Coursiv Ai Course Review
I recently completed a Coursiv AI course and wrote a detailed review, but I’m not sure if I’m being too harsh or missing important points. I’d really appreciate help from others who have taken the same course or know the platform well. What should a useful, honest Coursiv AI course review include so it actually helps future students and stays fair to the creators?
I took the Coursiv AI course a few months ago and wrote a long review too, so here is my take. Use what matches your experience and ignore the rest.
What I liked:
  • Structure was clear. Intro to AI, then prompt basics, then some workflow stuff.
  • Good for people who never touched ChatGPT before.
  • The short video format helped. Easy to watch 2 or 3 in a break.
  • Some templates were useful, like email drafting and content outlines.
What I did not like:
  • Lots of surface level content. If you already use AI tools weekly, most lessons feel like “yeah, I know.”
  • Not much about limits, hallucinations, privacy, or evaluation. That makes the course feel like marketing.
  • Almost no hands on projects with feedback. You watch, do a quick exercise, then move on. Hard to know if you improved.
  • Examples focused on marketing and content creation. Little on engineering, data work, or serious workflows.
If your review:
  • Mentions both strengths and weaknesses.
  • Gives 2 or 3 concrete examples where the course helped you.
  • Gives 2 or 3 specific gaps or issues, like missing topics, shallow modules, outdated info.
Then you are not too harsh.
Stuff you might add if you have not:
  • Who the course fits best. Total beginners, non technical staff, etc.
  • Where someone should go next after finishing. For example, “After this, take X for prompt engineering” or “Use Y to learn about evals.”
  • Any data you have. For example:
    • Time to finish: “Took me about 6 to 8 hours.”
    • How many lessons felt new for you: “For me, only around 30 percent felt new.”
    • Whether you changed your workflow after: “I now use AI for A, B, C, which I did not do before.”
If you post a short excerpt of your review, people can react to the tone. In my case I thought I was too harsh, then others said I was still too soft on the lack of depth, so outside feedback helped a lot.
Small tip. If you wrote lines like “this course is useless” or “total waste of money,” try to replace them with “this did not help me because X, Y, Z” and what you expected instead. That keeps it fair and more useful for others reading it.
If you’re worried about being “too harsh,” you’re probably already more fair than most course reviews on the internet.
I had a similar experience with the Coursiv AI course and I’ll be a bit more blunt than @nachtschatten:
1. It’s basically “AI for people who’ve never opened ChatGPT.”
If your review expects:
  • depth on model behavior
  • real coverage of hallucinations/privacy
  • structured practice with actual feedback
then yeah, you probably sounded harsh, but not unfair. The course mostly sells the idea of “AI can help you” rather than seriously teaching how to use it in complex workflows.
2. Don’t just list what’s bad. Anchor it to your expectations.
Instead of:
  • “This was way too basic”
Try:
  • “This was pitched as ‘advanced AI productivity’ but 80–90% of the content overlapped with beginner YouTube videos (prompts like ‘act as X’ and generic email templates). I expected deeper coverage of A/B testing prompts, evaluation, and systematizing workflows.”
You’re not attacking, you’re comparing marketing vs reality.
3. Point out actual moments where it helped you, even if they’re small.
If you:
  • adopted 1 or 2 templates into your daily work
  • changed how you structure prompts for email / outlines
  • discovered a new use case (like summarizing meeting notes)
mention that explicitly. That makes any criticism land as considered, not ranty. Something like:
“Even though I already used AI a lot, the lesson on batching content requests did help me speed up my blog outline process.”
4. A place where I slightly disagree with @nachtschatten:
They framed it as good for total beginners. I’d say: good for motivated but slightly anxious beginners. If someone is already comfortable watching 2–3 decent YouTube creators on AI, this course will feel redundant. If you think the marketing implied it was “cutting edge,” say that mismatch clearly.
5. A few specific angles you might still be missing in your review:
  • Up‑to‑dateness:
    • Were they using old model names, outdated UI, or ignoring current features like custom GPTs, agents, or tools?
    • If so, that’s worth a sentence: “Several examples were tied to older versions of the tools, which made parts feel dated.”
  • Breadth vs depth:
    • Did they touch too many topics shallowly instead of going deep on a few useful workflows?
    • You can phrase it like: “The course tries to cover writing, marketing, brainstorming, and productivity, but none of these sections go past the basics, so nothing felt truly ‘mastered’ at the end.”
  • Transfer to your real work:
    • Did you change anything substantial in your actual day‑to‑day after finishing?
    • If not, write that: “A week later my workflow looks almost the same, except I occasionally reuse one template from the course.”
  • Value for money:
    • Don’t just say “not worth it.” Add context.
    • Example: “At price X, I expected more project-based work and at least one module on evaluating AI output quality. As it stands, the value feels closer to a curated playlist of beginner videos than a full course.”
6. A simple structure that keeps you fair but honest:
  1. Who I am / my experience with AI before the course
    • 1–2 lines. “I use AI for work a few times a week,” or “I was totally new,” etc.
  2. What the course does well
    • Clear structure, short videos, a couple of templates you liked.
    • 2–4 bullet points, max.
  3. Where it falls short
    • Tie each criticism to:
      • what was promised
      • what actually happened
      • what you expected instead
  4. Who I think this is for
    • Example: “If you’ve never used ChatGPT and feel intimidated by it, this might be a gentle on‑ramp. If you already use AI weekly, you’ll likely feel it’s too basic.”
