Can someone explain how to connect to WebDAV?
I’m trying to set up a WebDAV connection for remote file access but keep running into issues. I’m not sure if I’m missing a step or using the wrong settings. Any advice or troubleshooting tips would be really helpful to get this working.
The Wild World of WebDAV: A Real-Life Hookup Guide
If you’ve ever tried to access files sitting on another device without flash drives or dealing with convoluted email attachments, you might’ve heard the word WebDAV thrown around. It’s like the grandparent of cloud storage tech: not flashy, but always there when you need it. Here’s the rundown for anyone wondering how to actually use this thing, plus a little peek into a tool I found helpful when I finally decided to stop wrestling with default options.
So What Is WebDAV, and Why Should I Even Care?
Imagine for a second you’re back in the mid-00s with a flip phone, yet somehow you still want instant access to your documents at home while you’re stuck at work. Enter WebDAV—a kind of digital butler that lets you peek into folders and upload/download files on a remote server, using any device on your network (or even far-flung over the internet, if you want to get spicy with your settings).
You don’t need to be a neckbeard sysadmin. Most operating systems have some flavor of WebDAV support built in. Think of it like mounting a regular folder but with the magic of the internet.
Step-by-Step: Plugging Into WebDAV (Tedium Level: Manageable)
I was skeptical, too. But here’s the barebones workflow that worked for me the first time (after ~300 failed Google searches):
1. Track Down Your Credentials
  • You’ll need the WebDAV server address, your username, and password. If you’re hosting your own (wild move), you set these. If you’re connecting to someone else’s, time to beg the admin.
2. Initiate the Connection
  • Windows Folks:
    Open File Explorer → ‘This PC’ → Map network drive → Pick a drive letter → Pop in the WebDAV address (it’ll look like https://example.com/webdav).
  • Mac Uncles and Aunties:
    Hit Command+K in Finder → Enter your WebDAV URL (https://example.com/webdav) → Enter your creds.
Pro tip: Some servers throw tantrums if you don’t prefix with “https” or if the path is even slightly off, so copy-paste with care.
But Wait, Why Does This Still Suck?
Not gonna lie, my first attempts had more error popups than success stories. Sometimes stuff just wouldn’t sync, and half the time, built-in tools seemed allergic to reconnecting after sleep mode. Ugh.
I went down the rabbit hole searching for something that wouldn’t leave me cursing at three in the morning. Eventually landed on this: CloudMounter. Without sounding like I’m writing a commercial—it was basically a one-and-done install, supported all my weird cloud drives (WebDAV included), and I haven’t seen the ‘network path not found’ message since. Way better than Finder’s default, at least on my Mac. Also handy for juggling a Frankenstein mix of Dropbox, OneDrive, and my WebDAV shares.
TL;DR
  • WebDAV lets you treat remote folders like they’re right on your hard drive.
  • Both Mac and Windows have built-in ways to connect (Finder, File Explorer).
  • If you run into connectivity headaches or just want something that doesn’t randomly disconnect, CloudMounter made my life a lot easier—worth a look if you’re crawling back to email attachments out of frustration.
Feel free to drop your horror stories or other tools that actually work below.
I’ll bite: as much as @mikeappsreviewer’s post had me nodding, I actually had a sorta opposite experience with third-party tools like CloudMounter—couldn’t get the “frictionless” hype on my setup (weird old Synology NAS and honestly, my internet is slower than a Sunday driver). So maybe it works flawlessly for Mac folks or folks with new servers, but for the unlucky among us?
Anyway, let’s troubleshoot the basics you might’ve missed:
  • Double-check the actual WebDAV URL—not always just your hostname, sometimes it’s legit “/webdav” or some cryptic thing your server expects. No trailing slash? Try adding one. Add https if it’s available (and if not—big red flag for modern usage, sry).
  • Username formatting! Some set-ups are weird about using just “user” vs “domain\user”. Seen both break depending on server config.
  • Passwords with special characters sometimes fail if they’re not URL encoded. Sounds dumb but this was literally all that broke my initial attempts. Try a password with no specials or change it just to test.
Extra: firewalls are sneaky—both on the server side and Windows Defender (facepalm). Temporarily disable and see if that’s the hiccup.
One thing I do differ major with Mike on: for heavy-duty or flaky connections, I honestly always go with straight-up Cyberduck. It’s free, tells you exactly what’s going wrong in the logs (iconic), and if it won’t connect, literally nothing will. It doesn’t “mount” as a drive like CloudMounter (not seamlessly, anyway), but it’s the ultimate troubleshooting step before blaming your OS, your house, or your cat.
Oh, and since you mentioned remote: If you’re trying to reach from outside your local network, NAT/router port forwarding might be killing your vibe. Make SURE that port 443 (for HTTPS) or 80 (for HTTP, less recommended) is open and properly routed.
