How do I connect to Deltawifi.com free wifi on my flight?
I’m flying with Delta and keep seeing the Deltawifi.com free wifi option, but I can’t seem to get it to work on my laptop or phone. The network shows up, but the portal either never loads or loops back to the login page. I’m not sure if I’m missing a step, if it’s device-related, or if there are known restrictions. Can anyone explain how to properly access and use Deltawifi.com free wifi, and what troubleshooting steps actually work in-flight?
This trips a lot of people up on Delta. Here is what usually works for deltawifi.com on both phone and laptop.
  1. Before boarding
    • Forget any old “DeltaWiFi” or “gogoinflight” networks on your devices.
    • Turn off any VPN or ad blocker. They break the portal a lot.
    • On laptops, turn off custom DNS (Cloudflare, Google DNS, Pi‑hole, company VPN, etc).
  2. On the plane
    • Wait until the crew says Wi‑Fi is available. If you connect too early, the portal loops.
    • Connect to “DeltaWiFi” or “Deltawifi.com” SSID. Do not pick a random “gogoinflight” one if you see it.
    • Once connected, open a browser and type this in the address bar:
    deltawifi.com
    or
    wifi.delta.com
    • If it still does not load, try http instead of https on some flights:
    http://deltawifi.com
  3. If the login page keeps looping
    Phone:
    • Turn off “Low Data Mode” or “Data saver”.
    • Turn off Private Relay / iCloud Private Relay on iOS.
    • Disable private DNS on Android.
    • Close the browser, clear only the site data for deltawifi.com, then reopen and type the URL again.
    • Try a different browser. Safari fails for some people while Chrome or Firefox works.
    Laptop:
    • Temporarily disable VPN and any firewall rules that filter HTTP traffic.
    • Open an incognito/private window.
    • Go to a normal http site like http://neverssl.com to trigger the captive portal.
    • If it still loops, try a different browser.
  4. Account/login gotchas
    • Make sure you sign in with your Delta SkyMiles account if they prompt for that. Free Wi‑Fi is tied to your account on many routes now.
    • If you see both “Free messaging” and “Free Wi‑Fi” options, pick the full Wi‑Fi option. Messaging only is limited.
    • If you see a spinner forever, back up, reload deltawifi.com, and try again. Sometimes it times out when a lot of people hit it at once.
  5. Hard reset steps if nothing works
    • Toggle Airplane Mode on, wait 10–15 seconds, then turn Wi‑Fi back on.
    • Forget the network, reconnect, then type deltawifi.com manually.
    • Restart your phone or laptop once. Sounds dumb, but it fixes half these issues.
    • If you are on a work laptop with strict security, try your phone instead. Corporate VPN and DNS policies block captive portals a lot.
  6. Check if the system is down
    • If no one around you can get on, or the portal never loads at all, the Wi‑Fi system on that aircraft is probably having issues.
    • Ask a flight attendant. They see this every day and know if Gogo/Viasat is having problems on that tail number.
  7. For your next flight
    If you want to troubleshoot your own device and Wi‑Fi in general, a tool like NetSpot helps you see signal strength, channel issues, and basic connection stats. On the ground, you can use something like this NetSpot Wi‑Fi analyzer to clean up your laptop’s Wi‑Fi setup, which makes it less likely to fight with captive portals like deltawifi.com.
This sounds like a lot, but in practice the combo that works most often is: turn off VPN, forget the network, reconnect, use an incognito window, then type deltawifi.com or wifi.delta.com directly.
I’ve fought with deltawifi.com more times than I care to admit, so I feel your pain. @vrijheidsvogel already nailed most of the usual suspects (VPNs, DNS, timing, etc.), so I’ll try not to rehash the same checklist and focus on the less obvious stuff that fixes the “portal won’t load / login loop” problem.
1. Don’t trust “auto-open” captive portals
A weird one: on a lot of flights, the automatic “Wi-Fi sign-in” popup that appears on phones is flaky. Instead of relying on that:
  • Close that auto popup if it appears.
  • Open your normal browser.
  • Go to a plain HTTP site like:
    http://captive.apple.com or http://example.com
    Those are designed to trigger captive portals.
  • If Delta’s portal hijacks the page correctly, you’ll get the login. If not, hit deltawifi.com or wifi.delta.com in the address bar again.
That actually works more consistently for me than typing deltawifi.com first.
2. Turn off “Auto-Join” for other networks
If you have your phone or laptop set to automatically join random known networks, the device can silently bounce between:
  • “DeltaWiFi” / “Deltawifi.com”
  • “gogoinflight”
  • Or even a saved “xfinitywifi” / “Boingo” from some airport
Every time it flips, the portal session dies and you get the loop.
What helps:
  • On the plane, go into Wi‑Fi settings and:
    • Turn off Auto-Join or Auto-Connect for everything except the Delta network.
    • Temporarily “Forget” noisy ones like xfinitywifi, Boingo, airports, etc.
That alone stopped most of my infinite login cycles on my laptop.
