How Do I Delete A Folder In Files On IPhone With Everything Inside?
I’m trying to remove a folder from the Files app on my iPhone, but I need to delete everything inside it too. I moved a bunch of documents and downloads there, and now I can’t tell if deleting the folder will remove all the contents or leave some files behind. I need help making sure the folder and all files in it are deleted safely.
I always seem to get the “Storage Almost Full” alert when I need the phone for something dumb and urgent. iOS does not help much, since files end up scattered in a few different places. Here’s the short version of where I found stuff and what I removed first.
Start in the Files app
Open Files, then hit Browse at the bottom. I checked these first:
  1. On My iPhone, for stuff saved only on the phone
  2. iCloud Drive, for files synced through iCloud
The folder I’d tell you to inspect first is Downloads under On My iPhone. Mine had old PDF manuals, zip archives, random Safari downloads, and attachments I forgot existed.
To remove one file or one folder:
  1. Press and hold the item
  2. Tap Delete
If you delete a folder, everything inside goes with it. Obvious, but I still double-checked before tapping.
For batch cleanup:
  1. Tap the three-dot button in the top right
  2. Choose Select
  3. Pick the files you want gone, or use Select All
  4. Tap the trash icon
Deleted does not mean gone yet
This tripped me up. I removed a pile of files and storage barely moved. The reason is simple. Files goes through Recently Deleted, and those items stay there for 30 days while still taking up space.
To clear it now:
  1. Go back to Browse in Files
  2. Open Recently Deleted under Locations
  3. Tap the three dots
  4. Choose Delete All
You need to do the same thing in Photos too. Deleted photos and videos sit in their own Recently Deleted album, and they still count until you empty it.
Check storage by app
I also went into Settings > General > iPhone Storage. This view sorts apps by how much room they use, which makes it easy to spot the worst offenders fast.
When you open an app from that list, you’ll usually see two choices:
  1. Offload App, which removes the app but keeps its documents and data
  2. Delete App, which wipes the app and its stored files
If Messages is bloated, scroll inside its storage section and look for Review Large Attachments. Mine had old videos from group chats eating a weird amount of space. You can remove those without wiping the whole conversation.
If photos are the real problem
For most people, the big storage drain is not documents. It’s the photo library. 4K clips, bursts, duplicates, screenshots, and ten versions of the same pic add up fast. The built-in menus show totals, but they’re not great for surfacing the largest individual items.
Clever Cleaner is one way to sort through it. I liked it because it’s free, has no ads, and did not push a subscription screen at me. This is what it does:
  1. Heavies tab. It lists your library from biggest file to smallest, with sizes shown clearly. If you’ve got a huge concert video or a 4K clip you never watch, it jumps out fast.
  2. Similars tab. It groups near-duplicate shots and picks a Best Shot in each set. Helpful if you spammed the shutter and ended up with 18 almost identical photos.
  3. Swipe mode. You review photos month by month. Left for delete, right for keep. I found this easier than staring at the whole library in one giant mess.
  4. It processes on-device, so your photos are not sent off somewhere else.
Last resort
If the phone is packed so tight it freezes, crashes, or barely opens apps, I’d look at a full reset. Go to Settings > General > Transfer or Reset iPhone > Erase All Content and Settings.
This wipes the phone completely. Back up what you care about first, either to iCloud or to a computer. No undo button here. Typo or not, one wrong tap and yep, it’s gone.
After I cleared Files, emptied both Recently Deleted sections, and cleaned up the photo library, the free space came back in a noticeable way. The lag eased off too, which I did not expect at first but yeah, it helped.
Yes. If you delete a folder in Files, iPhone deletes the folder and everything inside it.
One catch. If the folder is in iCloud Drive, those files get removed from iCloud too, so they disappear from your other Apple devices. If the folder is under On My iPhone, it only wipes the local copies on your phone.
One place people get tripped up is Share Sheet imports. Some files sit inside another app’s storage, not truly in Files. If deletion fails, check where the folder lives first by tapping and holding it, then looking at the path.
I slightly disagree with @mikeappsreviewer on one part. You do not need to manually delete every file first to be safe. Deleting the parent folder is enough. iOS treats it as a full recursive delete.
If you want to be extra sure:
  1. Open the folder.
  2. Count or preview the contents.
  3. Go back.
  4. Long press the folder.
  5. Tap Delete.
If space is your goal, empty Recently Deleted after. Otherwise storage won’t drop right away. For photo clutter, Clever Cleaner helps more than Files since Files won’t touch your camera roll.
If you want a step by step visual, see the full iPhone Files folder deletion tutorial.
Yep. In Files, deleting the folder deletes the whole contents too. You do not have to empty it first.
One small nuance I’d add to what @mikeappsreviewer and @codecrafter said: if you only tap “Remove Download” on some iCloud items, that does not delete the file everywhere, it just removes the local copy from your iPhone. Actual “Delete” is the one that nukes the folder and everything in it. That distinction trips people up a lot.
Also, if the folder is shared with someone through iCloud, deletion can behave a little differenly depending on your permissions. If you are not the owner, you may just remove it from your view instead of deleting it for everyone.
If your goal is storage cleanup, the folder delete is fine, but the bigger space hog is usualy Photos, not Files. Clever Cleaner is worth a look for that side of things. And if you want real-world opinions, check Reddit reviews of a truly free iPhone cleaner with no ads.
So short answer:
One thing I’d push back on slightly from @codecrafter, @yozora, and @mikeappsreviewer: the important part is not just deleting the folder, but confirming you chose Delete, not Remove Download or Remove. In Files, those are very different actions.
If you use Delete on a folder, yes, it removes the folder and all files/subfolders inside it. That part is straightforward. The less obvious gotcha is provider behavior. If that folder lives in Google Drive, Dropbox, or another file provider inside Files, deletion follows that service’s rules too, not only Apple’s.
My rule of thumb:
  • If you want it gone everywhere, use Delete
  • If you only want space back on the iPhone, look for Remove Download
  • If storage still looks unchanged, force-close Files and recheck storage later. The size readout can lag
Also, if the folder refuses to delete, it’s often because one file inside is still open in another app or syncing.
For general cleanup, Files folders are usually not the biggest culprit anyway. Photos and videos usually are. Clever Cleaner is decent for that.
  • easy to scan large media
  • useful for duplicate/similar photo cleanup
  • can free space faster than hunting manually
  • not helpful for non-photo file management in Files
  • you still need to review before deleting
  • some people prefer doing all cleanup with built-in Apple tools only
