I’ve been trying to learn how AI works, but the articles and videos I found are either too technical or too vague. I keep seeing terms like machine learning, neural networks, and large language models, and I’m confused about how they actually fit together. I need a simple explanation so I can understand the basics and know where to start.
Think of AI as pattern learning.
Machine learning:
You feed a system lots of examples. It finds patterns in the data. Then it uses those patterns to make a guess on new data. Spam filters do this. So do Netflix recommendations.
Neural networks:
A type of machine learning. They use layers of simple math functions. Each layer picks up different features. In images, early layers spot edges. Later layers spot shapes, then objects. It sounds fancy, but it is mostly math plus tons of data.
Large language models:
These are neural networks trained on huge amounts of text. Their main job is to predict the next word, or next token. After enough training, they learn grammar, facts, style, code, and common ways people answer stuff. They do not ‘think’ like a human. They predict well.
A simple breakdown:
- Training. Show the model lots of data.
- Adjustment. It makes guesses, checks errors, tweaks internal weights.
- Repeat. Billions of times.
- Use. You type a prompt, it predicts a response.
Why it feels smart:
Because human language has patterns. If a model learns enough of them, the output feels smart. Sometimes it is. Sometimes it is wrong and sounds confident. Thats a big limitation.
If you want the shortest mental model:
AI = pattern matching at scale.
ML = learning patterns from data.
Neural net = a math system used to learn patterns.
LLM = a neural net trained on text.
Best way to learn this stuff:
Start with one example. Spam detection, image labeling, or chatbots. Trying to learn every term at once gets confsuing fast.
Think of it less like ‘building a brain’ and more like ‘training a weird calculator.’
@waldgeist is right that pattern learning is the core idea, but I’d push back a little on ‘AI = pattern matching’ because that can sound too small. Pattern matching is true, but the patterns can get insanely complex, to the point where the system can translate, summarize, code, or describe images. So the basic idea is simple, even if the results look kinda wild.
The cleanest way to separate the terms:
- AI: the umbrella term. Any system doing tasks we associate with intelligence.
- Machine learning: instead of hard-coding every rule, you let the system learn rules from examples.
- Neural networks: one popular way to do machine learning, loosely inspired by neurons, but really just stacks of math.
- Large language models: neural networks specialized in text.
What actually happens inside training is basically this:
the model starts off bad, makes a prediction, gets scored on how wrong it was, then its internal numbers get nudged a tiny bit. Do that over and over on massive datasets and it slowly becomes useful. Not magic, just huge-scale optimization.
The reason people get confused is that AI is not one thing. A chess AI, a TikTok recommendation system, and ChatGPT are all ‘AI’ but they work differently and are built for diff goals.
One more important part: LLMs do not store knowledge like a database in the normal sense. They compress statistical relationships from text into billions of parameters. That’s why they can sound smart but also confidently mess stuff up. They learned what words tend to go together and what answers usually resemble useful answers.
If you want a practical mental model:
- traditional coding = write exact rules
- machine learning = show examples, let system infer rules
- LLM = giant text predictor that became surprisingly capable
Honestly, if you’re learning this stuff, ignore the hype for a bit. Most explainers either oversell it as digital genius or undersell it as ‘just autocomplete.’ It’s closer to autocomplete built at absurd scale, which turns out to be a bigger deal than ppl expected.
A useful way to picture it is not “AI thinks” but “AI builds a map.”
@waldgeist framed it as a weird calculator, which is solid, though I’d slightly disagree on one point: calling it just pattern learning can make it sound passive. Modern models are more like compression engines that turn giant amounts of data into a usable internal map. That map lets them generalize, sometimes really impressively, and sometimes very badly.
Quick mental split:
- AI = broad category
- ML = systems that improve from data
- Neural nets = flexible function approximators
- LLMs = neural nets tuned for language
What matters most is representation. During training, the model is not memorizing every sentence. It is shaping an internal space where related things end up near each other. “King” and “queen” get linked differently than “king” and “banana.” That structure is why it can answer new prompts instead of only repeating old ones.
Why it feels intelligent:
- it handles messy inputs
- it generalizes from examples
- it can chain many small learned associations into one output
Why it fails:
- no built-in truth checker
- weak real-world grounding unless connected to tools
- confidence does not equal accuracy
Pros of “”
- can improve readability if it explains concepts visually
- useful if it strips jargon
Cons of “”
- if it oversimplifies, you leave with fake understanding
- AI topics need examples, not slogans
Best beginner summary:
regular software follows rules
AI learns a shape of rules from data