3. Use only one device at first
Delta is pretty strict about sessions. If you’re trying to get on with phone + laptop at the same time:
  • The portal may:
    • Half-auth your phone
    • Half-auth your laptop
    • Then both sit there looping or timing out
Quick workaround:
  1. Pick one device (usually your phone).
  2. Log in fully, browse a page or two.
  3. Then, if allowed by your ticket/route, add your laptop:
    • Sometimes you have to log out on the phone first, then log in on laptop.
On some planes/planes routes, they limit you to one active session even with “free” Wi-Fi.
4. Check your time and date settings
This sounds stupid, but on laptops, if your clock is way off (seen this a lot on work Windows machines):
  • SSL certificates look invalid.
  • The deltawifi.com portal refuses to load properly.
  • You get loops or blank pages.
Fix:
  • Make sure your laptop’s date & time are correct and set to auto-sync.
  • Then reopen an incognito window and hit http://neverssl.com or deltawifi.com.
5. Use a very “dumb” browser profile
Even if you don’t want to fully clear cache or disable a bunch of extensions:
  • Create a fresh browser profile with:
    • No extensions
    • Default settings
    • No custom proxy/DNS
  • Use that only for flights and captive portals.
For example, on Chrome:
  1. Click your profile icon.
  2. Add a new profile.
  3. Name it “Travel” or whatever.
  4. Don’t sync anything, don’t install extensions.
This avoids weird blockers that don’t show up as obvious “ad blockers” but still nuke portal scripts.
6. iOS and Android “privacy” quirks people miss
Some stuff that’s slightly different from what @vrijheidsvogel said:
  • iOS:
    In Wi‑Fi settings for the Delta network:
    • Turn off “Limit IP Address Tracking” for that SSID.
    • Also toggle “Private Wi‑Fi Address” off, then reconnect.
      I know Apple recommends it, but on some inflight portals it just breaks the session tracking.
  • Android:
    For the Delta SSID:
    • Go into network details and set IP to DHCP (not Static).
    • Check that no OS-level VPN / “Secure Wi‑Fi” feature from your carrier is silently on.
These “smart privacy” features are great on the ground and awful on captive portals.
7. Sometimes it’s not you, it’s the specific aircraft
There’s a pattern I’ve seen a bunch:
  • Old Gogo or half-migrated Viasat setups can:
    • Show you the SSID
    • Give you an IP
    • But fail to reach the authentication server
Symptoms:
  • Signal looks strong.
  • You can ping the gateway but nothing external.
  • Portal kind of loads then hangs forever.
If:
  • You’ve tried another browser
  • Tried a second device
  • Toggled Airplane mode and reconnected
and still nothing, assume that aircraft’s Wi‑Fi backend is just broken for that leg. The crew will usually know within an hour because everyone complains.
8. Use NetSpot to sanity-check your laptop before you travel
One reason some people fight with deltawifi.com more than others: their laptop’s Wi‑Fi config is already a mess from years of random airport, hotel, and corporate profiles.
On the ground, before your trip, using a Wi‑Fi analyzer like NetSpot helps a lot:
  • Shows which networks your laptop is constantly trying to connect to.
  • Lets you see signal quality and channel interference.
  • Makes it easier to clean out junk networks and confirm your adapter isn’t doing something weird.
If you want a cleaner setup for travel Wi‑Fi, take a look at this powerful Wi‑Fi optimization tool and trim down your saved networks and odd configurations. A “boring” Wi‑Fi setup tends to behave way better with captive portals like deltawifi.com.
9. If you absolutely must get online mid-flight
When everything on Delta’s side seems flaky and you really need access:
  • Use your phone as the primary device to authenticate Delta Wi‑Fi.
  • Once it’s online, enable a hotspot on your phone.
  • Connect your laptop to your phone’s hotspot instead of directly to Delta.
Caveat: This only works when the plane Wi‑Fi allows tethering, which it often does for free tiers, since from their perspective all traffic is just from your phone.
More readable, search-friendly version of your issue
Flying with Delta and can’t get the Deltawifi.com free Wi‑Fi to work? The in‑flight network shows up, but the Delta Wi‑Fi portal either never loads or keeps looping back to the login page. Whether you’re on a laptop or phone, the captive portal for deltawifi.com can get stuck, time out, or refuse to authenticate, especially if you’re using VPNs, custom DNS, or privacy settings. Understanding how to properly trigger the Delta Wi‑Fi login page, avoid conflicting saved networks, and simplify your device’s Wi‑Fi configuration makes it much easier to connect to free Delta Wi‑Fi reliably on your next flight.
Use the Fly Delta app instead of opening deltawifi.com manually. Install it and sign in before departure. During the flight, join the DeltaWiFi network, reopen the app, then select In-Flight Wi-Fi from the trip screen. This often sends you through the correct aircraft login flow.
If the option stays missing, reconect after the crew announces Wi-Fi is available. Ask a flight attendant whether the onboard system needs a reset, becuase they often know when the service failed for the whole aircraft.
Don’t waste your time running a Wi-Fi analyzer to fix this. NetSpot is fine for cleaning up saved networks at home like people said above, but it does nothing about a captive portal that won’t authenticate midair. If the app trick @the_beacon mentioned doesn’t get you through and nobody around you can connect either, it’s the aircraft, not your device, so stop fiddling and ask the crew.