  5. What I’d recommend instead / next steps
    • Not required to name brands, but stuff like: “After this, I’d suggest a more hands‑on course with projects, or just following X/Y creators who go deep on real workflows.”
7. Quick tone check:
If your review says things like:
  • “total scam,” “useless,” “trash,” “they just wanted money”
try dialing that back into specifics:
  • “Content level did not match the ‘advanced’ marketing”
  • “Felt more like an extended intro than a full course. If you already use AI, this probably isn’t for you.”
Direct, but not a flame thrower.
You’re not being too harsh if:
  • you’re concrete
  • you separate “not for me” from “objectively bad”
  • you give people enough detail to decide if they might still find it useful
If you want feedback on tone specifically, paste 2–3 paragraphs from your review that you’re most worried about. People can usually spot instantly where it sounds fair vs where it turns into venting.
You’re not being too harsh just because you criticized it. With courses like the Coursiv AI course, the key is: are you critiquing the course, or punishing it for not being the thing you actually needed?
Instead of repeating what @nachtschatten already covered, here are a few extra angles you can fold into your review so it feels balanced and actually useful to readers:
1. Separate “content quality” from “instructional design”
Two different questions:
  • Was the information correct, current and non‑trivial?
  • Even if basic, was it delivered in a way that made it easy to learn and apply?
You can absolutely say something like:
  • “Content level is beginner, sometimes very superficial, but the pacing and clarity are solid. If you are brand‑new, the structure will probably feel reassuring.”
That nuance keeps it from sounding like a rant.
2. Talk about time cost as much as money
Most reviews fixate on price. A sharper lens is: was it the best use of your hours?
Good wording for your Coursiv Ai Course Review might be:
  • “If you have 3–4 hours, a curated YouTube playlist will give you roughly the same skills.”
  • Or, if it was efficient: “It compressed what would have taken me weeks of random tutorials into an afternoon.”
Readers care a lot about this and it signals you’re thinking practically, not just venting.
3. Assess how “opinionated” the course is
Useful courses usually give you a system or a point of view. Weak ones just list features.
Ask yourself:
  • Did Coursiv give you a framework for using AI across tasks, or just a tour of prompts?
  • Did it help you decide what not to use AI for?
You might write:
  • “The Coursiv AI course is more a feature tour than a clear methodology. I finished with more ideas, but not a strong system for deciding when AI is actually the right tool.”
That is sharper than “too basic” yet still fair.
4. Zoom in on friction points
Where did you actually feel annoyed or blocked?
Examples:
  • Confusing portal or bad navigation
  • No transcripts / subtitles
  • Exercises that felt fake or irrelevant to real work
  • Q&A support that never answered specifics
Mentioning 2 or 3 of these is more persuasive than general frustration:
  • “Several assignments felt like busywork, such as rewriting generic emails, instead of mirroring real‑world projects. That contributed a lot to my disappointment.”
5. Compare your before/after confidence
This is a different angle from skills. Even if you learned nothing new, did it shift your confidence, mindset, or sense of safety around AI?
  • “Skill‑wise, I learned almost nothing new. Confidence‑wise, I can see how a beginner might feel much less intimidated by AI after this.”
That line alone makes your review sound measured.
6. Pros & cons section for clarity
You mentioned not wanting to be too harsh. A simple bullet list near the end really helps:
Pros of the Coursiv AI course:
  • Clear, digestible lessons for absolute beginners
  • Friendly explanation of AI concepts without heavy jargon
  • Good starting point if you are anxious about using tools like ChatGPT
  • Some ready‑made prompts and templates you can plug in immediately
Cons of the Coursiv AI course:
  • Very shallow for anyone already using AI weekly
  • Limited coverage of advanced workflows, prompt iteration, or evaluation
  • Light or outdated handling of issues like hallucinations and privacy
  • Feels closer to curated beginner content than a deep, project‑based program
Notice how this matches some of what @nachtschatten said but keeps your own voice.
7. A place I’d gently disagree with others
Some people frame it as “good for total beginners.” I’d add a caveat: it also depends on how self‑directed the learner is.
  • A highly self‑motivated beginner might be better off exploring high‑quality free content plus experimentation.
  • A more structured, checklist‑type person may actually benefit from having a linear path like this, even if the material is basic.
Calling that out in your review helps readers self‑select.
8. Wrap-up suggestion
End your Coursiv Ai Course Review with something like:
“If you are curious about AI but have never touched a tool like ChatGPT, this course can serve as a gentle, structured introduction. If you already use AI at least a few times a week, you will likely find it too introductory and should look for more advanced, workflow‑driven material instead.”
That closing line keeps it honest without sounding like you are out to punish the creators.
Overall: keep your concrete examples, tie everything to expectations and actual outcomes, and add those pros/cons. That balance will do more for readers than softening your criticism for its own sake.
Your draft already hits content vs design, time cost, POV, friction, confidence, pros and cons, learner fit, and a clear close.
Simpler path. Use a 20 minut scorecard. Write your goal in one line. List five expected outcomes, tie to teh syllabus. For each, mark hit or miss with one evidence, like Lesson 4 at 07:12. Tally hits out of five. Under 3, warn beginners. 3 or 4, ok for newbies. 5, strong intro. End with one sentnce on who gets value and who skips.
