My iPhone storage is nearly full, and photos are using most of the space. I want to safely clear photo data and free up storage without accidentally losing important pictures. What’s the best method, including handling iCloud Photos and recently deleted items?
Don’t start by wiping your whole photo library. I got back a decent amount of space by clearing out the stuff I didn’t care about: duplicates, batches of nearly identical shots, old screenshots, Live Photos, and oversized videos. My library was over 100 GB, so sorting everything manually wasn’t practical.
I used Clever Cleaner to group the clutter into separate categories, including duplicate and similar photos, duplicate videos, screenshots, Live Photos, and large media. You can review items before deleting them, shrink eligible photos with the Compress tool, or go through the gallery one item at a time in Swipe mode.
Smart Cleanup is useful if you want to handle similar photos and compressible media across several categories with a few taps. The app is free, has no ads, and doesn’t require a subscription to get started. Some cleanup features have a fairly generous daily limit for new users.
I’d clean things up in roughly this order:
- Remove duplicate and similar photos.
- Check large videos and duplicate videos.
- Delete unwanted Live Photos, or compress them if you want to keep them.
- Clear out screenshots you no longer need.
- Run Smart Cleanup if you want to cover several categories together.
- Empty the Recently Deleted album afterward. Otherwise, that storage may not become available for up to 30 days.
Also check Messages. Photo and video attachments can still take up space even after you clean up the Photos app. Open a conversation, tap the contact’s name, select See All under Photos, then choose and delete anything you don’t need. Deleting an entire conversation also removes its attachments.
If you use iCloud Photos, turn on Optimize iPhone Storage under Settings > Photos. That keeps smaller versions on the phone while the full-resolution originals remain in iCloud.
Old trip and event albums are another good place to start. Reviewing 50 similar vacation shots together is much quicker than scrolling through your entire library. Once the big cleanup is done, spending a minute or two each week deleting fresh screenshots and duplicates keeps the problem from building up again.
You probably don’t need to sacrifice important memories just to free up storage. Clearing duplicates, similar shots, large videos, Live Photos, screenshots, and old message attachments can make a substantial difference.
Deleting photos from the iPhone is not a device-only cleanup when iCloud Photos is enabled. Those deletions sync to iCloud and your other Apple devices, so copy anything important to a computer or separate backup first and verify the files open. If you want to keep the library, use Optimize iPhone Storage instead of deleting it. Leave the phone charging on Wi-Fi afterward, since the space savings may not appear immediately. Cleanup apps such as Clever Cleaner can help find clutter, but check every selection rather than treating automatic suggestions as a backup.
Start in iPhone Storage, not by mass-deleting from the Photos app. Go to Settings > General > iPhone Storage and check whether it offers “Review Personal Videos.” A handful of long 4K videos or screen recordings can consume more space than thousands of ordinary photos, so removing the largest files first is usually the quickest win.
I agree with @voyageurdubois about iCloud syncing, but verify that syncing has actually finished. Open Photos, scroll to the bottom of the library, and check the sync status. If uploads are paused or your iCloud storage is full, some recent originals may still exist only on the phone. “Optimize iPhone Storage” cannot protect files that never uploaded.
For a safer first pass, use Apple’s built-in albums. Check Duplicates under Utilities and use Merge, then inspect Videos, Screen Recordings, Bursts, and Screenshots under Media Types. This is less aggressive than letting an app decide which similar photo has the best expression or focus. Clever Cleaner can still be useful for finding near-duplicates that Apple does not flag, but I would treat its similar-photo choices as suggestions, not automatic decisions.
If you are moving pictures to a Mac, PC, or external drive, do not assume a successful import message means the backup is complete. Open several imported photos and videos, including recent ones, and confirm they play at full resolution. Live Photos may be transferred as separate image and video files depending on the import method. Ideally, keep another copy of that folder before deleting anything from the phone.
Empty Recently Deleted only after those checks. Until then, its 30-day holding period is useful insurance. If you only need enough room for an iOS update or a trip, deleting two huge videos and some downloaded app content is often safer than trying to clean the entire photo library in one session.
Saving photos into the Files app on the same iPhone can actually make the storage problem worse. You may end up with a second local copy, and files in iCloud Drive can still stay downloaded on the phone. A real safety copy should be on a computer, external drive, or cloud service outside the synced iCloud Photos library.
After copying, disconnect the phone and open a selection of photos and videos from the backup itself. Then delete the biggest unwanted items from Photos, wait before emptying Recently Deleted, and confirm nothing important is missing. @voyageurdubois is right that deleting with iCloud Photos enabled removes those items across the synced library, so iCloud Photos by itself should not be treated as a separate backup.
If you want to keep everything, Optimize iPhone Storage is the least destructive route. If you need space immediately, large videos will usually matter more than cleaning hundreds of small images. Cleaner apps can speed up sorting, but I would never let one automatically choose between similar family photos.
Don’t compress your photos to save space unless you’ve thought hard about it. That Compress tool @petethecircuit mentioned does work, but you’re trading permanent image quality for a fairly small gain per photo. Compressing a few hundred normal shots gets you a lot less than deleting two long 4K clips, and the compressed version is what you’re stuck with going forward. If you ever want a print or a crop later, that decision comes back to bite you. I’d only use it on stuff I genuinely don’t care about keeping at full quality.
The point @kernelnode5670 made about videos is the one that actually matters, and it gets buried under all the photo talk. Storage math is lopsided. One minute of 4K at 60fps can eat more room than a whole day of regular photos. So before anyone touches their similar-photo pile, sort the library by size or hit Review Personal Videos and clear the biggest offenders first. That alone might solve the problem and you never have to agonize over which family snapshot to keep.
Where I’d push back a little is the idea that Optimize iPhone Storage is a clean safety net. It only downloads-on-demand when iCloud actually has the originals. If your iCloud is full and uploads are stalled, some photos are still living only on the phone at full size, and toggling that setting does nothing useful. Check your iCloud status first. Otherwise you think you’re safe and you’re not.
Clever Cleaner is fine for the grunt work of grouping duplicates and near-identical bursts, which the Photos app is genuinely bad at. I’d treat it exactly like the others said, as a sorting helper, not a decision maker. Let it gather the candidates, then you make the call on anything you’d be upset to lose. The automatic best-shot picking is a convenience, not gospel.
One thing nobody flagged: if you’re on a shared iCloud plan or use Shared Albums, deleting from your side can affect what others see, and Shared Albums have their own separate storage rules. Worth a quick look if you share photos with family before you go on a deleting spree.
A simpler first step is to free space outside Photos by offloading unused apps. Your photo library stays untouched, and the apps retain their documents and data.
Open Settings > General > iPhone Storage, select an app you rarely use, then tap Offload App. Check its App Size first, since offloading removes the app itself, not its saved data.
Start with a large game you dont play anymore. Check your availble space afterward before deciding whether you need to delete photos.
