Can someone help me with error code 8379xnbs8e02328ws?
I ran into error code 8379xnbs8e02328ws while trying to use my app, and it suddenly stopped working. I’m not sure what triggered it, and I need help figuring out what this error means, what causes it, and how to fix it so I can get things running again.
8379xnbs8e02328ws does not look like a standard system error. It looks more like an app-specific ID. So the fix depends on the app, device, and what happened right before it failed.
Start with the fast checks.
  1. Force close the app, then reopen it.
  2. Restart your phone or PC.
  3. Check your internet. Switch Wi-Fi to mobile data, or the other way around.
  4. Update the app.
  5. Clear the app cache. On Android, go to Settings, Apps, your app, Storage, Clear Cache.
  6. If that fails, reinstall the app. Make sure your account is backed up first.
  7. Check storage space. Many apps fail when free space drops too low, like under 1 GB.
  8. Check the app’s status page or social accounts. If their servers are down, the code means nothing on your side.
Common causes:
  • corrupted cache or local app data
  • expired login token
  • bad update
  • server outage
  • permission issue
  • device time/date mismatch, weird but it happens
If you want a real answer, post:
  • app name
  • phone/PC model
  • OS version
  • exact step when the error appears
  • screenshot if possble
If this is your own app, search your logs for that exact code string. It looks like a custom exception tag, not a built-in error.
That code looks less like an ‘error code’ and more like a trace ID or backend reference. I mostly agree with @cacadordeestrelas on that part. Where I slightly disagree is reinstalling right away. If the app stores local drafts, downloads, or unsynced data, reinstalling can make a bad day worse.
What I’d check next:
  • Look for the exact time it failed in your device logs.
    • Android: use Logcat if you can
    • Windows: Event Viewer
    • iPhone: Analytics Data
  • Check whether the app lost a permission after an OS update. Camera, storage, notifications, background data, location, etc.
  • If you use VPN, ad blocker, private DNS, firewall, or antivirus, disable it tempraorily. A lot of apps break in weird ways from that.
  • Make sure date/time is set automatically. Auth systems can fail from clock drift.
  • Try the same account on another device. If it fails there too, it’s probably account-side or server-side.
  • Try a different account on the same device. That helps narrow it down fast.
If this is your own app, search the code in:
  • client logs
  • crash reporting
  • API gateway logs
  • auth service logs
If you post the app name, device, OS version, and what button you tapped right before it died, people can probly narrow it down a lot more.
