Can someone help me develop Oxzep7 software?
I started planning Oxzep7 software, but I ran into problems with the core features, development workflow, and technical setup. I need help figuring out the best way to build it, avoid costly mistakes, and move the project forward efficiently. Looking for advice on software development, architecture, and next steps.
Start with scope. If Oxzep7 does 10 things, cut it to 3. Pick one core user flow. Example. User signs up, creates one record, exports one result. Ship that first.
Use a boring stack. It saves money.
Frontend, React or Vue.
Backend, Node with NestJS or Python with FastAPI.
Database, Postgres.
Auth, Clerk or Auth0 if you need speed.
Hosting, Docker plus Render, Fly.io, or AWS if you already know it.
Set rules early.
Write a one page spec.
List users, inputs, outputs, edge cases.
Define what done means for each feature.
Build order:
  1. Data model
  2. Auth
  3. Core API
  4. Basic UI
  5. Logs, tests, backups
  6. Billing, if needed
Workflow matters more than tools.
Use GitHub.
Main, dev, feature branches.
PRs for every change.
CI running tests and lint on each push.
Track work in Linear, Jira, or GitHub Projects.
Avoid these mistakes.
Custom auth.
Microservices too early.
Premature scaling.
No analytics.
No backups. This one hurts lol.
If you post your core features and target users, ppl here can give a much tighter plan.
I’d add one thing @andarilhonoturno only touched indirectly: before you pick stack or workflow, figure out the riskiest assumption and test that first. Not the easiest feature. The thing most likely to kill Oxzep7.
Example:
  • if the product depends on complex data processing, build a tiny command line prototype first
  • if it depends on users collaborating, mock that flow in Figma before coding
  • if it depends on integrations, test those APIs now because vendors love terrible docs lol
I actually kinda disagree with “ship fast” if it means shipping the wrong foundation. Fast is fine, but only after proving the hard part is even viable.
What usually saves money is:
  • architecture review before coding
  • clear non-functional requirements like speed, privacy, uptime
  • deciding what can be manual at first
A lot of founders overbuild admin panels, roles, settings, dashboards, all that fake-progress stuff. If Oxzep7 solves one painful problem, make that one thing stupidly solid.
Also, write failure scenarios, not just feature lists:
  • what happens if payment fails
  • what happens if an import is malformed
  • what happens if two users edit the same thing
  • what happens if the service goes down at 2am
If you want real help, post 3 things:
  1. who uses Oxzep7
  2. what they do step by step
  3. what part seems technically scary rn
That’ll get you much better advice than generic “use React + Postgres” answers tbh.
I mostly agree with @andarilhonoturno on testing the scary part first, but I’d push even harder on defining boundaries before architecture.
For Oxzep7 software, split the project into 3 boxes:
  1. Core value engine
    The one action users absolutely need.
  2. Support systems
    Auth, billing, admin, notifications, logs.
  3. Nice-to-haves
    Dashboards, analytics, role complexity, advanced settings.
Build box 1 brutally small. Not “MVP” in the vague startup sense. I mean one workflow that can be demoed, tested, and debugged end to end.
A practical way to avoid bad decisions:
  • write a one-page technical brief
  • list expected users, load, sensitive data, integrations
  • define what must be reversible later and what won’t be
That last part matters a lot. Database choice, tenancy model, and data schema are expensive to change. UI library is usually not.
Pros for Oxzep7 software:
  • easier to focus if you lock one use case
  • cheaper QA and deployment early
  • fewer hidden dependencies
  • tempting to overgeneralize too early
  • unclear scope can poison every technical choice
  • premature scaling work burns time fast
One thing I disagree with a bit: Figma helps, sure, but some products only become clear when real data hits the system. In those cases, a thin vertical slice beats polished mockups.
If you want sharper advice, post:
  • single main workflow
  • expected traffic
  • web, mobile, or desktop
  • any compliance/security constraints
  • team skillset
That will narrow the right build path fast.
