, so older help pages are often wrong. -
Object to AI data use, if available in your region.
For Facebook or Instagram:
Settings and privacy, Privacy Center, AI at Meta, then look for a form about info used for generative AI.
In the EU and UK, this is more common. In the US, options are less clear. -
Hide AI content where possible.
Long press suggested AI posts or chats.
Tap Not interested, Hide, or similar.
Short version, you can reduce it, but you can’t fully remove Meta AI from the apps rn. If you want, post your phone type and app version and ppl here can give the exact taps.
@waldgeist is basically right that there’s no real master kill switch, but I’d push back a little on one part: “just don’t use it” is not really an opt out, it’s more like avoiding the puddle in your kitchen instead of fixing the leak.
A couple things worth checking that are different from muting/hiding the chat:
- Turn off app updates for a bit if Meta AI only appeared after a recent update. Not a forever fix, obv, but it can stop new UI changes from getting worse.
- Use Facebook/Instagram in a mobile browser instead of the app. The AI stuff is often less shoved in your face there.
- If you use Messenger, switch your default chat habits to SMS/iMessage/WhatsApp/Signal for a while. Sounds dumb, but reducing interaction can stop it from surfacing as aggressively.
- Check your Activity Log and ad settings. This won’t remove Meta AI, but it can reduce some personalization tied to your account behavior.
- If you’re in the EU/UK, use the actual privacy objection form, not just the help page maze. That’s the only semi-real “opt out” route rn.
So yeah, full disable? nope. Reduce exposure? kinda. Meta made this wierdly hard on purpose, imo.
For a cleaner fix, hide Meta AI with a content blocker. Install uBlock Origin in Firefox, open Facebook or Instagram, then use “Block element” on the AI button, search prompt, and chat panel. Save each filter seperately.
This removes the clutter from your screen without changing account settings. Repeat if Meta changes the layout. It works best on desktop and Firefox for Android. It’s not an account-level opt-out, but your daily experience stays mostly AI-free.
Set your expectations low before you start clicking around. What people call an opt out here is really just damage control. The generative AI training objection form and the chat mute button are two completely different things, and mixing them up is where a lot of the confusion in this thread comes from. The form (mostly EU/UK) is about your data. Muting and hiding is about your screen. Neither one deletes Meta AI from the app.
The uBlock idea from @darkhive7465node actually works, but I’d be honest about the upkeep. Meta shuffles class names and button positions pretty often, so element blocking on Facebook tends to break every few weeks and you end up re-selecting the same stuff. If you don’t mind babysitting a couple of filters, fine. If you want set and forget, you’ll get annoyed fast. Desktop holds up better than mobile for this, so don’t expect the phone experience to stay clean.
The piece nobody’s mentioned: the little AI search circle and the ‘ask Meta AI’ prompt are baked into the search bar itself, so there’s no toggle for that one at all. On the app you’re stuck ignoring it. If that specific thing is what’s bugging you most, the browser route @hoshikuzu mentioned is probably your least painful option, since the search bar there is plainer and doesn’t shove the assistant at you the same way.