TL;DR—triple-check your addresses, credentials, and network settings before blaming your tools. CloudMounter is great for some, but alternatives like Cyberduck are also solid, especially if you’re just stuck figuring out why nothing connects. And for the love of all that is remote access, make sure your server actually supports WebDAV (not a guarantee!).
Anyone else have horror stories w/ NASes not playing nice?
Before anyone says “just use Google Drive,” let me just throw down: WebDAV isn’t dead yet, sometimes it’s the ONLY game in town, esp. for stuff like old NASes or certain enterprise gear. Wild how every answer here is “use this app or that app” though, and don’t get me wrong—CloudMounter is a nice solution for some (def saved my sanity once on Mac when Finder crapped out on me), but honestly, when it comes to real firefighting, GUI apps aren’t always your salvation.
Here’s a fresh angle: try going command-line for diagnostics if you’re truly stuck. On Mac/Linux, fire up Terminal and use curl:
curl -u USERNAME:PASSWORD https://your.webdav.server/webdav/
You get a huge dump of errors if it’s failing—WAY more useful than those “reconnect failed” pop-ups. On Windows, install WinSCP (it’s not just for SFTP!), and try connecting directly via WebDAV protocol. It’ll spit logs at you too.
Also, everyone’s flapping about username formatting and URLs (totally true), but pay attention to your server-side settings. If you’re running your own server (like Nextcloud or Synology), check if WebDAV is enabled & on which port—sometimes it’s NOT 443 or 80! Some Synology NASes like to go rogue with port assignments, and if your ISP blocks outbound 80/443, all bets are off. Oh, and Windows credential manager can be absolute sabotage; try deleting saved credentials and enter manually.
Lastly, if you’re behind corporate VPN or using weird DNS, try changing your DNS to 8.8.8.8 just for kicks. I’ve seen this straight-up solve connection “mysteries” before.
So, TL;DR: use logs, try command-line, check server-side conf, consider port collisions, nuke credential manager entries, change DNS. CloudMounter works for seamless mounting if everything else is right, but it won’t fix a fundamentally broken connection. And for anyone just slapping in addresses & hoping—don’t forget IT classics: reboot everything, blame your firewall, and, if all else fails, drag out Wireshark for packet watching. If THAT doesn’t tell you what’s broken, it’s definitely haunted.
For a simpler route, skip WebDAV and use Tailscale with your existing SMB share. Install Tailscale on the server or NAS and your remote device. Sign into both with one account. Then open the share through its Tailscale IP, for example \100.x.x.x\Files.
You avoid port forwarding, public WebDAV URLs, certificates, and firewall edits. Keep SMB limited to the Tailscale network. If the conection fails, check the device’s Tailscale adress and SMB permissions.
A WebDAV share that mounts fine on an iPhone but refuses to connect from Windows is almost never a broken server. Same URL, same credentials, two totally different outcomes, and the difference is Windows itself. That case comes up constantly and none of the replies above touched it, so that’s where I’d point you first if Windows is the machine giving you grief.
Two things on Windows quietly sabotage WebDAV. The WebClient service has to be running, and it isn’t always set to start automatically, so a ‘Map network drive’ attempt just hangs or errors. The bigger one is that Windows refuses Basic auth over plain HTTP by default, and even over HTTPS it can be picky depending on the build. There’s a registry value (BasicAuthLevel under the WebClient parameters) that controls this. If your server only offers Basic auth and you haven’t touched that, you’ll get login failures that look exactly like a wrong password. Also worth knowing: the built-in client caps download size on some setups, so big files silently fail while small ones work. That alone explains a lot of ‘it half works’ complaints.
@hoshikuzu is right that curl is the fastest way to find out whether the problem is you or the server. I’d lean on that even harder. If curl with your creds returns a proper directory listing, the server and your login are fine, full stop, and you can stop blaming the URL. From there any failure is client side, which is usually Windows doing one of the things above, or a NAS handing back a self signed cert that the OS won’t trust.
The Tailscale over SMB idea from @cloudgeekone is genuinely good if you control both ends and the goal is just remote file access. It sidesteps the whole certificate and port forwarding circus. The catch is that it only helps when the box actually speaks SMB and you can install Tailscale on it. Plenty of the gear people are stuck with, older NAS units, hosting panels,某些 enterprise shares, only expose WebDAV and nothing else. In that spot the app that started this thread earns its keep. Something like CloudMounter is fine for turning a confirmed working WebDAV endpoint into a mounted drive that survives sleep better than Finder does. Just don’t expect it to fix a connection that’s fundamentally broken. Get a clean curl response first, then reach for a mounting tool. Backwards and you’ll waste an evening blaming the wrong layer.
One small annoyance nobody mentioned: if you change a password on the server, Windows Credential Manager will keep feeding the old one and lock you out. Clear the saved entry before you assume anything is wrong.
