Can I use my laptop as a monitor for a dual-screen setup?
I’m trying to set up a dual monitor workspace and I’m wondering if I can use my laptop as a second screen for my desktop. I already have both devices, but I’m not sure what cables, settings, or software I need to make it work. I need help figuring out the easiest way to connect them and whether this setup is even possible.
You can use a laptop like a second screen, sort of. The big catch is what you mean by 'second screen.'
I messed this up the first time. I took an HDMI cable, ran it from one computer into my laptop, and expected the laptop to behave like a monitor. Nothing happened. I thought the cable was bad. Nope. On most laptops, the HDMI port is output only, not input. So it sends video out to another display, but it does not take video in from your desktop or another laptop. This gets repeated over and over in forum threads and Reddit posts.
What works in real use
The route I had better luck with was wireless display support or screen-sharing apps.
On Windows, I used 'Project to this PC.' Both machines were on the same Wi-Fi network. After turning it on, my main computer extended its desktop to the laptop, close enough to a normal second monitor for everyday stuff.
For me, it was fine for web tabs, Discord, docs, Spotify, terminal windows, and random side tasks. I would not use it for fast games or editing video. There was always some lag, not huge, but enough to get annoying fast.
If you're on a Mac, Sidecar is the smoother option when the second device is an iPad. Mac-to-Mac is a bit less clean unless you add extra software. I tried to keep it simple and still hit limits there.
Setup things I wish I fixed sooner
  1. I raised the laptop a little above the main monitor. My neck stopped complaining after day one.
  2. Use extend mode, not mirror mode. Mirror mode gets old fast unless you're presenting something.
  3. If the cursor feels wrong when moving between screens, change the display layout in your system settings. I had mine reversed for an hour and it felt broken.
  4. If you're using wireless display tools, wired Ethernet on both devices helped a bit with delay. Not perfect, still better.
Apps I tested
I tried SpaceDesk and Deskreen before I gave up and bought a cheap portable monitor. For temporary use, both were decent. Setup was easy, and they worked well enough for spare windows, chat, reference docs, and other low-stakes stuff.
If your goal is a clean long-term dual-screen setup, a real monitor is easier. If you only need extra space once in a while, the laptop trick does the job. Mostly.
Short answer, yes, but not with a normal HDMI cable.
@mikeappsreviewer is right about the big trap. Most laptops do not accept video input. Their HDMI port sends signal out. It does not work like a monitor port.
If you want the laptop screen for your desktop, your best options are these:
  1. Capture card route.
    Plug the desktop HDMI into a USB capture card, then into the laptop. Open preview software on the laptop. This shows the desktop feed. It works, but it is not a true second monitor. Your desktop sees it like a cloned output, and latency is usally there.
  2. Remote desktop route.
    Run remote desktop software from the laptop into the desktop and keep one app full screen. This is better for admin work, coding, docs, email. It feels weird for drag-and-drop across screens, tho.
  3. If your desktop has a spare GPU output, get a cheap monitor.
    This is the clean fix. Used 22 to 24 inch monitors are often $30 to $80 local. Less hassle, less lag, less jank.
One thing I disagree on a bit with @mikeappsreviewer, wireless display is fine for temp use, but on crowded Wi-Fi it gets annoying fast. If you work all day like this, it gets old.
If you want smooth dual-screen behavior, a real monitor wins. If you want a stopgap, use remote desktop or a capture card.
You can, but I’d frame it differently than @mikeappsreviewer and @suenodelbosque. The real question is whether you want the laptop to act like a true monitor, or whether you just want more usable screen space.
One option people forget is software KVM and shared-workflow tools, not display-casting. Stuff like Mouse Without Borders, Barrier, or Synergy lets you keep the desktop and laptop as two separate computers, but use one keyboard and mouse across both like they’re one setup. Clipboard sharing too, sometimes file drag/drop depending on the app. It does not turn the laptop into a literal second display, but for a lot of work setups it feels close enough and is way less flaky than trying to force video into a screen that was never built for it.
Honestly, I kinda disagree with the idea that you need to chase the ‘fake second monitor’ setup at all costs. If the laptop already has its own CPU, browser, apps, and storage, sometimes it’s smarter to use it as an actual second machine. Put Slack, docs, music, dashboards, email, Teams, whatever on the laptop, and keep the main desktop for heavy stuff. Less lag, less fiddling, fewer why-is-this-blurry moments.
If you do try this route, a few practical things matter:
  • Put both devices on the same desk height or close to it
  • Use the same keyboard/mouse via software sharing or a USB switch
  • Match scaling/font size so your eyes don’t hate you
  • Turn off sleep settings on the laptop while you’re working, or it gets anoying fast
So: if you mean ‘plug cable into laptop and use it like a monitor,’ usually no.
If you mean ‘make the laptop useful as part of a dual-screen workspace,’ yes, absolutley. Different idea, same end result for a lot of people.
I’d split this into two separate goals:
A. One desktop stretched across two screens
B. Two devices on one desk that feel like one workspace
@suenodelbosque, @caminantenocturno, and @mikeappsreviewer already covered the usual routes, but I actually think people over-focus on forcing the laptop panel to become a monitor. For daily work, the smarter move is often to dock the laptop beside the desktop and sync the workflow, not the video signal.
What I mean:
  • use a USB keyboard/mouse switch
  • or use shared clipboard / input software
  • keep chat, docs, email, music, dashboards on the laptop
  • keep the desktop for the heavy apps
That gives you most of the benefit of dual screens without video compression, wireless lag, weird scaling, or capture-card jank.
If you insist on making it feel more unified, check whether your monitor supports picture-by-picture or whether your peripherals can switch between both machines fast. Weirdly, that’s often cleaner than trying to turn the laptop into a display.
Pros of using the laptop in the setup
  • no need to buy another screen right away
  • portable fallback
  • useful as a true second machine
  • can reduce load on the desktop
  • awkward desk ergonomics
  • color/brightness mismatch
  • different scaling and aspect ratios
  • battery and sleep settings become annoying
  • not a true plug-and-play monitor replacement
So my take: if you want a real extended desktop, a proper monitor is still the least frustrating answer. If you just want more room to work, the laptop is absolutely usable, just not in the way most people first imagine.
